Go Back  RCU Forums > RC Airplanes > RC Jets > Turbine Clinic > KingTech Turbines International
Reload this Page >
K120G starting issue "weak gas"
KingTech Turbines International Barry is your host and will help you with all your Kingtech questions and concerns.
Old 10-20-2018, 10:49 AM
makis
makis's Avatar
Default K120G starting issue "weak gas"
Hi guys,
I need your help and/or advice. The turbine has 3 hours flight total time and I attempted today to start it after 5 months. During the starting sequence, after stage 3, it fails to start, it cuts down and "weak gas" is displayed on GSU. I make several attempts but with the same result. The turbine battery is LiFe 3s 9.9V 3650mah and it was 96% full with voltage 10.2V. I'm trying to figured out what the problem might be, any help will be much appreciated.
Old 10-21-2018, 09:37 PM
makis
makis's Avatar
OK guys, problem solved!!!
The fuel filter from pump to turbine was almost clogged, plenty of kerosene residues. I removed it and I placed new one and the turbine runs again.
