TF P-51 kit cowl problem
MN
I'm building the TF P-51 kit, with the US engines 41, soft mount.
If I build the cowl the way the plans show, I won't be able to get the upper engine mount bolt out on the carb side of the engine.
Wondering what others have done ?
Is there a FG cowl that would work better?
My Feedback: (158)
ORIGINAL: Pete S-RCU
Here's a picture, its a Great Planes mount.
I bought the engine at a swap meet, new in the box.
It came with the mount.
Looks to be enough to get passed the flywheel with that big 5" spinner up there
I'd glue the sides to hold the spinner ring, and then take off your spinner back plate and remove just enough materail to get the wrench on the bolts and to be able to remove the engine. Then put it all back and proceed to finish up the cowl
good luck
