***CUB BROTHERHOOD***
#1926
mnem, what you are looking for is simple being a stabilization unit will always require flight adjustments for the very reason you mentioned, cg, wing incidence, thrust, etc. What I do, and has worked well so far, is set the fuse on the table, raise the tail to level flight (level placed on the stab), set level flight at this point. It may need slight adjustments hereafter but those can only be made after flying, and it will fly well at this setting with minor trim adjustments.
#1927
Ahhh... okay.
The plane of the horiz stab was what I tried to use with my Dynam Pitts build, but I was fighting issues with warpage due to well-known issues with the kit. Bottom line, it's nearly impossible to buy one with straight tailfeathers. I eventually wound up putting a bullseye level on each side of the horiz stab and one on a piece of flat lexan across the flat plane of the battery hatch in the nose. When I split the difference with the tail bubbles, the one in the battery compartment was dead-on, so I went with that. We'll see how it flies when I can get my buddy Brook to take it up and help me trim it out.
With this one there's no evidence of that kind of warpage; I just wanted to make sure there wasn't some magic "golden rule" that I as an ignorant stick-banger didn't know about.
mnem
* One less
mnem
* One less
#1928
Just out of curiosity, whats this Ardu Pilot all about?... a fair guess I'm assuming some sort of recovery auto pilot thing-a-ma-jig.
I've been toying with the idea of using a recovery parachute that gets deployed when the radio goes into fail-safe... but I've thought about it so long now, someone else probably has already done it.
John M,
John M,
#1929
I've been thinking about that as well. A parachute recovery on fail-safe or on a channel, although I guess one could just shut off the Tx to cause a deployment. The trick would be retrofitting it to an existing plane, or even designing it into a new build as well. Hmmm...
#1930
#1931
ArduPilot is an open source Arduino-based Flight Controller that has been in continuous development for about 6 years. The folks who started DJI started out there. It supports flight stabilization, vector-management and RTL superior to ParkZone's SAFE hardware, as well as fully autonomous flight in pretty much any form of multirotor, fixed and rotary wing aircraft, as well as boats and ground vehicles.
At this point, the GUI is advanced enough that even a programming-defective hack like me can figure out how to use it.
My main intent is to use it as a "SAFE" equipped plane with emergency RTL. A trainer.
I plan to fly it after I use up my similarly built and equipped Bixler, which I am also building now.
mnem
*ZZZzzzZZZzzzZZZzzz*
mnem
#1932
#1 Cub Man - Charles Brooks
#2 Minn Flyer - Mike B.
#3 acerc - Robert R
#4 Arup -
#5 Frequent Flyer -
#6 bikerbc -
#7 GAP RCU -
#8 rafeeki -
#9 Scirocco 14 - Mark
#10 Lins - Lindsey G
#11 CK1 – Chris
#12 Jaybird –
#13 heritageman -
#14 Live Wire - Larry K
#15 Saito18 –
#16 davidgeorge212 –
#17 WacoNut –Anthony
#18 raydar –
#19 no1isnormal –
#20 JH313 –
#21 JNorton – John
#22 FJRrider –
#23 lovetoflyguy – PJ
#24 Edwin – Edwin
#25 Lavell – Lavell
#26 crash bandicoute
#27 do335a –
#28 fred985
#29 Pa-18cub150 –
