~~SIG Brotherhood ~~
#3852
That 4* is SOOOOO cool!!!!!!!!! You've done a lot of work on that - well done indeed!!!!!!!!!!!!!!!!! The guy at the field was right - hard to believe that's a lowly 4* standing there.
It looks like you've done something rather interesting on the landing gear. Might we see of pic of just how you did that?
#3853
#3854
I finally did it. After spending the past couple of weeks getting comfortable with the Kadet Jr, I dared a maiden flight on the Aerosportster. The little Fox .15 BB provided enough power to drag it into the air before it went to far off the edge of the runway and into the mud pit. After a coupe seconds of frantic control inputs and clearing the tree tops it took 5 clicks right aileron and 3 clicks up elevator to get it predictable. I can't say handsoff, this little thing wants to go everywhere but where you leave it. Loops are nice and round, rolls not exactly axial, but easily done. Then the landings...it slows down surprisingly easy. I fell behind the power curve on both landings and ended up pancaking short of the 'good' runway. Got away with a little mud on the tips and a loose gear mount but it was ugly to watch. I think the gear mount will be an easy fix. Improving the runway will take some time.
skylark-flier (05-07-2021)
#3856
Shoot! To me, this looks like a GOOD day.
You're in one piece.
Plane's in one piece.
Field is still available.
GOOD DAY!!
GOOD DAY!!
#3858
Thanks guys! Yeah, I would have to agree. All in all it was a pretty good day. And, yes. That is the residue of proof dripping off the wing. For some reason that Fox spits brown goo everywhere. Has since the first time I put it on the break-in stand. It runs great though!
#3859
Have you considered putting one of those exhaust extenders on the muffler outlet? It could help keep the slime off the plane, shortening clean up after your last flight.
https://www.dubro.com/collections/mu...27026615&_ss=r
#3860
I have looked at those, and I am doing a Du-bro order soon, so maybe I'll get a couple. But I don't mind the oil slick down the side that much. Once you know how to interpret it, it is like an EKG print out for your engine.
#3862
The basic structure is now complete on my 1/4 clipped wing Cub. Now I have to start the covering. I will use the traditional Hazel Sig scheme but use a dark red as the base color with gold stripes. I will start on the wings and the ailerons as I want to paint the interior of the fuselage. I am leaning toward white but might switch to gray.
capt1597 (05-09-2021)
#3863
Another Kougar CG question
Hi guys
I’ve read a ton of forums about balancing a Sig Kougar but none have told me if I should balance at the wingtips with the plane upside down or right side up.
I know it’s 1/2 inch from the LE at the wing tips.
Only answer if you KNOW the answer-
im not interested in hearing stuff like 30% of wing cord or “Look at the plans” or “Go to Sig” or “I used to have one that flew great but I don’t know the CG.”
I just want a legitimate answer from someone who is currently flying one.
Thank you
Thank you
#3864
Hi guys
Thank you
Thank you
#3866
Use a Vanessa rig to balance it. This way you can sight down from wing tip to wing tip and get the most accurate balance you can. The VR, if you don't know about it, uses a plumb bob, and points to the balance point of the plane. Probably the best tool I have ever come across. Vanessa c.g. Rig: How to.
#3868
If you could be so kind to add me to the Sig Brotherhood. I have flown Kadets on and off for 40 years and I just added a Kavalier to the fleet.
I finished my winter project, a Sig Kavalier, and all I can say is "Wow" what a great kit and flying airplane! This was my first build in 20 years. I planned the construction and modifications for months before I started, and built it in two months time; a record for me and it turned out beautiful. I converted it to a taildragger with split elevators joined by a control horn, and I have the rudder extended down to the fuselage bottom. I took out most dihedral and installed two aileron servos. I stopped the ailerons one rib bay short of the wingtip (no flutter). Put a OS.46 up front, installed the servos towards the rear of the compartment and it balanced perfectly without adding weight. It came in at 5.5 lbs.
