Reload this Page >
Balsa USA Brotherhood
Old 08-10-2015, 04:33 PM
  #1076
jeffEE
jeffEE's Avatar
this is a place you might want to look at. http://home.cablerocket.com/~scaleribstitch/id16.htm
Old 08-10-2015, 06:02 PM
  #1077
s3nfo
My Feedback: (14)
I used thin glue lines from a plastic squeeze bottle with a very tiny hole from the Martha Stewart collection of artsy craftsy stuff at Micheals. Took me less that 2 hours to do the rib stitches on the wings and tailplane on my Ziroli Stearman.
Old 08-14-2015, 03:45 AM
  #1078
3136
3136's Avatar
Originally Posted by adec4
g'day all
have any of you boys got an easy way to do scale rib stitching please for my BUSA stearman ??
I TRHINK IM GOING TO GO STIR CRAZY TRYING TO PUT A COUPLE OF THOUSAND STITCHES ON BY HAND
PLEASE HELP IM DESPERATE (
regards adec
Sorry mate, I don't have any pics.
What I did was got a bit of plywood and marked out the intervals of what stitching I wanted then drilled and put in nails on the left and right sides of the board.
So you have a line of nails going vertically up and down on the left and another set on the right.
Then in the middle space stick down some masking tape to cover the entire area.
Then tie some string at the top left nail, run it to the right, down one nail and back to the left.
So you basically have a pattern of evenly spaced horizontal lines of string sitting on top of the masking tape.
Then use wood glue to stick the string to the tape, let dry well.
Cut with a very sharp knife vertically strips the width you want.
Sick down on the wing then iron a wider strip over the top of solartex.
Then you end up with simulated stitching and the covering tape.
Let me know if it doesn't make sense, I'll draw some pics.
Old 08-14-2015, 05:49 AM
  #1079
capnpaul
capnpaul's Avatar
This is the method 3136 is talking and the method i use. You will have rib stitching coming out your ears
https://www.youtube.com/watch?featur...&v=gb1lz7ZrOqw
Old 08-14-2015, 06:18 AM
  #1080
foodstick
foodstick's Avatar
Here is what I do for a standoff scale rib stitching.. I do painting and weathering with water based acrylic paints on the covering.. then I lightly clear them with rustoleum clear. Once I have my wings painted.
1. I lay a piece of masking tape down the ribs the right width for wing tape..
2. I spray a slightly darker color of paint down the tape.. I use thinned acrylic paint in my airbrush (VEGA 2000 love it) this shades the sides of the tape and when you take the tape off it makes the strip look lifted off the wing.
3. Now I take a lighter colored chalk and draw some angled short lines across the rib tape area.. I do light over darker colors.. and darker STITCHES over light areas like the white on roundels and insignias. This simulates highlights, or shadows. I will add I don't usually use white chalk for this. When you use white chalk it disappears almost completely when cleared. You have to lay on typical white chalk HEAVY to make it apparent after a clear coat.
4. Then since I fly mainly electric and GASOLINE motors I topcoat with two light dusting coats of Rustoleum clear.. I DO NOT lay on a wet coat that flows out. This leaves it flatter and I have had no problems so far.
Maybe you will like the look and give it a try. I am just glad I have found ways over the years in this hobby to use some of my art skills ... heaven knows painting on canvas will never put money on my table !
ID:	2114349   Click image for larger version
Old 08-14-2015, 07:31 AM
  #1081
FlyerInOKC
FlyerInOKC's Avatar
Has anyone in the brotherhood built the Balsa USA Excalibur kit of late? I am in a nostalgic mood but I don't want to start a long term build like a WWI scale airplane right now.
Old 08-18-2015, 04:05 AM
  #1082
wildbills21
Flyboy077,
I made mine all out of bass, it has really held up well. That was until it fell off the shelf and landed on the Ural, Now it is epoxied and wrapped about two times with Duct tape. The problem with the balsa on the top and bottoms is when you land a little more on the left or right wheel the sub wing flexes. Your not the first, we are working on a solution. Just think if they had Duct tape around in the WWI era.
Wild Bill
Old 08-18-2015, 06:20 AM
  #1083
wildbills21
Oh, I almost forgot. I am looking for a built 1/3 scale D7. After watching the 4 D7 formation flight in Fond du lac this past weekend I have got to have one. I normally build all my planes but I have 3 projects going on and no time for at least a couple of years to build one. BUSA has a house 1/3 scale D7 that I fly but when the fun starts the boss gets to fly it.
