Reload this Page >
***CUB BROTHERHOOD***
Old 05-04-2013, 04:54 PM
  #1126
Props4ever
Default RE: ***CUB BROTHERHOOD***
BAMMMMMM!!!!!!!!
Cub with test nose gear strut!!!!
4th picture proves that fuselage is sitting on its nose gear strut!!!!
Off course actual strut will be different with bigger nose wheel.
ID:	1879192   Click image for larger version
ID:	1879193   Click image for larger version
ID:	1879194   Click image for larger version
ID:	1879195   Click image for larger version
ID:	1879196   Click image for larger version
ID:	1879197   Click image for larger version
Old 05-04-2013, 05:13 PM
  #1127
stevegauth30
stevegauth30's Avatar
wow, the firewall looks like it was recently recovered from a ship wreck. im sure youll dr. it up though.
Old 05-04-2013, 05:47 PM
  #1128
Props4ever
Now Cub with whole new empinnage!!!!
ID:	1879201   Click image for larger version
ID:	1879202   Click image for larger version
Old 05-04-2013, 11:00 PM
  #1129
Props4ever
Unscrewed the main upper cabin door frame, I don't like the way it's hinges from outside, it will be rehinged again properly.
Had to add balsa strip fillets to even out and give back root airfoil's top curve on the fuselage, it was all sanded into wavy pattern amd looked awful plus lose lift also, now its all fixed.
Right top stringer of the fuselage between main wing and stabilizer also needed to be looked, it had one joint loosen up but other 2 were not even joined right on the formers, so had to make couple corner notches on the former corners to reglue and attach this stringer perfectly, it's also done now.
Presently right wing is attached to the fuselage with one screw holding it, I'm surprised to see the amount of gap there is between fuselage and wing!, it's more then 1/8" from front to the back.
Now I'm going to add a fillet here shaped as root airfoil but my question is, with this much gap where as these both should be butt joined together at this attachment point, can these Cubs fly???
ID:	1879271   Click image for larger version
ID:	1879272   Click image for larger version
ID:	1879273   Click image for larger version
ID:	1879274   Click image for larger version
ID:	1879275   Click image for larger version
ID:	1879276   Click image for larger version
Old 05-05-2013, 12:54 PM
  #1130
WacoNut
WacoNut's Avatar
I installed the new YDA-56 engine in my 1/3 Cub. She is now ready for another flying season.
Later!!
Anthony
Old 05-05-2013, 01:44 PM
  #1131
Cub Flyer Fresno
Cub Flyer Fresno's Avatar
Oh my goodness!  Remember to put the wings on before you try to fly that thing!
Hey, are we going to get to see a video of how it performs with that engine?  I'd like to see that.
Take care,
David
Old 05-05-2013, 01:54 PM
  #1132
WacoNut
WacoNut's Avatar
I will get the wife to shoot a video next weekend weather permitting. That will give her practice shooting video for the Waco.
Later!!
Anthony
Old 05-05-2013, 02:28 PM
  #1133
Joey B
Joey B's Avatar
I would like to join cub brotherhood I have been flying for about 29 years had several cubs and I am building 1/4 scale balsa usa cub now almost ready to start covering using solartex cub yellow 0s 120 fs for power and have robart scale landing gear
Old 05-05-2013, 10:55 PM
  #1134
AlmondRancher
Cub Man,
I appreciate the welcome.
Old 05-05-2013, 11:50 PM
  #1135
AlmondRancher
Anthony,
That is a very nice looking 1/3 scale cub. What engine was installed on the plane before you replaced it with the YDA-56?
Old 05-06-2013, 01:40 AM
  #1136
WacoNut
WacoNut's Avatar
It had a YDA-56 on it before. It is a perfect power combination for this plane. The engine is no longer made so spare parts are hard to come by.
Later!!
Anthony
Old 05-06-2013, 05:30 AM
  #1137
FlyerInOKC
FlyerInOKC's Avatar
You are making some good progress. The airplane reminds me a little of a SIG kit but I'm still not sure what it is.
Old 05-06-2013, 08:05 AM
  #1138
bikerbc
Joey B I am building a BUSA I/4 Cub too and am almost ready for covering , I am using the Robart gear as well.. I am using the DU-Bro 1/3 scale Cub wheels .. I have an OS Gemini Twin 160 on .. It should have close to the same power as the FS 120 .. I have the FS 120 in my Sig 1/4 Cub and it is a very good match .. I still have a few finishing touches like the tail wires and radio to install but it is getting close ..But flying season is here .. I am thinking about using a set of Hanger 9 wing struts from their 1/4 Scale J3 .. They will need a little modifying but I like how they mount and look...They will need to be lengthened a bit . I also made a little hatch on top of the cabin so that I will be able to put my wing bolts on from the outside...