I just put 5 flights on it and it flys great. Rock solid and flies on rails just like others describe. The OS.46 is the perfect match for it. I will try to add photos when I am able.
Thank you Sig for still being there for us builder/flyers!
#3870
For sure - gotcha logged with #219. Welcome to the SIG Brotherhood!!
Yeah, I'm with you - nice to see SIG back on their feet and producing again. It's been awhile.
SO! Here's the SIG B'hood, as I've got us today:
1 - Hazel & Glenn Sigafoose
2 - Maxey Hester & the team
3 - acdii
4 - RCKen
5 - DGUY
6 - DBD1
7 - fix-n-fly
8 - foodstick
9 - UPF-7
10 - jeffie8696
11 - skyrat71
12 - Leroy Gardner
13 - CanDo
14 - JPMacG
15 - Thunder Chicken
16 - 5skyhawk172
17 - Cutlass 60
18 - Mr-Punk
19 - Sabreryder
20 - eastkurt
21 - FlyerInOKC
22 - rtn9105
23 - oliveDrab
24 - triumphman49
25 - ARUP
26 - willig10
27 - malitape
28 - OLDFLYER2
29 - justin80
30 - Jim Branaum
31 - crawler tech
32 - yel914
33 - ThunderBoat42
34 - sbd-3
35 - Thatsakitbuilt
36 - blw
37 - Mike Gretz
38 - Mako17
39 - Live Wire
40 - deanz406
41 - bchapman
42 - SrTelemaster150
43 - SushiHunter
44 - n8rloves2fly
45 - M_Callahan
46 - carlosponti
47 - xxwolfyxx
48 - landeck
49 - cherokeenut
50 - Mark Thomas
51 - rphiii
52 - n0kjf
53 - cymaz
54 - OldRookie
55 - gosch
56 - ThunderChicken72
57 - lfd47
58 - bikerbc
59 - badger5964
60 - N1EDM
61 - Hfrank
62 - Lowvoltage
63 - US185Damiani
64 - hsukaria
65 - lkruse
66 - Sgt. Meyer
67 - G-JIMG
68 - Hydro Junkie
69 - Twin_Flyer
70 - oldsterling
71 - J T Caldwell
72 - cloudancer03
73 - Super08
74 - Hab
75 - Smashmaster
76 - Rv7garage
77 - Neddy191
78 - JZHANDYMAN
79 - Pete Lane
80 - SIGPlanes
81 - rcmichael
82 - larryshobbies
83 - skyraider71
84 - Hawk570
85 - hogflyer
86 - cubcrasher
87 - chandler_ace
88 - Firewalkerd1
89 - Robin A
90 - GLGofLB
91 - On the Deck
92 - aircraftbuilder67
93 - FJRrider
94 - sdcranford
95 - AMA 74894
96 - W7APD Alan
97 - bobsrc
98 - kiwi4
99 - Flight Risk
100 - G.Barber
101 - I_Fly
102 - scaleforlife
103 - balsatermite
104 - 3136
105 - rc56
106 - R/C Addiction
107 - Fly North
108 - JFS737
109 - skylark-flier
110 - rdgettler
111 - allamericanflyer
112 - MartyPetriSr
113 - tribalturtle2
114 - Soboflyer
115 - jollyroger
116 - Captcrunch44
117 - 19wingwalker48
118 - tzlaser44
119 - larscato
120 - TomCrump
121 - guido
122 - RMeadows
123 - Old_RC_Guy
124 - TheComputerGeek
125 - hook57
126 - newbiedc
127 - PipeMajor
128 - RDJeff
129 - ABORH
130 - danpos
131 - mscic-RCU
132 - Cycotravlr
133 - aggieman
134 - Renegade
135 - bodybuildr
136 - SigSenior
138 - mike 71
139 - merto31
140 - thobin
141 - numb3rulz
142 - Gary in Fla
143 - VincentJ
144 - RICKSTUBBZ
145 - EJWash1
146 - BigTeeEldorado
147 - Aquila1954
148 - jwharkinz
149 - TCraft Lover
150 - Pork Chop
151 - drube
152 - trainermaster80
153 - samklem
154 - tkametz
155 - Vinnie6
156 - budof561
157 - RKRick
158 - leojzamboni
159 - sgtmonte
160 - smallrc
161 - daywalker
162 - angel asenjo
163 - Jeff Spicoli
164 - themutsnutz
165 - mvarzoni
166 - Big Stikflyer
167 - gutmark
168 - knuckleball
169 - capt. crunch jr.
