contol rods
ORIGINAL: TimT2000
These are the quickest adjusting rods on the planet, no wonder they are out of stock
right now. I have bought many for my planes.
Cheers
Tim
http://www.troybuiltmodels.com/items/HAN3555.html
Cheers
Tim
id rather pay less for more just a quick example http://www.hobbyking.com/hobbyking/s...dProduct=13038
ORIGINAL: MetallicaJunkie
10 bucks is way over priced
ORIGINAL: TimT2000
Cheers
Tim
Cheers
Tim
Just giving the best option. (giving money is not an option)
Cheers
Tim
If money wasn't an option I would have a fleet of full scale
I put well over 100lbs of force on my rod setup and it held. this was in the pull direction. Being that they are short(4"-5") they are also very strong in the compression direction. I am sure that the longer the rods are the weaker they are in the compression direction. I did not try to bend them in the middle as the rods will never see this force on the plane. I am cutting the rods to full length and utilizing all the threads in the ball end for extra strength as well. My 33% Waco weighs in excess of 60lbs fully loaded and I am fully confident in these rods holding.
Build one and test it out.
Just my .02
Anthony
Just my .02
Anthony
ORIGINAL: dsrepairs
Need to buy or make 4-40 control rods 3 5/8'' long threaded on both ends. Scoured the online vendors and found nothing. Anyone know a source for off the shelf premade sizes ? Not in love with the ''all thread'' look but will use if only option. Thanks</p>
Why hasn't any one recomended using the solder on connectors available in 4-40 and 2-56 made by Dubro http://www3.towerhobbies.com/cgi-bin...?&I=LXD924&P=M very easy to use and you can make good use of all the rod you buy. You can also buy a 4-40 die and just thread the rod.
#31
My Feedback: (22)
FL
I have been making my own control rods for years..the best system out there is a small company called RODCHUCK.COM.......they will sell you the dies needed to make both 4-40 threaded rods and 2-56....you use bare werlding sticks..its a excellent means for making control rods for larger planes and well as conventional glow..
recently I did try another product as weight was a major consideration (3D)..awesome rods from central hobbies...the carbon fiber material is as strong as steel and the rod ends are made from titanium and you just instal with J weld epoxy..nothing better for the price.all the f3a pattern guys rely on them.
of course the best connectors are ball link connectors from dubro..
If you buy the rodchuck system I guarantee you'll likely make all your own rods and never go to a hobby shop for 4-400 steel rods again.never!
#32
I cut my rods to length from #2 or #4 stock, and use a 2-56 or 4-40 die to thread both ends. Takes 3 minutes. I also cover the rod with CF, epoxied for additional (compression) strength. Ball links for both ends.
I trust a solid rod implicitly more than a soldered end connection.
To the point of an earlier post, commercially available dies are all right-handed, so I cannot make those nice counter-threaded turnbuckle type rods. But I can make rods any length i need from what i have in the shop. If anyone has a source for LH dies, that would be interesting.
#33
ORIGINAL: wjcalhoun
If anyone has a source for LH taps, that would be interesting.
Later!!
Anthony