Old 05-06-2013, 05:51 PM
  #1139
Joey B
Joey B's Avatar
bikerbc Ibuilt the struts that came with kit but i like the idea you have on the wing mounting bolts it is going to be a pain putting them in from inside the cabin
Old 05-06-2013, 09:23 PM
  #1140
bikerbc
It is a pain putting them on from the inside .. I have a Sig Cub and its wings are held on from the outside , I like that way better.. I have two BUSA1/3 Scale Cub and there wings are held on from the inside too and I find I seldom want to fly them because of the setup... So I thought how could I make this easier... I have the Hanger 9 PA19 and the Hanger9 Taylor craft and bolt of those planes have their wings held on with one wing bolt on each side and it works fine.. There isn't much force pulling out on a wing .. The back bolt is easy to gain access to from the outside .. You can just open up a strip about 1.25" wide and make a small hatch held on with a couple of screws...If you decide you want to have two wing bolts you can still put the front ones in from inside the cabin.. How much Dihedral did you use ? 1.25 per side ? Do you have any wash out ?
Old 05-06-2013, 11:04 PM
  #1141
AlmondRancher
I have a few engines that have been out of production for several years, so replacement parts are also very hard to come by. Irecently purchased a O.S. FS-48 from a member on RCU. The engine has been out of production for quite some time. Iam surprised that Tower Hobbies still carries spare parts for this old engine. Some of the parts from a O.S. FS-52 are interchangeable. Iam considering installing the engine on a Sig 1/5 scale anniversary cub.
Old 05-07-2013, 07:37 AM
  #1142
bikerbc
I am not familiar with the engine but it will probably fly the plane in a scale like manner . It is definatly on the low end of the power scale ..If it were mine I would be looking for something a little bigger...I might be worth a try.. Cubs can get away with low power but I wouldn't fly it on a windy day ..
Old 05-07-2013, 08:09 AM
  #1143
smkrcflyer
smkrcflyer's Avatar
Does anyone have the Bill Hempel’s 50cc Clipped Wing Cub?
http://www.billhempel.com/CWC/25Clip...Cub/index.html
Old 05-07-2013, 10:52 AM
  #1144
bikerbc
Oh why oh why did you have to show me that ? Now I have drool all over my keyboard .. I don't have one but I want one bad ..
Old 05-07-2013, 11:38 AM
  #1145
FlyerInOKC
FlyerInOKC's Avatar
ORIGINAL: bikerbc
He thought you needed something to build in your "spare time"!
Old 05-07-2013, 05:44 PM
  #1146
Cub Man
My Feedback: (50)
Cub Man's Avatar
#1 Cub Man - Charles Brooks
#2 Minn Flyer - Mike B.
#3 acerc - Robert R
#4 Arup -
#5 Frequent Flyer -
#6 bikerbc -
#7 GAP RCU -
#8 rafeeki -
#9 Scirocco 14 - Mark
#10 Lins - Lindsey G
#11 CK1 – Chris
#12 Jaybird –
#13 heritageman -
#14 Live Wire - Larry K
#15 Saito18 –
#16 davidgeorge212 –
#17 WacoNut –Anthony
#18 raydar –
#19 no1isnormal –
#20 JH313 –
#21 JNorton – John
#22 FJRrider –
#23 lovetoflyguy – PJ
#24 Edwin – Edwin
#25 Lavell – Lavell
#26 crash bandicoute
#27 do335a –
#28 fred985
#29 Pa-18cub150 –
#30 cessna579 –
#31 cubcrasher –
#32 mac1va –
#33 morganflyboy –
#34 Steve Landron –
#35 mintie –
#36 Gordie M –
#37 extra-nut –
#38 snowball –
#39 eastkurt - Kurt
#40 JerryM –
#41 rcavi8or –
#42 meanrc –
#43 Rc Overkill –
#44 oldiron410 –
#45 Hill202 –
#46 weathervane – Andrew
#47 SunDevilPilot –
#48 iflyj3 – Dan
#49 gluemaster –
#50 EddieC –
#51 CanDo – Les
#52 dabigboy – Matt
#53 [email protected] –