170 - flygilmore
171 - Yasbush
172 - cardinalflyer
173 - bbrowncods
174 - pmoen70
175 - GSXR1000
176 - Comper
177 - stinsonsr9
178 - scale buff
179 - F4 Phantom blue angles
180 - OKC_Jim
181 - bigtj10
182 - Mrotar
183 - fcf
184 - ursharkfuel
185 - fredvon4
186 - Brendon.Gunnell
187 - JulianF25
188 - SailplaneJunkie
189 - GUS THE I.A.
190 - do335a
191 - Patrick R.
192 - sterbejj
193 - daniberry
194 - ETpilot
195 - 442dave
196 - Mwt5086
197 - VooDooBlade
198 - Major Crunch
199 - eihoward
200 - aspeed
201 - bufa
202 - Corsair013
203 - Airacobra
204 - tmaxx1701
205 - Beibitoi
206 - TomM
207 - GameEngineer
208 - khodges
209 - TimJohansen
210 - Deans
211 - JIMHI
212 - Outrider6
213 - smilam
214 - fstevenj
215 - andy.lawler-AT-hotmail-DOT-com
216 - PopeyeCharlotte
217 - BaltimoreBomber
218 - Bigshark
219 - kbuch
#3872
3 - acdii
4 - RCKen
5 - DGUY
6 - DBD1
7 - fix-n-fly
8 - foodstick
9 - UPF-7
10 - jeffie8696
11 - skyrat71
12 - Leroy Gardner
13 - CanDo
14 - JPMacG
16 - 5skyhawk172
17 - Cutlass 60
18 - Mr-Punk
19 - Sabreryder
20 - eastkurt
21 - FlyerInOKC
22 - rtn9105
23 - oliveDrab
24 - triumphman49
25 - ARUP
26 - willig10
27 - malitape
28 - OLDFLYER2
29 - justin80
30 - Jim Branaum
31 - crawler tech
32 - yel914
33 - ThunderBoat42
34 - sbd-3
35 - Thatsakitbuilt
36 - blw
37 - Mike Gretz
38 - Mako17
39 - Live Wire
40 - deanz406
41 - bchapman
43 - SushiHunter
44 - n8rloves2fly
45 - M_Callahan
46 - carlosponti
47 - xxwolfyxx
48 - landeck
49 - cherokeenut
50 - Mark Thomas
51 - rphiii
52 - n0kjf
53 - cymaz
54 - OldRookie
55 - gosch
57 - lfd47
58 - bikerbc
59 - badger5964
60 - N1EDM
61 - Hfrank
62 - Lowvoltage
63 - US185Damiani
64 - hsukaria
65 - lkruse
66 - Sgt. Meyer
67 - G-JIMG
68 - Hydro Junkie
69 - Twin_Flyer
70 - oldsterling
71 - J T Caldwell
72 - cloudancer03
73 - Super08
74 - Hab
75 - Smashmaster
76 - Rv7garage
77 - Neddy191
78 - JZHANDYMAN
79 - Pete Lane
80 - SIGPlanes
81 - rcmichael
82 - larryshobbies
83 - skyraider71
84 - Hawk570
85 - hogflyer
86 - cubcrasher