#30 cessna579 –
#31 cubcrasher –
#32 mac1va –
#33 morganflyboy –
#34 Steve Landron –
#35 mintie –
#36 Gordie M –
#37 extra-nut –
#38 snowball –
#39 eastkurt - Kurt
#40 JerryM –
#41 rcavi8or –
#42 meanrc –
#43 Rc Overkill –
#44 oldiron410 –
#45 Hill202 –
#46 weathervane – Andrew
#47 SunDevilPilot –
#48 iflyj3 – Dan
#49 gluemaster –
#50 EddieC –
#51 CanDo – Les
#52 dabigboy – Matt
#53 [email protected] –
#54 woodworm –
#55 skipb
#56 mrdhub – Dan
#57 Homer712
#58 scaleman57 –
#60 psheffield
#61 quiltsfly
#62 G.Barber
#63 bobbailey
#64 scflyboy
#65 Cub Flyer Fresno
#66 FILE IFR - Mike T
#67 talob – Mike
#68 Lowvoltage – Joe
#70 Glyder – Chuck
#71 smkrclfyer –
#72 jeffEE
#73 GW –
#74 lever02
#75 AB Bob – Bob
#76 rede2fly –
#77 Barn-E-Stormer
#78 Ray S. –Ray
#79 Daniel-EL
#80 ExcaliburIII – Richard Longfellow
#81 jrb1 -
#82 on_your_six –
#83 BGCombs
#84 RevGQ
#85 jkr_1100
#86 Dope Fiend
#87 paero-RCU
#88 .50cal
#89 mrshea - Phil
#90 Cougar-RCU
#91 glenladen
#92 cublover
#93 lowbubba
#94 steve
#95 Gray Beard
#96 roaddog2
#97 biam
#98 rcpilotaviator
#99 funtana1
#100 rcavi8or
#101 GPutt33
#102 actionjackson
#103 sj3cub
#104 dreamwever
#105 phatbob02
#106 igoren
#107 N1EDM
#108 mrwad – Don
#109 dirtrod – Ty
#110 HawkI
#111 redkav
#112 GerKonig _Gerry
#113 SCOTT42
#114 5blue
#115 crazystick
#116 3[SUP]rd [/SUP]time Richard
#117 chevyman962000
#118 Mrj3cub
#119 Oldflyer2
#120 rogergh
#121 TEAMERICA
#122 cannonball200
#123 TripleDeucer
#124 tenspeed59 – Mark
#125 rcjunky67 – Robert
#126 VincentJ
#127 nalby
#128 fcf
#129 malitape
#130 sirzepp
#131 rmpRmP
#132 Rv7garage
#133 pt19 flyer
#134 JohnFH
#135 ahgoodman
#136 skyraider71
#137 Planejaw
#138 rc airplane nut
#139 Stan7476
#140 RDJeff
#141 rmpRmP
#142 oldfartpilot
#143 Big Lacy
#144 mnemennth
#145 Unclebuck21228
#146 WacoOne
#147 AV8RJIM
#148 retcaptafd
#149 dadragon
#150 boss_rc
#151 [email protected]
#152 msu68stang
#153 cowboy1969
#154 cubflyman
#155 akcub
#156 oldfartpilot
#157 jwrich
#158 rmyret
#159 tom_sandiego
#160 5skyhawk172
#161 archie05
#162 JerryM
#163 elaguilacalva
#164 arfwrecker
#165 I_Fly
#166 althepal88
#167 ROCKY1405
#168 scale buff
#169 Grumpy Monkey
#170 pt19 flyer
#171 Cloud Cruiser
#172 rye
#173 Props4ever
#174 oldfartpilot
#175 rcfighterjock
#176 cubkadet
#177 wildbills21
#178 RCJones
#179 FlyerInOKC
#180 WB6JGD
#181 Joey B
#182 cwhitacre21
#183 Yank II
#184 RCJones
#185 facia
#186 Aiden88
#187 spaceworm
#188 Sgt. Meyer
#189 LarsL
#190 jmcowart
#191 308jockey
#192 yak86
#193 p510851
#194 Bauer66
#195 baldguy
#196 acdii
#197 Mr-Punk
#198 skylark-flier
#199 braddock VC
#200 ThunderBoat42
#201 Ultimateflying
#202 FlyerInOKC
#203 John_M_
#204 Mako17
#205 bpoates25
#206 3136
#207 Loopdeeloop
#208 Jim Hargett
#209 deanz406
#210 darren4
#211 Murphey
#212 Horsepoweraviation
#213 Chucks
#214 Bob Howard
#215 Firewalkerd1
#216 Antares100
#217 motor12
#218 hogflyer
#219 bigbird3
#220 PeterC
#221 bwoofter
#222 Bush Flyer
#3 acerc - Robert R
#4 Arup -
#5 Frequent Flyer -
#6 bikerbc -
#7 GAP RCU -
#8 rafeeki -
#11 CK1 – Chris
#12 Jaybird –
#13 heritageman -
#15 Saito18 –
#18 raydar –
#19 no1isnormal –
#20 JH313 –
#21 JNorton – John
#22 FJRrider –
#24 Edwin – Edwin
#25 Lavell – Lavell
#27 do335a –
#28 fred985
#29 Pa-18cub150 –
#30 cessna579 –
