K100 accel delay question
Hello,
I noticed if I slowly raise the throttle from idle to max I can get the turbine up to full speed very quickly. However, if I just slam the stick forward from idle to max, it takes about 3 times longer to accelerate by itself. Why is that? |
RE: K100 accel delay question
set your acc delay faster
i know the k100 is very fast |
What is your acceleration and decelleration set at now? You will find it in the run menue.