Wild Bill
Old 08-18-2015, 10:15 AM
  #1084
jeffEE
jeffEE's Avatar
Boy I hope somebody got a bit of video of the DVII flight.
Old 08-18-2015, 02:17 PM
  #1085
spadsriver09
Wild Bill,
I don't know what could have made those flights any cooler, except for maybe some pyrotechnic effects on the ground or in-flight video which I had a go-pro mount made but did not have another SD card to put in the camera. Great flying with you and Mark!
Lee
Old 08-21-2015, 07:51 AM
  #1086
RDJeff
Please add my name to the brotherhood! I recently built a Stick .40 Plus, powered by a PAW .40 diesel. I liked it so much that I picked up a Stingray 120, powered it with a DLE 20, and just finished the build yesterday. Pictures to follow! Thanks,
Jeff
Old 08-21-2015, 03:54 PM
  #1087
jwrich
My Feedback: (17)
jwrich's Avatar
Welcome Jeff, we will be watching for your pictures. Tell us a little bit about flying in Alaska, I would think you have a lot of building time.
It would be helpful for me if all BUSA Brothers would post their BUSA Brotherhood number in their signature. If I have missed anyone please let me know.
BUSA brothers
#1 Jwrich OK USA
#2 Jeffo MI USA
#3 ARUP KY USA
#4 RCKen OK USA
#5 mattnew MA USA
#6 surmovik60 VA USA
#7 GerKonig PA USA
#8 Granpooba NY USA
#9 radfordc KS USA
#10 balsa brain FL USA
#11 3136 Victoria Austrialia **
#12 wwoneguy MD USA
#13 vertical grimmace CO USA
#14 rcmiket TX USA
#15 bpoates25 FL USA
#16 PiperDriver IL USA
#17 68goat AL USA
#18 jlsimon NJ USA
#19 pat s NC USA
#20 pending IN USA
#21 Steve Percifield IN USA
#22 opol MN USA
#23 Zero TX USA
#24 tonyos VA USA
#25 b206 IL USA USA
#26 LonnieMcc MS USA
#27 eindecer3 TN USA
#28 flyer35 NY USA
#29 jeffEE MN USA
#30 s3nfo CA USA
#31 Kwikfli KS USA
#32 JDHammer PA USA
#33 Ikruse OK USA
#34 bobbailey VA USA
#35 Vampire PA USA
#36 zemkes_wolfpack IN USA
#37 triumphman49 AL USA
#38 SRQFlyer FL USA
#39 Daniel-EL OH USA
#40 hairy46 WY USA
#41 pettit NC USA
#42 Hrannar Iceland **
#43 lowbubba OH USA
#45 FokkerD7 OH USA
#44 FireBee VA USA
#46 iampilot2 OH USA
#47 Wagon1 FL USA
#48 darren 4 WI USA
#49 Luxuswaffe FL USA
#50 dryverman VT USA
#51 otterrc FL USA
#52 cooper998 DE USA
#53 lazyace NY USA
#54 wings2an3 NY USA
#55 the pamster TX USA
#56 lucasar15 PA USA
#57 AMA74894 MN USA
#58 squidman TX USA
#59 M_Callahan OH USA
#60 Karp050555 PA USA
#61 optech CA USA
#62 ashby NSW Australia **
#63 R/C Art IN USA
#64 on_your_six MD USA
#65 Highflyer2 GA USA
#66 dddaviddean NJ USA
#67 Quagmire CA USA
#68 pending CA USA
#69 ratshooter TX USA
#70 TXAG96 MI USA
#71 R/C Ray NY USA
#72 feep NH USA
#73 sdcranford MO USA
#74 buzzard bait NY USA
#75 chadasmus KY USA (BUSA Team Pilot, Builder and Designer)
#76 fokv25 IN USA
#77 Dynamic! WI USA
#78 WinterHawke WI USA
#79 t6racer NSW Australia **
#80 NM2K GA USA
#81 rcjunky67 FL USA
#82 AndyF IN USA
#83 freefall2907 IA USA
#84 a65l VA USA
#85 Grimracer IL USA
#86 Corsair2013 UT USA
#87 Chevelle NY USA
#88 eagledancer FL USA
#89 Leroy Gardner ID USA
#90 ANZAC Australia **
#91 Spadsriver09 IN USA
#92 PSB OH USA
#93 bradpaul FL USA
#94 MRadu CA USA
#95 HPA OH USA
#96 Shoestring MN USA
#97 David Gladwin United Kingdom **
#98
Rich6170 OH USA
#99 Wildbills21 MI USA (Team BUSA pilot, builder and the chief mechanic)
#100 Rickj OH USA
#101 Geezeraviation TX USA
#102 Flyboy077 OH USA
#103 Shelstrm WI USA
