Reload this Page >
Best CG location for a Great Planes Big Stik 60
Old 10-26-2013, 01:40 PM
karolh
Default Best CG location for a Great Planes Big Stik 60
The GP 66" span Big Stik 60 plan and instructions give a .75" wide range for it's CG location which equates to from approx. 4.00" - 4.75" behind the wing's LE. Even though most everyone has a different flying feel for their aircraft, what CG location have you found that works best.
Old 10-26-2013, 01:59 PM
countilaw
countilaw's Avatar
A stik usually works very well at 27 % back from leading edge. At this point the nose should hang down slightly. On the original Jenson Ugly stik, the CG worked well at the spar.
Frank
Old 10-26-2013, 03:10 PM
DGrant
DGrant's Avatar
Yep.. right on the spar. I own one. Very nice flying plane. I've got the OS 1.10 in mine. Good luck with yours.
Old 10-27-2013, 04:04 AM
karolh
Which one do you own ?
