Reload this Page >
Sig Ryan STA
Sig Ryan STA
Old 10-11-2012, 02:46 PM
  #251
VincentJ
VincentJ's Avatar
Default RE: Sig Ryan STA
How much was it Neddy? Sounds interesting.
Old 10-11-2012, 04:43 PM
  #252
Neddy191
Neddy191's Avatar
It was about $25
Old 10-11-2012, 07:19 PM
  #253
Cub Flyer Fresno
Cub Flyer Fresno's Avatar
You can pick them up at Hobbylinc for $21.09.  Ship it USPS and the total comes to $27.04.
Anybody else find it cheaper?  I wanna get one!
Old 10-12-2012, 02:58 AM
  #254
VincentJ
VincentJ's Avatar
Update on my wing progress: Lat night I glued all of the aileron and flap ribs to the leading edge as well as getting all of the hinge blocks in place. Wing tip has been laminated and is awaiting its place on the wing. Should be completed with the right wing in a few more days!
How about a few more favorite tool photos guys! It's good to share...
Old 10-12-2012, 07:46 AM
  #255
TCampbell
TCampbell's Avatar
ORIGINAL: Cub Flyer Fresno
Good ol' Amazon.com saves $0.87, $20.24 + $5.93 shipping to NH from Best Service Stores (shipping may be more for folks out west?). This one is on my RCwish list.
My box of building tools is pretty light as I'm new to it, but I have to say that after a #11 blade and sand paper, my pin vise and set of small Dremel bits gets a lot use drilling holes for motor mounts, flying wires and hinge points.
**Even better, our local RCBuyers has it for $25.99!
Old 10-12-2012, 08:44 AM
  #256
Lowvoltage
http://www.btemodels.com/fourmost.html
He makes very nice kits too!
Old 10-12-2012, 10:38 PM
  #257
cavoodle
Hi VJ, Sorry that it has taken me so long to reply to your question re the wing tip to aileron transition. It has been a couple of weeks since I last logged into your site. Unfortunately I did not take any close up pics of that area at the time, apart from the one I posted along with some others on page 6. Now that the wing is covered I am unable to respond to your request, sorry. As I recall it was simply a matter of building up with balsa and then sanding back to the required aerodynamic shape once the ailerons were hinged to the wing.
Old 10-12-2012, 11:21 PM
  #258
cavoodle
Hi VJ, Just noticed that you are working on the landing gear blocks. Sometime earlier you mentioned that you were considering fitting the Robart robostruts as I have fitted to mine. If you are going to install these you will need to purchase them first as you will need to modify the positions of the mounting blocks to the wings so that these struts can be custom fitted. Fitting these Robostruts allowed me to rake the undercarriage foward by about 1 inch which I hope will help with the problem of nose overs on landing, particularly on our clubs grass flying field that at times can be a little long!
Old 10-13-2012, 05:58 AM
  #259
Stickbuilder
Stickbuilder's Avatar
Quick question: Did the ST-A use any landing lights? If so, where were they located, and what type? Same for the Navigation lights.
Bill, Waco Brother #1
Old 10-14-2012, 04:43 AM
  #260
VincentJ
VincentJ's Avatar
Hopefully somebody that knows can answer you Bill. I didn't see any on the planes that I have seen.
Since the weather here is lousy, ( rainy, windy and cold ) and flying is not possible I will try to get in the workshop all day today...
Update on the right wing. Wing tip has been installed and all the hinge blocks have been glued and drilled for their respective hinges. I still haveto sheet the top of the wing and install all the servo mounts, then I can start to join the two wing halves together! Thanks to all that posted their build tool picks. It's always nice to see what other modelers are using.
Old 10-14-2012, 05:44 AM
  #261
WacoNut
WacoNut's Avatar
Bill,
The Ryan did not come equipped with lights. If you are modeling a military version no lights. If you are modeling a restored civilain version then all bets are off.
Later!!
Anthony
ID:	1811084   Click image for larger version
Old 10-14-2012, 01:11 PM
  #262
VincentJ
VincentJ's Avatar
Spent the better part of the day in the workshop and I got all the hinging on the wing DONE! The aileron tip has been shaped and transitioned into the wing tip as well.These wings were a handful to build, but I have to saythey are really beautifull to look at, almost a shame to cover them up...Will go back down shortly to make the servo mounts. I really lose track of time when I'm working in the shop.
Old 10-15-2012, 02:30 AM
  #263
Stickbuilder
ORIGINAL: WacoNut
Bill,
Later!!
