11.1v Battery for G4 turbine
Regards, Jason
As for the batteries, a fully charged 3S LiFe will be 10.8V and a fully charged 3S LiPo will be 12.6V. That's a serious voltage difference.......
Jason_H (12-04-2020)
My Feedback: (9)
At times you can get the overvoltage message on a fully charged LIFE battery. So after a charge I like to hold the throttle up a little longer during the start. This will run the starter motor manually before the start lowering the voltage for a good start.
3 cell LIFE is the only recommended battery for these engines G2 and up. Some people will use a 2 cell LIPO but that does not last as many flights and not recommended since the biggest wear on a turbine happens during start up you want the max voltage the system requires. I also would never stick a lipo in my plane anyway unless its an EDF but that's just me. I have to many scale planes that the battery's are not accessible without allot of work so they must be charged in the plane.
makis (12-08-2020)
