Sig Spacewalker II 1/4 scale
#2177
#2178
Two, five meter rolls should have less waste than five, two meter rolls, etc.
As far as I'm aware, all rolls are the same width.
#2180
I like the ordering the bigger rolls you can't beat having one single roll of covering. It a great way of insuring you don't run into a color various between smaller rolls which I have seen happen. It also gives you a little protection from unanticipated hanger rash or transport SNAFUs.
#2183
Hi guys, I thought you might like to see some photos of the Spacewalker II I am flying at the moment. It was built by a friend of mine from a highly modified Sig kit. I added a whole bunch of extra scale details for a scale comp we had in February. I am pretty please with the results (below). And the last two images are the original.
#2189
Vincent
Being you moved the firewall back 17/32 (which I also did) did it move the thrust line, because if I follow the original thrust line on the plans using the the DLE-35RA Mounting Pattern the upper holes are very high on the firewall. (I also used a 1/2" firewall). I'd appreciate any help you can give me.
Thank you
Thank you
