Help with U-CAN-DO-3D  60 >
Old 08-27-2003 | 02:59 AM
Default Help with U-CAN-DO-3D 60
Gentleman,
I just bought a U-CAN-DO-3D 60 Size ARF. As Im looking through the owners manual, They supply you with a cut-up sheet of CA hinge material. Should I use the CA hinges or some other type???
Biggfrank
Old 08-27-2003 | 03:01 PM
My Feedback: (13)
They can be used. Just be sure to use a grease pen or a crayon to draw a heavy line down the center of the hinge where it will be bending. This will keep the CA glue from that area which keeps the flexiblity and helps prevent breakage.
Also be careful to not wind up with binding if your hinge line is too tight. I always seal my hinge lines anyway so if you need to have a sufficiently wide gape in order to get the huge throws needed (45 degrees or more!) you will need iron in some sealing material anyway (stripes of monokote).
Old 08-27-2003 | 05:05 PM
Default U-CAN-DO
Thanks for the tip Gary. It all maks a lot of sense to me.
Old 08-27-2003 | 05:35 PM
MinnFlyer's Avatar
Here Ace, read this:
http://www.rcuniverse.com/reviews.ph...ew&reviewid=55
Old 08-28-2003 | 01:41 AM
Default CA Hinges???
Minnflyer,
Thanks for the link, I read it a couple of times and im going to use that technique on my plane im sure everything will work out just fine.
Ace