#54 woodworm –
#55 skipb
#56 mrdhub – Dan
#57 Homer712
#58 scaleman57 –
#60 psheffield
#61 quiltsfly
#62 G.Barber
#63 bobbailey
#64 scflyboy
#65 Cub Flyer Fresno
#66 FILE IFR - Mike T
#67 talob – Mike
#68 Lowvoltage – Joe
#70 Glyder – Chuck
#71 smkrclfyer –
#72 jeffEE
#73 GW –
#74 lever02
#75 AB Bob – Bob
#76 rede2fly –
#77 Barn-E-Stormer
#78 Ray S. –Ray
#79 Daniel-EL
#80 ExcaliburIII – Richard Longfellow
#81 jrb1 -
#82 on_your_six –
#83 BGCombs
#84 RevGQ
#85 jkr_1100
#86 Dope Fiend
#87 paero-RCU
#88 .50cal
#89 mrshea - Phil
#90 Cougar-RCU
#91 glenladen
#92 cublover
#93 lowbubba
#94 steve
#95 Gray Beard
#96 roaddog2
#97 biam
#98 rcpilotaviator
#99 funtana1
#100 rcavi8or
#101 GPutt33
#102 actionjackson
#103 sj3cub
#104 dreamwever
#105 phatbob02
#106 igoren
#107 N1EDM
#108 mrwad – Don
#109 dirtrod – Ty
#110 HawkI
#111 redkav
#112 GerKonig _Gerry
#113 SCOTT42
#114 5blue
#115 crazystick
#116 3rd time Richard
#117 chevyman962000
#118 Mrj3cub
#119 Oldflyer2
#120 rogergh
#121 TEAMERICA
#122 cannonball200
#123 TripleDeucer
#124 tenspeed59 – Mark
#125 rcjunky67 – Robert
#126 VincentJ
#127 nalby
#128 fcf
#129 malitape
#130 sirzepp
#131 rmpRmP
#132 Rv7garage
#133 pt19 flyer
#134 JohnFH
#135 ahgoodman
#136 skyraider71
#137 Planejaw
#138 rc airplane nut
#139 Stan7476
#140 RDJeff
#141 rmpRmP
#142 oldfartpilot
#143 Big Lacy
#144 mnemennth
#145 Unclebuck21228
#146 WacoOne
#147 AV8RJIM
#148 retcaptafd
#149 dadragon
#150 boss_rc
#151 [email protected]
#152 msu68stang
#153 cowboy1969
#154 cubflyman
#155 akcub
#156 oldfartpilot
#157 jwrich
#158 rmyret
#159 tom_sandiego
#160 5skyhawk172
#161 archie05
#162 JerryM
#163 elaguilacalva
#164 arfwrecker
#165 I_Fly
#166 althepal88
#167 ROCKY1405
#168 scale buff
#169 Grumpy Monkey
#170 pt19 flyer
#171 Cloud Cruiser
#172 rye
#173 Props4ever
#174 oldfartpilot
#175 rcfighterjock
#176 cubkadet
#177 wildbills21
#178 RCJones
#179 FlyerInOKC
#180 WB6JGD
#181 Joey B
Old 05-07-2013, 05:51 PM
  #1147
Cub Man
My Feedback: (50)
Cub Man's Avatar
Last year at the DOGS event they used one in a candy drop. Man I would love to have one.......
Old 05-07-2013, 05:54 PM
  #1148
Cub Flyer Fresno
Charles, it needs to be bigger.  Not the plane, the photo!  [X(]
Old 05-07-2013, 06:22 PM
  #1149
Cub Man
My Feedback: (50)
Cub Man's Avatar
That was from my wifes cell phone
Old 05-07-2013, 06:46 PM
  #1150
Props4ever
Things seems to be getting slower but I'm trying to keep up the pace.
Last night I pulled out can of Neato and sprayed on the black areas in the forward fuselage as shown in last segment of pictures.
I was hoping all that black stuff is old glow fuel or gas that is soaked in the wood and grime/dirt accumulated from past many years of use, sure enough I was right. Today I vacuumed off the dried out powder and it pulled out a lot for crap from the wood and made areas a lot cleaner and dirt free. This is amazing stuff to remove old glow fuel or gas soaked wood to get rid of grime n dirt. Now I can recover over these ares with out worrying about anything.
ID:	1880095   Click image for larger version
ID:	1880096   Click image for larger version
ID:	1880097   Click image for larger version
ID:	1880098   Click image for larger version
ID:	1880099   Click image for larger version
ID:	1880100   Click image for larger version
ID:	1880101   Click image for larger version
ID:	1880103   Click image for larger version
ID:	1880104   Click image for larger version
ID:	1880105   Click image for larger version
