Top-Flite Contender
Charlie,
Can you take some closeup pics of your 4-stroke installation in your Contender? Looks like it going to be a real tight fit.
Thanks!!
Anthony
Thanks!!
Anthony
I have the engine mounted and the throttle push rod hooked up.
I found the inner rod for the throttle push rod was missing from the kit, The excess from this rod is what also acts as bearings for the rest of the solid wire pushrods. [:@][:@][:@] I had another pushrod for the throttle in my stock but unfortunately I had already glued in the outer rods for the elevator and rudder and I need the missing rod to complete that installation. Looks like I will be making a phone call tomorrow to get a replacement sent out.
I will be able to contniue on the build since I was able to get the throttle connection completed.
Later!!
Anthony
Later!!
Anthony
ORIGINAL: WacoNut
Charlie,
Thanks!!
Anthony
Charlie,
Thanks!!
Anthony
Any bigger engine I'd have needed a bigger airframe . . . perfect!
Thanks for the pics Charlie,
I called Tower today and they directed me to the parts department and I have the missing manual and the inner control rod tube on it's way. I had a club meeting tonight so I didn't get any work completed on the Contender.
Later!!
Anthony
Later!!
Anthony
#31
I have made some good progress on the fuse.
The cowl has been shaped and sanded. Next up is to work on the wing mounting. If all goes well I should be starting to cover the plane this evening.
Later!!
Anthony
Later!!
Anthony
#32
I am also tinting the canopy. It is currently soaking in black Rit dye. I warmed the water to 115deg and will let the canopy soak until the water cools off to room temp. I will post some pics of the canopy after it has been tinted and rinsed and dryed.
Anthony
Anthony
#35
Should fly really good on that engine.
I flew one with a .46AX and it really flew it well.
I am wrapping up the last few items and covering will begin.
Anthony
Anthony
#36
Covering has been started.
It has been years since I have used Monokote. The fuse will be the hardest thing to cover so I figured I would get it out of the way. So far it is turning out pretty good. Going to call it a night and get back on it tomorrow.
Later!!
Anthony
Later!!
Anthony
#39
Thanks Guys,
I really dislike film covering. But it does have it's advantages.
As you will see from thew pics the plane is almost covered. I will be adding some white stars to the blue bands on the wings. It should be easy to tell the top from the bottom in the air. The plane is mostly blue from the bottom and red from the top. I plan on having the plane ready for the maiden next weekend.
Here are a few pics of how it is looking so far.
Anthony
Anthony
#40
Just came across this thread. Really Anthony, 10 days. If you build any faster everyone would miss everything. LOL
Look's great. I bet it's going to be a rocket.
#41
I am slipping a bit, it should be flight ready right now
I have always liked the looks of the Contender and wanted one. I think this will be a great plane to have in the hangar for Fun-Fly events at the club.
Later!!
Anthony
Later!!
Anthony
#42
ORIGINAL: WacoNut
Hi Rick,
I will be having some fun with this one. I had to mow grass when I got home from work today so it is slowing me down a bit
It has been years since I have covered a plane with Monokote and I am going to need some pointers. I will be doing a Red,White and Blue pattern with overlapping colors. What is the best way to seal the edges of the monokote? I will be applying some of the trim parts with windex and little heat. Is monokote trim solvent best or acetone?
Later!!
Anthony
Hi Rick,
Later!!
Anthony
Anthony,
You have outdone yourself once again......I fell a sleep for six days and you have about finished the thing.
I have not tried the acetone yet for applying trim. I have successfully used monokote trim solvent for doing narrow strips of monokote to form trim around the windows of a Decathlon. It even worked around the windshield. But I had to cut the pieces curve to fit - obviously since I was not using heat to stretch and shrink. I have had some success using the Windex trick for larger trim pieces. But heat is still need to keep the stuff on. even with the Windex to squeegee out the air I still ended up with those pesky little bubbles that needed poked with a pin.
Anyway...your plane is looking as good as I figured it would. Looks like you got the covering stretched around the lower nose well.
#43
Hi Rick,
I am using Windex to put the stars down and I will test acetone tomorrow for sealing.
It took alot of heat and stretching to get the nose and the wing tips covered.
Later!!
Anthony
Later!!
Anthony
#44
I think I am done with the covering.
I do need to cut out the slots for the landing gear wires and seal them down. I am happy with how the covering job turned out. I will go over the stars and some of the trim pieces tomorrow with acetone and heat if necessary.
I think the stars add a nice touch.
Anthony
Anthony
#45
This recipe works very well for applying Monocoat trim.
I don't remember just where I got it. But I have used it many times.
Not sure why it came out one long line. It was a paragraph when I uploaded it.
Fred
Fred
#47
ORIGINAL: Smashmaster
Fred
Fred
#48
I have all the servo's installed in the plane and the fuel tank is installed and plumbed.
I am still waiting on the missing inner control rod, I called them today and they said it shipped yesterday so hopefully tomorrow it will arrive.
The landing gear has been mounted and the plane is now sitting up on it's legs. I also painted the cockpit and I am in the process of painting the pilot. I will finish up the painting tomorrow and glue the pilot in place and glue the canopy in place.
Should be on pace for putting the maiden flight in this weekend.
Anthony
Anthony
#49
The control rod did not arrive so I worked on adding some decals to the plane. My wife said the white areas were too plain. I also added a 1/8" pinstripe to the blue bands on the wings.
I have to say I have enjoyed building and finishing this kit. I am usually a scale plane builder and flyer but I will be proud to show up at the field with this plane.
Anthony
Anthony
