Aileron Push Rods ?
IN
Aileron Push Rods ?
OK, I took a break from my Sig MK II build and played around with an Blade MCPx.. WOW, that thing is fun !
Anyways, I just have a few more steps to go on my 1st kit and have a simple question.. On the Aileron push rods, do I make them the same length and use a round servo arm with the off set holes to get some differential ? It makes sense to me, but thought I'd ask. I'm just using a single servo for my trainer also.
Thanks, Bill in Indiana
TX
RE: Aileron Push Rods ?
I use the arms, as they have holes from the edge inward that will do the differential for you. Wheels are okay, and you can drill the holes where you want on them. But generally, I just throw the wheels into my junk box and now have a ton of them that I never use.
Banned
ORIGINAL: BillinIndiana
Perhaps there is something I do not understand from your writing.
If you are using a single servo to operate both aileronsplease see posts #7 and #8.
The length of the rods does not change their linear motion.
Zor
Edited by Zor after posting #7 and #8 posts.
Bill, you can get the aileron differential throw by offsetting the servo arm holes. Set up the controls with minimal slop; I've had flutter because of the loose aileron linkages. I use two aileron servos now.
Yes, you can (and should) make the aileron pushrods the same length. You may also use a round servo arm with the off set holes to get some differential, or you can use the "X" servo arm and use the two adjacent arms (kinda "V" shaped) to do the same thing as long as a 45° offset angle is OK.
I did look at the Sig Mk II construction manual and it is a little unclear about how to set this up. Check out Great Planes PT-20/40/60 manuals if you would like a similar installation.
Hope this helps.
Hope this helps.
Banned
Hello,
The drawing in post #7 shows how aileron differential can be set up with the horns on the ailerons.
I plan to add to this drawing to show how it can also be done witht the arms on the servo.
Zor
Editing to add a new drawing.
Zor
Banned
Hello,
Zor
Editing to add a new drawing.Please see post #8 .
Zor
Banned
Please let us know if we have answered your questions satisfactorily.
Zor
Banned
It appears that Bill is not returning to the thread to acknowledge the help many have offered.
It is not always worth our efforts to help.
Perhaps he is away for a few days ?
I see that his last log in was on 02/19/2013 at 09:53:36 PM
Zor
Zor
