Reload this Page >
Dornier Do-335
Dornier Do-335
Old 02-13-2011, 04:42 AM
kenazzo2000
Default Dornier Do-335
i wish to buy plans or a kit of this plane anyone know were i can get one ? thanks
Old 02-13-2011, 05:24 AM
AJsToyz
AJsToyz's Avatar
Default RE: Dornier Do-335
http://www.kitcutters.com/Smi/SmiDO335Dorn.htm
http://www.precisioncutkits.com/donsmith.htm
Old 02-13-2011, 05:34 AM
kenazzo2000
thanks very much
Old 02-13-2011, 10:57 AM
Ram-bro
My Feedback: (101)
The Al Masters kit/plans are the same scale and size. That is what I fly
Old 02-13-2011, 11:55 AM
kenazzo2000
ORIGINAL: Ram-bro
can you give me more information please
Old 02-13-2011, 12:03 PM
Ram-bro
My Feedback: (101)
My 335 has an OS 150 on the front and an OS 60sf on the rear. I believe the ws and length are rgiht at 85" and 1/6.5 scale.....Dont have the weight numbers. It will fly on the 150 alone...ask me how I know. That rear engine does add quite abit of umph to it. It flies like a pattern bird and has a very unique sound to it when both are turning and burning. It is an all wood kit with the cowls being glass and you can order these and the canopy. Hope this helps. I am currently refinishing my 335, hope to hae it finished before the spring
ID:	1562965   Click image for larger version
ID:	1562966   Click image for larger version
ID:	1562967   Click image for larger version
Old 02-13-2011, 12:09 PM
kenazzo2000
ORIGINAL: Ram-bro
My 335 has an OS 150 on the front and an OS 60sf on the rear. I believe the ws and length are rgiht at 85'' and 1/6.5 scale.....Dont have the weight numbers. It will fly on the 150 alone...ask me how I know. That rear engine does add quite abit of umph to it. It flies like a pattern bird and has a very unique sound to it when both are turning and burning. It is an all wood kit with the cowls being glass and you can order these and the canopy. Hope this helps
first of all you did a nice job if i buy the plans only will i have how to build the cowls on the plan ? is the plan good to build the whole plane ? like the ribs and formers and so on ? thanks for all of your help
Old 02-13-2011, 12:22 PM
Ram-bro
My Feedback: (101)
I cant claim any of he building. I bought the plane several yrs ago here on RCU but I have gone under the skiin to stregthen and reglass the kit. I would say it builds pretty light and could use some stregtheniing in certain areas. I dont really like the front hatch area....takes away some rigidity from the front end. The nose gear is so long that the it changes the shape somewhat of the nose area when being built. The scale lines arent the best but you can work with them. If you notice inmy pics, the exhaust stacks and carb intakes arent located in the scale positions or are the scale sizes. I ordered a set from IMP models to bring it up to code. It would be just about impossible to do a scale cockpit without some serious redesigning and strengthening of the front 1/3rd of the fuse. This kit begs for a fiberglass fuse so that the cockpit can be done properly. The wingtips are now solid onmine as they were changed to solid balsa pieces. I added wing filets the full length and I also aadded to the dorsal scoop, added flaps. It will be more different than the same when Iam done.
Old 02-13-2011, 12:27 PM
kenazzo2000
thanks alot hope all goes well on the changes i will need a good plan because im not a expert at building
Old 02-13-2011, 02:42 PM
Ram-bro
My Feedback: (101)
there are several of the Al Master's kits out there flying. If you can handle sheeting, I imagine this wont be a hard build for you. The wing is of conventional build and the fuse is stringers and sheeting
Old 02-13-2011, 02:45 PM
TLH101
My Feedback: (90)
TLH101's Avatar
Al Masters Do-335:
http://www.wingsontheweb.com/do335/index.php
http://www.wingsontheweb.com/vhangar...o335_proj.html
Use the tabs at the top to get all the available info on the model. Short kits, plans & parts are available for an 81" & 60" version.
Old 02-13-2011, 10:11 PM
kenazzo2000
thanks everyone for your help hope i get one
Old 02-14-2011, 06:52 PM
kenazzo2000
has ANYONE bought the plans recently from somewere ? if yes from were ? thanks
Old 02-14-2011, 07:29 PM
Ram-bro
My Feedback: (101)
can you buy them from the above sites? There is also Don Smith plans
Old 02-14-2011, 07:32 PM
kenazzo2000
ORIGINAL: Ram-bro
im trying hope i can get one im going crazy about this plane lol
Old 02-14-2011, 07:39 PM
Ram-bro
My Feedback: (101)
here are a coupla build threads to ease or poke at your pain
http://www.rcscalebuilder.com/forum/...58&KW=do%2D335
http://www.rcscalebuilder.com/forum/...67&KW=do%2D335
and maybe this one
http://www.rcscalebuilder.com/forum/...97&KW=do%2D335
Old 02-14-2011, 07:43 PM
kenazzo2000
thanks ram-bro your a big help i was selling all of my planes cause i got hooked on rc cars ive got 40 including 2 jet cars now my son whants to start and learn how to fly and he s got me whanting to fly as well