#31 cubcrasher –
#32 mac1va –
#33 morganflyboy –
#34 Steve Landron –
#35 mintie –
#36 Gordie M –
#37 extra-nut –
#38 snowball –
#39 eastkurt - Kurt
#40 JerryM –
#41 rcavi8or –
#42 meanrc –
#43 Rc Overkill –
#44 oldiron410 –
#45 Hill202 –
#47 SunDevilPilot –
#48 iflyj3 – Dan
#49 gluemaster –
#50 EddieC –
#51 CanDo – Les
#52 dabigboy – Matt
#54 woodworm –
#55 skipb
#56 mrdhub – Dan
#57 Homer712
#58 scaleman57 –
#60 psheffield
#61 quiltsfly
#62 G.Barber
#63 bobbailey
#64 scflyboy
#67 talob – Mike
#70 Glyder – Chuck
#71 smkrclfyer –
#72 jeffEE
#73 GW –
#74 lever02
#75 AB Bob – Bob
#76 rede2fly –
#77 Barn-E-Stormer
#78 Ray S. –Ray
#79 Daniel-EL
#81 jrb1 -
#82 on_your_six –
#83 BGCombs
#84 RevGQ
#85 jkr_1100
#86 Dope Fiend
#87 paero-RCU
#88 .50cal
#89 mrshea - Phil
#90 Cougar-RCU
#91 glenladen
#92 cublover
#93 lowbubba
#94 steve
#95 Gray Beard
#96 roaddog2
#97 biam
#98 rcpilotaviator
#99 funtana1
#100 rcavi8or
#101 GPutt33
#102 actionjackson
#103 sj3cub
#104 dreamwever
#105 phatbob02
#106 igoren
#107 N1EDM
#108 mrwad – Don
#109 dirtrod – Ty
#110 HawkI
#111 redkav
#113 SCOTT42
#114 5blue
#115 crazystick
#117 chevyman962000
#118 Mrj3cub
#119 Oldflyer2
#120 rogergh
#121 TEAMERICA
#122 cannonball200
#123 TripleDeucer
#126 VincentJ
#127 nalby
#128 fcf
#129 malitape
#130 sirzepp
#131 rmpRmP
#132 Rv7garage
#133 pt19 flyer
#134 JohnFH
#135 ahgoodman
#136 skyraider71
#137 Planejaw
#139 Stan7476
#140 RDJeff
#141 rmpRmP
#142 oldfartpilot
#143 Big Lacy
#144 mnemennth
#145 Unclebuck21228
#146 WacoOne
#147 AV8RJIM
#148 retcaptafd
#149 dadragon
#150 boss_rc
#152 msu68stang
#153 cowboy1969
#154 cubflyman
#155 akcub
#156 oldfartpilot
#157 jwrich
#158 rmyret
#159 tom_sandiego
#160 5skyhawk172
#161 archie05
#162 JerryM
#163 elaguilacalva
#164 arfwrecker
#165 I_Fly
#166 althepal88
#167 ROCKY1405
#168 scale buff
#169 Grumpy Monkey
#170 pt19 flyer
#171 Cloud Cruiser
#172 rye
#173 Props4ever
#174 oldfartpilot
#175 rcfighterjock
#176 cubkadet
#177 wildbills21
#178 RCJones
#179 FlyerInOKC
#180 WB6JGD
#181 Joey B
#182 cwhitacre21
#183 Yank II
#184 RCJones
#185 facia
#186 Aiden88
#187 spaceworm
#188 Sgt. Meyer
#189 LarsL
#190 jmcowart
#191 308jockey
#192 yak86
#193 p510851
#194 Bauer66
#195 baldguy
#196 acdii
#197 Mr-Punk
#198 skylark-flier
#199 braddock VC
#200 ThunderBoat42
#201 Ultimateflying
#202 FlyerInOKC
#203 John_M_
#204 Mako17
#205 bpoates25
#206 3136
#207 Loopdeeloop
#208 Jim Hargett
#209 deanz406
#210 darren4
#211 Murphey
#213 Chucks
#214 Bob Howard
#215 Firewalkerd1
#216 Antares100
#217 motor12
#218 hogflyer
#219 bigbird3
#220 PeterC
#221 bwoofter
#222 Bush Flyer
#1934
ArduPilot is an open source Arduino-based Flight Controller that has been in continuous development for about 6 years. The folks who started DJI started out there. It supports flight stabilization, vector-management and RTL superior to ParkZone's SAFE hardware, as well as fully autonomous flight in pretty much any form of multirotor, fixed and rotary wing aircraft, as well as boats and ground vehicles.At this point, the GUI is advanced enough that even a programming-defective hack like me can figure out how to use it.My main intent is to use it as a "SAFE" equipped plane with emergency RTL. A trainer.I plan to fly it after I use up my similarly built and equipped Bixler, which I am also building now.mnem*ZZZzzzZZZzzzZZZzzz*