Anthony
Yep, I'm doing the ST-A Special with the Ranger six cylinder engine, not the 4 cylinder Menasco version. May add lights since Ryan was a forerunner of installing leading edge landing lights. I even thought about using a retractable light under the right wing. I'm still looking for photos.
Old 10-16-2012, 05:10 AM
  #264
VincentJ
VincentJ's Avatar
Last night I made the two aluminum servo brackets for the aileron and flaps. During it's contruction I had to use the disc sander to get the aluminum brackets sized properly. I kept my old 6" Grizzly disc sander just for metal working purposes, I can't believe what a difference their is between the Jet and Grizzly sander! What a piece of crap, how did I ever get along without it? Tonight I will make the four 1/32" ply reinforcement pieces for the landing gear mounts. Getting closer, will be back with photos soon... ( Had to rake a ton of leaves last night )
Old 10-16-2012, 05:20 AM
  #265
acerc
acerc's Avatar
I don't comment much. Just enjoy watching. But I must say PICTURE'S!!!!
Old 10-16-2012, 06:04 AM
  #266
VincentJ
VincentJ's Avatar
So glad you missed my pics! I didn't take any pics of the right wing Robert because it's just a duplication of the left side. If you want to see the right side I can take a few tonight.
Old 10-16-2012, 06:12 AM
  #267
Cub Flyer Fresno
Yeah!  I wanna see!  Pictures!  Pictures!  Pictures!
Old 10-16-2012, 03:55 PM
  #268
VincentJ
VincentJ's Avatar
OK here are some pictures! Various shots of the left and right wings. Servo bays are tight for the flaps, but doable. I am currently working on the 1/32" ply reinforcements for the landing gear mounts. these are time consuming to make as they are all hand filed to get the shape that I want, there are four of them and I have two more to make... Still a lot of sanding and shaping to do,
ID:	1811936   Click image for larger version
ID:	1811937   Click image for larger version
ID:	1811938   Click image for larger version
ID:	1811939   Click image for larger version
ID:	1811940   Click image for larger version
ID:	1811941   Click image for larger version
ID:	1811942   Click image for larger version
Old 10-16-2012, 03:59 PM
  #269
acerc
acerc's Avatar
There we go. Love watching, especially when it is a clean crisp build, Nice to see that degree of craftmanship.
Keep it up.
Old 10-16-2012, 04:11 PM
  #270
VincentJ
VincentJ's Avatar
Thanks Robert, I'm currently almost two months into this build, hope to have it done in a couple more.
Old 10-16-2012, 06:31 PM
  #271
Cub Flyer Fresno
I've got to second Robert.  Great job.  I hope to order my covering real soon.  Let's see if I can finish my Cub before you finish the Ryan.  Yeah, right!
Old 10-17-2012, 02:48 AM
  #272
VincentJ
VincentJ's Avatar
David, what did you decide on asthe covering of choice for your Cub?
Old 10-17-2012, 08:40 AM
  #273
TCampbell
TCampbell's Avatar
Really inspiring craftsmanship on those wings. You're really setting a standard for us newer builders to strive towards. Just another 20 years or so and maybe I'll get there. Keep up the great work.
Old 10-17-2012, 12:11 PM
  #274
Cub Flyer Fresno
ORIGINAL: VincentJ
VJ, I've decided to go with the Cub Yellow Solartex. After discussions with others that have used it (you included) especially with Robert who has been invaluable for me, it sounds like that will be the best way for me to go, particularly since this is my first built... and... I WANT TO GIT-ER-DUN!!!! I want to do the rib stitching w/pinking then clear coat the entire thing just to make sure it is easier to clean. I'll probably go to Home Depot and get some latex color matched for the cowl and anything else that needs painting.
That's the plan so far. Now all I need is the money..............................
Old 10-17-2012, 02:30 PM
  #275
VincentJ
VincentJ's Avatar
Thanks Tim, always remember it's all about the journey and the pleasure we all get when we build, shapeand see our our creations take flight...it's what keeps me sane in a sometimescrazy world.
David, I think Solartex is a great choice, I'll be using it on this build as well. If you only have to paint the cowl and some other parts such as your landing gear you may want to consider the rattle can that Top Flight makes, it's called LustreKote paint and it comes in Cub yellow. I've used these paints before with some pretty impressive results. May be worth the 7 or 8 bucks to see if it will match the Cub yellow Solartex. just an idea....
Waiting for the glue to dry on the rib reinforcements, will post some photos later this evening.
