Reload this Page >
Bridi Loadstar 40 Build
Old 03-12-2013, 05:46 PM
dmbaerry
dmbaerry's Avatar
Default Bridi Loadstar 40 Build
Getting ready to start my first build in 20 years. Wish me luck
Old 03-12-2013, 05:57 PM
dmbaerry
dmbaerry's Avatar
Default RE: Bridi Loadstar 40 Build
Here is a pic of the Kit, the new Tactic Radio and a Magnum .40.
Old 03-12-2013, 06:55 PM
GaryHarris
GaryHarris's Avatar
You must be pumped!
I can dig it, and I'm in!
Old 03-13-2013, 07:02 AM
dmbaerry
dmbaerry's Avatar
Thanks Gary, I am really glad you are following because I follow your builds all the time. Will definitly relly on some of your knowledge. I really enjoy your builds. Sorry its not a Kadet..LOL
Old 03-13-2013, 07:28 AM
superfli
My Feedback: (42)
Be careful with that Tatic 4 channel radio. I lost my Electric Stick due to low/dead batteries. The radio takes 4AA batteries. The only warning I got was 4 quick beebs and then the radio died. If possible replace them with recharchable batteries and make sure there full each time you go out.
Superfli
Old 03-13-2013, 07:32 AM
dmbaerry
dmbaerry's Avatar
Yes, thanks Superfli. I already have rechargables for it. Other than the battery issue, how do u like the Radio. My first 2.4 ghz
ORIGINAL: superfli
Superfli
Old 03-13-2013, 06:12 PM
dmbaerry
dmbaerry's Avatar
Well I got right into it tonight. Laid out the plans and covered with wax paper. Sorted and identified the wing parts and started assembly. I am sure out of practice, but feels good to back at it after such a long break (20 years ugh). Any way the kit seems to be really nice and well cut so far, Balsa is good and the instructions are pretty straight forward. Good Work Blue Jay Airplane Kits.
ID:	1861661   Click image for larger version
ID:	1861662   Click image for larger version
ID:	1861663   Click image for larger version
Old 03-13-2013, 06:16 PM
dmbaerry
dmbaerry's Avatar
Here are the specs, if anyone is interested
Loadstar 40
Wing Span: 72.75 inches
Wing Area: 760 sq inches
Engine Size: .25 - .50 (2 Stroke)
Engine Size: .60 (4 Stroke)
Fuselage Length: 53 inches
Est. Weight: 5.50 lbs
Flat Bottom Air Foil
Old 03-13-2013, 07:28 PM
GaryHarris
GaryHarris's Avatar
Looking good brother!
Old 03-14-2013, 04:25 AM
STEVEB
I'm about finished the covering on my Loadstar. I bashed the kit to have separate aileron servos instead of just one as I like to experiment with flaperons and aileron differential. I also used the Solartex covering as my aileron and elevator hinge material giving me totally sealed hinge lines. I've used covering material on .40 and smaller sized planes for many years with no failures.
Also, this in my 5th Bluejay kit and have found all to be a delight to build.
Steve Barnett
Arnold, MD
Chesapeake Bay radio Control
Old 03-14-2013, 04:43 AM
dmbaerry
dmbaerry's Avatar
ORIGINAL: STEVEB
Steve Barnett
Arnold, MD
I am thinking of doing two servo's for the ailerons also.. you would'nt happen to have a pic or two of your set up?
Old 03-14-2013, 04:44 AM
dmbaerry
dmbaerry's Avatar
ORIGINAL: GaryHarris
thanks Gary.. You are the man!!!
Old 03-14-2013, 08:02 AM
STEVEB
You would think that having learned how to fly I could learn how to upload more than one photo at a time. Obviously I have not yet been given the secret handshake. With that said, here is a pic of the bottom of the wing showing the two servo mount/hatch covers. The aileron leading edge is beveled at about 30 degrees with 1 inch wide strips of covering top and bottom for the hinging. As the covering is full span, the entire aileron is sealed. The strings are the pull thru. be sure to cut the appropriate holes in the wings for the servo leads. I'll continue to try and upload more pics.
Old 03-14-2013, 10:04 AM
STEVEB
Here is the servo mount and the top of the servo hatch.
ID:	1861880   Click image for larger version
Old 03-15-2013, 04:38 AM
dmbaerry
dmbaerry's Avatar
SteveB...Did you use standard size servo's in the wings?..
Old 03-16-2013, 01:44 PM
flyinrog
Hey Dave I'll be watchin too...dont much care to build, but I do like to modify......Rog
Old 03-18-2013, 01:04 PM
STEVEB
Full sized servos for all the surfaces.
Old 03-19-2013, 09:31 AM
dmbaerry
dmbaerry's Avatar
Thanks SteveB.. That's what I was thinking but with all the change in equipment,since I left the hobby, I was not sure.
Old 03-20-2013, 04:49 PM
dmbaerry
dmbaerry's Avatar
Ok.. so now I know I am building again.. the old glue the finger tips together..LOL ... Anyway I have made more progress. I have the Right wing half done and sheeted except for center sheeting, that I am going to do when I install the two seperate servos for the ailerons. The left wing is almost finished except for the webbing. I am thinking on black and floresent green color scheme. What do u all think?
ID:	1864661   Click image for larger version
Old 03-20-2013, 05:18 PM
dmbaerry
dmbaerry's Avatar
One more pic...
Copyright © 2021 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