One of our local Universities comes to our field on occasion to test something very similar (fully autonomous flight control system), but I think they're trying to get theirs to land on its own... they need to come up with a mobile ILS system that can be place on the runway so it can lock onto the glide slope; then we'll need ATC, just to wave off the heavies lol... if they could come up with a system the could land an RC plane, and do it reliably at a reasonable price, that would be the ultimate fail-safe / recovery.
John M,
#1935
I have never posted in this forum before, but I was having a look through the forums tonight and found this, and I had to write. I just don't know how I missed this, I would love to join the Cub Brotherhood, at the moment I have three cubs One ARF 40 size and two electric one 52 inch wing span and my own design super cub for the park of only 36 inches. Last year I spent most of my modelling budget on designing and building CNC router. I have four other plans for cubs One Semi-scale super cub a 1/5 scale L4 and the last two are 1/4 scale one J3 and the other a PA11, So this year I hope to get cracking on building the Pa11 model from the plans and the semi-scale for the son in law. My wife wonder why I keep on buying the same model plans just in different sizes, But I'm just a Cub nut. Mike.
#1936
#1939
Neat-o, sounds like fun stuff.
John M,
John M,
I've developed a bad habit of NOT staying "3 mistakes high" because by the time I get there, I'm only a few moments away from being so far away that orientation is a problem for me and my old eyes. I either get disoriented and start flying the wrong way, or don't realize I'm inverted, or get my bearings wrong re: Nose-in/Nose-out, etc and the ground rushes up faster than I can figure it out.
I'm hoping that by hitting it with the scattergun approach... by building a big, yellow plane I can actually see that can pretty close to fly itself (knock on balsa) that I can get a little closer to my goal of "one more successful landing". Because so far, there's been just the one... and I wasn't even there for it. I call it my Jigsaw Cub because it's been pieced together so many times.
http://www.youtube.com/watch?v=4siKf-MBHXA "Learning to fly; tongue-tied & twisted, just an earth-bound misfit, I.
Unfortunately, lots of Jello when I'm walking due to the floppy brim on my Walkabout Hat. Not too bad once I plant my feet & start crashing... err, flying the plane
I was getting the Jigsaw Cub trimmed out when I lost sight of it behind a tree; killed throttle & went out to pick up the pieces, but as I approached, saw it sitting in the driveway, just waiting for me so I restarted the video.
Figures - my first successful landing, and I wasn't even there for it!"
http://www.youtube.com/watch?v=rMr_L30CvmI If you have patience for REALLY boring flight videos that are mostly of a plane that's just a speck or worse before getting lost, here's the 5 minutes leading UP to that:
Thank Ifni for my buddy Brook; he's stopped me from giving up forever more times than I can count. And he's saved my plane more times too.
mnem
Landing is one aerobatic maneuver which MUST be mastered.
