Reload this Page >
Robin Hood 99" CG question
Old 01-15-2011, 04:18 PM
dunk
My Feedback: (153)
Default Robin Hood 99" CG question
I purchased a used Robin hood 99" shaved about 2.5 lbs off of it and was getting ready to try to CG the thing. I was going to go on the main spar and should be fine but was curious what the actual CG should be. Going to be a cool plane for my kid.
Old 01-26-2011, 03:47 PM
David3827
Default RE: Robin Hood 99
Sir, I just ran across your CG request. I can put the wing on mine tomorrow and let you know if you still need it.
Old 01-26-2011, 03:58 PM
dunk
My Feedback: (153)
I still need the CG almost finished covering the fuse.
thanks a bunch
Gary
Old 01-26-2011, 06:42 PM
David3827
Gary I'll let you know. David, N.C.
Old 01-27-2011, 07:07 PM
David3827
Gary, mine balanced at the main spar. It is the Robin 99
Old 01-27-2011, 07:52 PM
dunk
My Feedback: (153)
Thank you very much for taking the time to check for me. I was not really worried but I am adding a smoke tank and material and wanted to try to see where to install for the cleanest look.
