Go Back  RCU Forums > RC Airplanes > RC Jets > Turbine Clinic > KingTech Turbines International
Reload this Page >
K80G1 flames on start up sequence.
KingTech Turbines International Barry is your host and will help you with all your Kingtech questions and concerns.
Old 01-11-2020, 06:48 PM
CARS II
My Feedback: (7)
CARS II's Avatar
Default K80G1 flames on start up sequence.
My K80 is spitting a bit of flames on the start up sequence, just on the first 30-40 seconds.
Remind me which adjustment do I have to decrease.
Using Kero.
Tks.
Old 01-13-2020, 04:33 AM
gunradd
My Feedback: (9)
gunradd's Avatar
If its during the preheat phase then preheat fuel might be a little high. You need to look when its starting to see the phase its spiting flames.
Old 01-13-2020, 02:00 PM
CARS II
My Feedback: (7)
CARS II's Avatar
Thank you for the reply, I will have a chance to run the engine again on Wen, in the meantime, I've been reading about other's engine problems similar to mine and also found some good info about starting the turbine, including preheat in the manual on page 28.
I will let you know if the preheat changes takes care of the flames.
Tks.
Old 01-13-2020, 09:07 PM
Daniel-J
Daniel-J's Avatar
Try to test it at different speeds, does it always do this at work?
Old 01-15-2020, 04:29 PM
CARS II
My Feedback: (7)
CARS II's Avatar
Run the engine today, in a nut shell, the only adjustment I did was to the Pump PW Ignit. K, from 23 down to 17, left the pre heat as it was, now it is doing a clean start, must have a strong pump I guess, only 4 hrs on this engine.
Thank you for the advise.