#1940
Nice little park flyer you have there; looks like a lot of fun... kinda reminds me of my 1/2A days... I remember loosing one in the sun glare... I could hear it but lost sight of it... I just kept the stick pulled back doing loop after loop hoping she wouldn't run out of fuel until I got sight of it again.
The bigger ones fly a lot more stable, especially the 1/5, 1/4, 1/3 scale, you'll be amazed at the difference... only thing is they're not as forgiving in situations such as in your first video; you would be walking up to a pile of wood... my eyes aren't that great either, so the next cub will be 1/3 scale, if I can't see that a quarter mile away, then I should be using a walking cane.
John M,
John M,
#1941
Yeah, it's the cheapo foamie from HK; colors don't match, decals looked so bad I threw 'em away, and the little dark green sticker on there is off one of my son's Lego kits. He stuck it on while I wasn't looking, so I left it on there for luck.
I figure by now it weighs twice as much in glue and bamboo BBQ skewers.
That still ain't a lot.
But I've gotten my money out of it for sure, it doesn't owe me a cent; That and my Champ. I think maybe I need to take a detour and patch that old beast up...
mnem
Need another indoor venue...
mnem
#1943
MI
looks like the guys flying quads are way ahead of you guys. they can turn the radio off and their quad comes back to them and lands and does the same thing if they get a low battery. I no they are using a GPS tied into some other things.
#1944
MI
A typical autoland system consists of an ILS (integrated glideslope receiver, localizer receiver, and perhaps GPS receiver as well) radio to receive the localizer and glideslope signals.
#1945
VT
John M, I've been back since last Wednesday. tried to post thursday and lost the thread during the post and just forgot about it. Computer is a putz! I have been on an aspirin regiment for several years as you suggested. I am on ten different meds since the heart attacks. Doing cartio rehab three times a week too.
got my number while I was gone, 219, thanks to whom ever.
Gotta go now, time to get ready for my work out.
bird.
bird.
#1947
I was thinking the same but decided to leave well enough alone, lol... but since you brought it up... while I was watching his first video, and he was exclaiming "no wwwway" "no wwway" as he was weaving in and out of the tomb stones... I thought to myself, wheres the flying field in the middle of the cemetery??... someones been resurrected ???... it was quite the entrance to what became the obvious.
John M,
#1948
Thanks, Steve. I keep trying. If I can learn this, the real thing may not be far behind...
box car - The Ardupilot is the SAME board; it can be configured for ANY type of vehicle, including quads. Auto-Landing is a LOT easier when you have VTOL capability. On a fixed-wing, the intent is to "Return To Launch" if it gets too far away for you to see orientation, or if you get disoriented yourself, not to land it for you. This is still great; if it gets close enough to the right course, you can just feather throttle until it parks itself like the HobbyKing T1000FC video:
http://hobbyking.com/hobbyking/store...trSearch=t1000
(Click on the "Watch The Daily" link on the product page)
I'm just looking for something to keep my "D'OH!" moments from being quite so terminal for my planes; I do expect to fly most of the time and land it by myself, I'm not THAT inept.
Actually, not flying in the Cemetery; only crashing.
The cemetery is what was on the other side of the tree I lost it behind.
EXACTLY the sort of CDE that having RTL could save my plane from.
mnem
*Fuel*
mnem
*Fuel*
#1949
VT
Only if you are superstitious brother! Superstitions control only those that believe them. The scriptures say that the living are conscious that they will die but the dead are conscious of nothing at all. And fate? There is no such thing! You make your life what it is by your choices. Sorry!
bird.
bird.
#1950
It not superstition is all those blasted monuments you can hit! And they like airplane eating trees in those cemeteries too! It's almost as bad as trying to use a prairie grass field for take offs and landings.
Off topic: I remember the first time I visited my wife's family in Queens and the wife took me over to see Harry Houdini grave. Being from Oklahoma and having lived in several Southwestern states I had never seen a cemetery that size! And the headstones and monuments were really cool to see! I got a kick out of the cemetery beside the road to New Orleans from the airport too. Cemeteries are really interesting from an artistic view.