87 - chandler_ace
88 - Firewalkerd1
89 - Robin A
90 - GLGofLB
91 - On the Deck
93 - FJRrider
94 - sdcranford
95 - AMA 74894
96 - W7APD Alan
97 - bobsrc
98 - kiwi4
99 - Flight Risk
100 - G.Barber
101 - I_Fly
102 - scaleforlife
103 - balsatermite
104 - 3136
105 - rc56
106 - R/C Addiction
107 - Fly North
108 - JFS737
109 - skylark-flier
110 - rdgettler
112 - MartyPetriSr
113 - tribalturtle2
114 - Soboflyer
115 - jollyroger
116 - Captcrunch44
118 - tzlaser44
119 - larscato
120 - TomCrump
121 - guido
122 - RMeadows
123 - Old_RC_Guy
125 - hook57
126 - newbiedc
127 - PipeMajor
128 - RDJeff
129 - ABORH
130 - danpos
131 - mscic-RCU
132 - Cycotravlr
133 - aggieman
134 - Renegade
135 - bodybuildr
136 - SigSenior
138 - mike 71
139 - merto31
140 - thobin
141 - numb3rulz
142 - Gary in Fla
143 - VincentJ
144 - RICKSTUBBZ
145 - EJWash1
147 - Aquila1954
148 - jwharkinz
149 - TCraft Lover
150 - Pork Chop
151 - drube
153 - samklem
154 - tkametz
155 - Vinnie6
156 - budof561
157 - RKRick
158 - leojzamboni
159 - sgtmonte
160 - smallrc
161 - daywalker
162 - angel asenjo
163 - Jeff Spicoli
164 - themutsnutz
165 - mvarzoni
166 - Big Stikflyer
167 - gutmark
168 - knuckleball
170 - flygilmore
171 - Yasbush
172 - cardinalflyer
173 - bbrowncods
174 - pmoen70
175 - GSXR1000
176 - Comper
177 - stinsonsr9
178 - scale buff
180 - OKC_Jim
181 - bigtj10
182 - Mrotar
183 - fcf
184 - ursharkfuel
185 - fredvon4
187 - JulianF25
189 - GUS THE I.A.
190 - do335a
191 - Patrick R.
192 - sterbejj
193 - daniberry
194 - ETpilot
195 - 442dave
196 - Mwt5086
197 - VooDooBlade
198 - Major Crunch
199 - eihoward
200 - aspeed
201 - bufa
202 - Corsair013
203 - Airacobra
204 - tmaxx1701
205 - Beibitoi
206 - TomM
207 - GameEngineer
208 - khodges
209 - TimJohansen
210 - Deans
211 - JIMHI
212 - Outrider6
213 - smilam
214 - fstevenj
218 - Bigshark
219 - kbuch
-Matt
capt1597 (05-17-2021)
#3874
By the way, I want to see the plane that the wing section above the P-51 is destined for. That's GOTTA be an interesting airframe.
