For all you ARF haters......Sig Kavalier kit built
I've assembled quite a few ARF's over the years and I finally got bored with that so I decided to build a kit. I had originally purchased this kit for my dad back around 1995 so he could start flying r/c again. As things go, he never got around to it. I asked if I could build it and obviously he didn't disagree. The Kavalier is really a nice easy kit to build, the instructions are excellent and I think the end result turned out to be okay. I used Monokote Missile red, Insignia Blue and White mainly because you can still get the matching paint for it and you can't go wrong with the color combination. Obviously I used the pictures on the box for the color design but changed up the original scheme somewhat. I am not a covering expert, that's for sure but I'm getting better and while I like using Monokote, the Missile red seemed to be the most difficult to deal with. Again, that is probably just a problem with me.
The engine is an OS 40SF (that should tell you how long I've had this) and the prop on it is an APC 10 x 6. I have an APC 11 x 6 that I may switch to. The pilot is a Williams Brothers pilot that I put together and painted. I used Dubro low bounce wheels, 2 3/4" main and 2 1/4" nose, and I polished the main landing gear with my dremel tool and a little metal polish. I'm using a 6 channel S-FHSS receiver (only 4 channels will be used) with my Futaba T8J transmitter. I really like this transmitter. It's easy to program, the screen is easy to read, there is no external antennae on the transmitter and it balances very nice on my neckstrap. All up weight without fuel is 5 1/2 pounds so I think it should perform very good. I have not flown this yet but look forward to doing that very soon.
Here are some pics:
Here are some pics:
RE: For all you ARF haters......Sig Kavalier kit built
ORIGINAL: deadstickdan
The engine is an OS 40SF (that should tell you how long I've had this) and the prop on it is an APC 10 x 6. I have an APC 11 x 6 that I may switch to. The pilot is a Williams Brothers pilot that I put together and painted. I used Dubro low bounce wheels, 2 3/4'' main and 2 1/4'' nose, and I polished the main landing gear with my dremel tool and a little metal polish. I'm using a 6 channel S-FHSS receiver (only 4 channels will be used) with my Futaba T8J transmitter. I really like this transmitter. It's easy to program, the screen is easy to read, there is no external antennae on the transmitter and it balances very nice on my neckstrap. All up weight without fuel is 4 1/2 pounds so I think it should perform very good. I have not flown this yet but look forward to doing that very soon.
Here are some pics:
Here are some pics:
Hi and welcome back to the hobby!
rgds/krokko
nibor123 (08-07-2022)
+ 1 on the welcome back. Very nice looking model and a nice building job too. I remember Sig kits and the Kadet as a very nice flier. I still have a Kougar Mk 11 kit unopened under my work bench. Tried offering it as a prize at our club's Fun Fly a couple years ago and everyone said " but it's not a model, it's a kit"...... that's where ARF's have taken us.
I very much enjoyed the building process. There will be more kits to come and while I still think ARFs are okay, I don't look at them the same right now. Much more satisfaction thru the kit build process. The next kit will be a Autogyro Compnay of Arizona C4 auto gyro. That should build quick and definitely be a challenge to fly.
smithcreek, I have seen your Pitcairn build/flight and I do have one of those kits waitng in the wings
Dan
Dan
Nice job Deadstick. I think the kit building process is half the hobby, but that's just me and few other die hard builders! The nice thing is the feeling you get when you fly this bird. They fly differently that ARFs. Not better or worse, it's just that you know what went into the plane and it feels different to fly it. You seem to care about the plane more and stand with a sense of wonder that you built this plane yourself and it's up in the air. Not like an ARF that seems so easily replaced. Enjoy the maiden.
ORIGINAL: yel914
ORIGINAL: deadstickdan I've assembled quite a few ARF's over the years and I finally got bored with that so I decided to build a kit. I had originally purchased this kit for my dad back around 1995 so he could start flying r/c again. As things go, he never got around to it. I asked if I could build it and obviously he didn't disagree. The Kavalier is really a nice easy kit to build, the instructions are excellent and I think the end result turned out to be okay. I used Monokote Missile red, Insignia Blue and White mainly because you can still get the matching paint for it and you can't go wrong with the color combination.
Thank you all for the comments on the Kavalier. I know this one will fly good. I took these pictures on our dining room table and maybe I'm the only one that this happens to but my build room is now a mess. The plane looks good but geeeeeeeeezzzz loueeeeeeeeeeeeez do I have some cleanin' to do I just know I'll find something in there that I thought I had and couldn't find so I went and bought another
I'll get the room all neat and tidy again and start on the next build.
Dan
Dan
Nice airplane! I think if there was ever an assessment to determine the most classic kit of all time, the Kavalier would have to be it. I never built one, but I always looked at it in the Sig catalog with desire. Had friends that flew them and they are great performing machines.
One other thing I tried to do differently with this build is that I used no CA glue. The only glues I used were Titebond II, 30 minute epoxy and 5 minute epoxy. CA glue is starting to bother me and for my pace of building Titebond sets quick enough. I had tried Titebond III on some balsa wood and it works, but soon found out that when Titebond II was used the glue was a lighter color and blended in with the balsa wood better. I don't think I'll ever get tired of opening the kit box and smelling all that balsa
Dan
Dan
That is a nice looking Kavalier! I built one for my dad in the 80's. It is a very good flyer. I hope you enjoy many flights with yours.
My Feedback: (13)
Very nice job, Dan. I saw one of these kits NIB at the Perry swap meet a couple of weeks ago, but I was trying to get to another table for something I spotted. When I went back to score that Kavalier kit, it was gone.[]
I'm about to get back into building myself; just last night I set up the building board and will get back on a Sig Somethin' Extra that my grandson and I began some years ago; got one wing panel done, and the boy discovered girls.
Treasure that .40 SF. I've got one on a Sig Kougar, and a .46 SF on a Stik. Both were purchased back in 1988, both have hundreds of hours on them, and both are fabulous engines. Compare them to current offerings, and you will simply shake your head and wonder "What happened?"
deadstickdan,
From the pics, your completed plane looks excellent! Congrats on a kit build, and keep at it. You even used the old Williams Bros pilots which I used many of, and that adds more to the nostalgia. Jon
I'm almost finished with my Kavalier. Did you do anything to lighten yours up?
4 1/2 pounds seems very light for a finished Kav.
Ed
Ed
Gypsy,
Now I know why my wife has been so happy. I originally used our digital bathroom scale to weigh the plane and it showed 4 1/2 pounds. Tonight I dug out another scale that I've had for years. It's a basic analog scale but is fairly accurate. I weighed a 5 oz fish anchor and my scale was dead on at 5 oz. I put the Kavalier on the scale and found that it actually weighs in at 5 1/2 pounds without fuel. I edited my original post to show the correct weight. I think that makes more sense but now I have to let my wife know she's heavier than she thinks
Dan
Dan
Maybe you should have just left the digital scale for the wife to use and not told her about it.
Would have made for a happier household. Now you have to put up with all that "low cal" stuff for awhile!
Ed
Ed
Dan
Dan
If you get into a position you need to do a little tacking or what have you with CA switch to the foam safe CA. It has a different solvent base and does the trick for me. I can't touch the regular CA without getting sick for a week from the fumes. I have no problems with Bob Smiith's foam safe CA. He even did a custom mix for me once when I need a really thick version. Check your local shop he usually puts their name on the bottle. The foam safe thin has a white top and the medium a black top. These guys are scale modelers so check their website to droll over some beautiful birds!
Mike
Gypsy,
Dan
Gypsy,
Dan