#104 Drude FL USA
#105 bschatz CA USA
#106 RCDuffer CA USA
#107 capnpaul Orillia, ON, Canada **
#108 p38nut IN, USA
#109 yoda64 VA, USA
#110 Jaybird ME, USA
#111 mbnt IL, USA
#112 Foodstick (Lance) IA, USA
#113 adec Perthaustralra, Australia **
#114 Navy Orange Park, FL, USA
#115 RD Jeff, Anchorage, AK, USA
Jeff, you have been added to the Brotherhood
Fair Winds and Happy Flyin'
Rich
Old 09-02-2015, 03:32 PM
  #1088
mistral12
Like to join but I don't think I can even get off the ground. Just finish building 1/4 BUSA sopwith pup but boy I must be a poor builder. I used coverall and dope with paint, build custom landing gear with bungee shocks, steerable tail "stick" and flying wire and powered with Zenoah ZP26 with electronic ig. THe bad news it took almost 4lbs of lead in the front and the planes weights 18lbs Should I even try to fly this concrete brick? Any advise would be great !
Old 09-02-2015, 03:59 PM
  #1089
foodstick
foodstick's Avatar
it should fly
My 1/4 D7 weighs 6 pounds more than that and flies great ... Your plane has a lot more wing.... Also I think Balsa USA is real generous on the CG.. so if it doesn't slow down and flare nice at the end..start taking a little weight out each flight until you find the better CG location.
Old 09-02-2015, 06:17 PM
  #1090
s3nfo
My Feedback: (14)
Only one way to find out, start that sucker up and let 'er rip. Bet it flies fine!
Old 09-02-2015, 06:31 PM
  #1091
sdcranford
My 1/4 scale SW5a from BUSA has 3-4 lbs in the nose and flies great. Just fly it.
Old 09-02-2015, 08:04 PM
  #1092
R/C Art
My Feedback: (38)
R/C Art's Avatar
If I remember correctly, my old 1/4 scale Pup weighed about 14 lbs ready to fly. After flying it a while I added nearly 3 lbs to the firewall to get it flying more scale like. Power was a G23. I don't think you will have any trouble...... the air frame will carry the weight just fine.
Old 09-03-2015, 03:06 AM
  #1093
geezeraviation
geezeraviation's Avatar
At 18# its a tad under 21 oz per sq ft. why wouldn't it fly. My 1/4 N28 weighs 16 1/2# these days and flies fine at almost 24 oz per sq ft. with an old Zen G23.
Old 09-05-2015, 01:32 PM
  #1094
3136
3136's Avatar
I beefed up heaps of things in my 1/4 pup build which in hindsight was silly, mine is 20lb and flies just fine.
Old 09-06-2015, 07:13 AM
  #1095
jeffEE
jeffEE's Avatar
If the CG is correct, then it will fly just fine.
Old 09-15-2015, 11:21 AM
  #1096
JKEpps
JKEpps's Avatar
Can I get in too? Looking to finish up my BUSA 1/3 scale D.VII. Build thread:
http://www.rcuniverse.com/forum/gian...vii-build.html
I also have a BUSA 1/3 scale Ercoupe to finish. Build thread:
http://www.rcuniverse.com/forum/gian...3-ercoupe.html
Last but not least, I bought, but have yet to begin working on, a BUSA 1/3 scale Albatros D5. I'll create a build thread when I start that one, but it won't be any time soon, if even this year, Too many other projects to finish first.
Old 09-15-2015, 06:19 PM
  #1097
jwrich
My Feedback: (17)
jwrich's Avatar
Mistral 12, sorry I didn't see that you wanted to join the brotherhood. I have the 1/4 scale Sopwith Pup also with a very old G 23 and it flys great. Maybe you can post a picture of your Pup, we all would like to see it. Don't worry I am sure it will fly well.
You are now a member of the Balsa USA Brotherhood!
