Hatch for a 4 Star 40 >
Old 11-21-2013, 03:36 PM
My Feedback: (9)
DGUY's Avatar
Default Hatch for a 4 Star 40
I would like to make a hatch over the fuel tank on this plane. I am not sure on how to do it exactly. So any help or ideas would be appreciated. Especially you guys that have experience with this Sig kit.
thanks
Derrick
Old 11-21-2013, 08:10 PM
foodstick's Avatar
My after thought hatchs are sometimes LESS than spectacular to look at ! but I generally look in the fuse try to figure out what is where. Then I take a razor saw and exacto knife to cut away the hatch. You might be able to use a thin pin to stick thru and FIND exactly where the bulkheads are glued in to the top of the hood. I think the bigger the better on hatch size personally. I like to use a wooden dowel pin up front to hold the hood down, and magnets in the back. Thats what I do on my electric conversions.You will need to make a new front and back bulkhead in the hatch once its removed so that it holds its shape well.
Like I said its not always easy to do and keep things pretty,
Old 11-24-2013, 04:49 AM
My Feedback: (9)
DGUY's Avatar
Thanks for the info foodstick.
Old 11-24-2013, 05:52 AM
I put a tank access hatch in the bottom of this 4*. Instead of gluing the bottom forward fuse plate in place, I glued in a 1/8" x 1/4" frame and the bottom plate is attached to it with # 2 counter sunk screws. The engine is mounted inverted so looking at both pic's the bottom is up.
ID:	1941777   Click image for larger version
Old 11-24-2013, 07:51 AM
foodstick's Avatar
Dguy, for some reason I was thinking you were retro fitting the hatch.. and not building a kit... sign of the times I guess !
Icemakers idea would also work on the top., Instead of shaping the hood the way the instructions state ...simply screw a piece of wood down to the top of the tank cover. then sand it to shape.
The main key is to leave the structure strong enough even without the hatch on,Add some bracing ,tri stock etc. and then be able to securely hold it on. There is nothing wrong with changing the shape or look of things a bit, kitbashing is a fun way to customize.
Old 11-24-2013, 09:08 AM
Since you are building, you have several options. Think about whether you want to have a hatch or just use tape to pull the tank back into the fuse compartment to work on it. Good luck!
Old 11-24-2013, 10:13 AM
I used a cowl for the build, the engine is inverted, I had to get a lower tank placement. I do have mounting plate above the tank. The tank will come out through the fuse after removing the receivers. The hatch makes it convenient.
Old 11-24-2013, 03:01 PM
My Feedback: (9)
DGUY's Avatar
Thanks guys for the tips. Y'all have given me some ideas.
Derrick
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
