telemaster 40
hi guys
just finishing up a telemster 40 from kit and it is listed as a 40 engine.
fuselage was built by someone else and I built the wing with flaps.
it seems quite heavy for a 40 engine, what are you guys using?
thinking of using a 60 on it, can alway throttle down.
thanks
pt19 flyer
thanks
pt19 flyer
thanks guys for reply and response.
will go with the 40 to 46 per your advice
got it covered and painted servos and pushrods made and
ready for engine mounting.
thanks and happy flying
pt19 flyer
pt19 flyer
ok ken
thanks for reply
what does yours weigh?
just holding mine up without motor mounted, it just seems real heavy, so I
was just wondering if a 46 would fly it. I will mount one of the listed motors
and weight at that time. have the servos and pushrods installed.
have the blue os 46 and an os 46sf.
thanks for reply
pt19 flyer joe
thanks for reply
thanks for reply
pt19 flyer joe
Telemasters have big wings, they can be a little "heavier'. My 96" telemaster weighed a ton and I flew around 1/4 to 1/2 throttle most of the time.
You'll be fine.
Jason
You'll be fine.
Jason
ok jason
thanks very much for advice, keep your fingers crossed for me.
as the name implies I really like the pt19 planes. had a beautiful model
built from flying model plans, was a beautiful flyer, but it originally had
torque rod aileron control which wa not very effective. finally removed the
covering and replaced with 90 degree bellcranks. worked very well.
with the torque rod had a major flutter at full throttle.
kit was built by a flyer in florida, was very strong and heavy but an
excellent flyer after I made the above changes. looking to build another
pt19 in the future, this winter maybe. in a stupid move I sold it with some
pressure to a fellow club member. haven't seen him fly it as yet, thinking of
checking if I would buy it back. you ever do something like this?
thanks very much
pt19 flyer joe
thanks very much
pt19 flyer joe
I had many good flights on my Telemaster 40 plane with a Magnum .46. I even carried a 3 pound payload a few times! If I had a OS .46, it would be a great match for your plane. As Jason already said, this plane has plenty of wing area, you don't need to over power it.
ok CanDo
thanks for reply and info...if you find any smart thumbs and get more than
you need or can use, I want some, can use some...ha!ha!
thanks & happy flying, no crashes allowed!
pt19 flyer
pt19 flyer