And so, once again, the SIG Brotherhood, as I've got us today:
3 - acdii
4 - RCKen
5 - DGUY
6 - DBD1
7 - fix-n-fly
8 - foodstick
9 - UPF-7
10 - jeffie8696
11 - skyrat71
12 - Leroy Gardner
13 - CanDo
14 - JPMacG
16 - 5skyhawk172
17 - Cutlass 60
18 - Mr-Punk
19 - Sabreryder
20 - eastkurt
21 - FlyerInOKC
22 - rtn9105
23 - oliveDrab
24 - triumphman49
25 - ARUP
26 - willig10
27 - malitape
28 - OLDFLYER2
29 - justin80
30 - Jim Branaum
31 - crawler tech
32 - yel914
33 - ThunderBoat42
34 - sbd-3
35 - Thatsakitbuilt
36 - blw
37 - Mike Gretz
38 - Mako17
39 - Live Wire
40 - deanz406
41 - bchapman
43 - SushiHunter
44 - n8rloves2fly
45 - M_Callahan
46 - carlosponti
47 - xxwolfyxx
48 - landeck
49 - cherokeenut
50 - Mark Thomas
51 - rphiii
52 - n0kjf
53 - cymaz
54 - OldRookie
55 - gosch
57 - lfd47
58 - bikerbc
59 - badger5964
60 - N1EDM
61 - Hfrank
62 - Lowvoltage
63 - US185Damiani
64 - hsukaria
65 - lkruse
66 - Sgt. Meyer
67 - G-JIMG
68 - Hydro Junkie
69 - Twin_Flyer
70 - oldsterling
71 - J T Caldwell
72 - cloudancer03
73 - Super08
74 - Hab
75 - Smashmaster
76 - Rv7garage
77 - Neddy191
78 - JZHANDYMAN
79 - Pete Lane
80 - SIGPlanes
81 - rcmichael
82 - larryshobbies
83 - skyraider71
84 - Hawk570
85 - hogflyer
86 - cubcrasher
87 - chandler_ace
88 - Firewalkerd1
89 - Robin A
90 - GLGofLB
91 - On the Deck
93 - FJRrider
94 - sdcranford
95 - AMA 74894
96 - W7APD Alan
97 - bobsrc
98 - kiwi4
99 - Flight Risk
100 - G.Barber
101 - I_Fly
102 - scaleforlife
103 - balsatermite
104 - 3136
105 - rc56
106 - R/C Addiction
107 - Fly North
108 - JFS737
109 - skylark-flier
110 - rdgettler
112 - MartyPetriSr
113 - tribalturtle2
114 - Soboflyer
115 - jollyroger
116 - Captcrunch44
118 - tzlaser44
119 - larscato
120 - TomCrump
121 - guido
122 - RMeadows
123 - Old_RC_Guy
125 - hook57
126 - newbiedc
127 - PipeMajor
128 - RDJeff
129 - ABORH
130 - danpos
131 - mscic-RCU
132 - Cycotravlr
133 - aggieman
134 - Renegade
135 - bodybuildr
136 - SigSenior
138 - mike 71
139 - merto31
140 - thobin
141 - numb3rulz
142 - Gary in Fla
143 - VincentJ
144 - RICKSTUBBZ
145 - EJWash1
147 - Aquila1954
148 - jwharkinz
149 - TCraft Lover
150 - Pork Chop
151 - drube
153 - samklem
154 - tkametz
155 - Vinnie6
156 - budof561
157 - RKRick
158 - leojzamboni
159 - sgtmonte
160 - smallrc
161 - daywalker
162 - angel asenjo
163 - Jeff Spicoli
164 - themutsnutz
165 - mvarzoni
166 - Big Stikflyer
167 - gutmark
168 - knuckleball
170 - flygilmore
171 - Yasbush
172 - cardinalflyer
173 - bbrowncods
174 - pmoen70
175 - GSXR1000
176 - Comper
177 - stinsonsr9
178 - scale buff
180 - OKC_Jim
181 - bigtj10
182 - Mrotar
183 - fcf
184 - ursharkfuel
185 - fredvon4
187 - JulianF25
189 - GUS THE I.A.
190 - do335a
191 - Patrick R.
192 - sterbejj
193 - daniberry
194 - ETpilot
195 - 442dave
196 - Mwt5086
197 - VooDooBlade
198 - Major Crunch
199 - eihoward
200 - aspeed
201 - bufa
202 - Corsair013
203 - Airacobra
204 - tmaxx1701
205 - Beibitoi
206 - TomM
207 - GameEngineer
208 - khodges
209 - TimJohansen
210 - Deans
211 - JIMHI
212 - Outrider6
213 - smilam
214 - fstevenj
218 - Bigshark
219 - kbuch
220 - Flyboywbl
221 - Scale only 4 me
#3875
My Feedback: (158)
Another project not yet completed,,, maybe some day,, Scratch built CL-415 (Only a 12 year break)
Scout build thread here if interested https://www.rcgroups.com/forums/show...Champion-Scout
