G-FAST build
FL
Once the vertical fin set up I started fitting the side sheeting. I think I spent about a half a day fitting the left and right sides. Lots of trimming, sanding, pinning, taping, and most of all, patience......oh and more pinning.....
I had to keep the sides damp to get the balsa to curve. This sheeting is 1/8 balsa and was a slight pain to shape in a few areas. Once satisfied, I glued them in. Once the sides were completely dry I fitted the top balsa block. I didn't want to rush the glueing so I waited an extra day before I started sanding/shaping. Also, my balsa filler ended up becoming no good. I had to put an order in. Hope to get that in a few days.
FL
Since I'm waiting on a few things to arrive in the mail for the fuselage, I decided to jump back over to the wings. I also want to keep things moving along. Because its been so fricken long from when I last worked on this plane, I forgot that I never built the ailerons. I spent 30 min looking for something I never built..yikes!😖
Anyway, I built them over the plans as shown. Nothing too special there. I did make a provision in the bottom sheeting of the aileron for lite ply. This is for the control horn mounting. I also filled in that pocket with balsa to strengthen.
FL
I finally finished the ailerons. I rounded the roots just enough to achieve at least +/- 20 degrees of deflection. I also added 3/32 lite ply to the bottom of the ailerons to support the control horn. I didn't want it compressing the balsa during flight. At the time I originally started this post I had ordered the CF landing gear from GraphTech RC. I had used their products before and had great success with their stuff. Sadly, I don't believe they are in business anymore. I think JTEC is selling CF landing gear these days. I have yet to purchase their products.
#31
FL
Next steps over the next day or so...
-mount the tail landing gear and hook up linkage
-mount the main landing gear, wheels, and wheel pants
-cut canopy and finish off the cockpit
-make the elevator control rod assembly
I will post some pictures when finished.
#32
FL
Does anyone out there know if Fiberglass Specialties is still in business? There website is up and I only get a voicemail that is hard to make out. Unfortunately this model does not come with a suggested cowl. I was hoping they could help me out with a generic cowl option. I really want to avoid having to fabricate a plug and build a mold to produce one single fiberglass cowl. Any info will help, thanks.