BUSA brothers
#1 Jwrich OK USA
#2 Jeffo MI USA
#3 ARUP KY USA
#4 RCKen OK USA
#5 mattnew MA USA
#7 GerKonig PA USA
#8 Granpooba NY USA
#9 radfordc KS USA
#12 wwoneguy MD USA
#14 rcmiket TX USA
#17 68goat AL USA
#18 jlsimon NJ USA
#19 pat s NC USA
#20 pending IN USA
#22 opol MN USA
#23 Zero TX USA
#24 tonyos VA USA
#25 b206 IL USA USA
#28 flyer35 NY USA
#29 jeffEE MN USA
#30 s3nfo CA USA
#31 Kwikfli KS USA
#32 JDHammer PA USA
#33 Ikruse OK USA
#35 Vampire PA USA
#38 SRQFlyer FL USA
#40 hairy46 WY USA
#41 pettit NC USA
#43 lowbubba OH USA
#45 FokkerD7 OH USA
#44 FireBee VA USA
#47 Wagon1 FL USA
#48 darren 4 WI USA
#51 otterrc FL USA
#53 lazyace NY USA
#57 AMA74894 MN USA
#58 squidman TX USA
#61 optech CA USA
#63 R/C Art IN USA
#67 Quagmire CA USA
#68 pending CA USA
#70 TXAG96 MI USA
#71 R/C Ray NY USA
#72 feep NH USA
#76 fokv25 IN USA
#77 Dynamic! WI USA
#80 NM2K GA USA
#82 AndyF IN USA
#84 a65l VA USA
#87 Chevelle NY USA
#92 PSB OH USA
#93 bradpaul FL USA
#94 MRadu CA USA
#95 HPA OH USA
#98
Rich6170 OH USA
#100 Rickj OH USA
#104 Drude FL USA
#105 bschatz CA USA
#108 p38nut IN, USA
#109 yoda64 VA, USA
#111 mbnt IL, USA
#116 Mistral 12 Granbury TX, USA
Fair winds and happy flyin'
Rich
Old 09-15-2015, 06:26 PM
  #1098
jwrich
My Feedback: (17)
jwrich's Avatar
JKEpps, I checked out your construction thread on the Fokker D VII, I signed on and will be following your progress. You are now a member of the Balsa USA Brotherhood, welcome, feel free to post your advice and a picture of your work.
BUSA brothers
#1 jwrich, Enid, OK, USA
#2 Jeffo MI USA
#3 ARUP KY USA
#4 RCKen OK USA
#5 mattnew MA USA
#7 GerKonig PA USA
#8 Granpooba NY USA
#9 radfordc KS USA
#12 wwoneguy MD USA
#14 rcmiket TX USA
#17 68goat AL USA
#18 jlsimon NJ USA
#19 pat s NC USA
#20 pending IN USA
#22 opol MN USA
#23 Zero TX USA
#24 tonyos VA USA
#25 b206 IL USA USA
#28 flyer35 NY USA
#29 jeffEE, Farnington, NM USA
#30 s3nfo CA USA
#31 Kwikfli KS USA
#32 JDHammer PA USA
#33 Ikruse OK USA
#35 Vampire PA USA
#38 SRQFlyer FL USA
#40 hairy46 WY USA
#41 pettit NC USA
#43 lowbubba OH USA
#45 FokkerD7 OH USA
#44 FireBee VA USA
#47 Wagon1 FL USA
#48 darren 4 WI USA
#51 otterrc FL USA
#53 lazyace NY USA
#57 AMA74894 MN USA
#58 squidman TX USA
#61 optech CA USA
#63 R/C Art, Shelbyville, IN, USA
#67 Quagmire CA USA
#68 pending CA USA
#70 TXAG96 MI USA
#71 R/C Ray NY USA
#72 feep NH USA
#76 fokv25 IN USA
#77 Dynamic! WI USA
#80 NM2K GA USA
#82 AndyF IN USA
#84 a65l VA USA
#87 Chevelle NY USA
#92 PSB OH USA
#93 bradpaul FL USA
#94 MRadu CA USA
#95 HPA OH USA
#98
Rich6170 OH USA
(Team BUSA pilot, builder,& chief mechanic)
#100 Rickj OH USA
#101 Geezeraviation, Houston, TX, USA
#104 Drude FL USA
#105 bschatz CA USA
#108 p38nut IN, USA
#109 yoda64 VA, USA
#111 mbnt IL, USA
#113 adec, Perthaustralra, Australia **
#114 Navy, Orange Park, FL, USA
#116 Mistral 12, Granbury, TX, USA
#117 JKEpps, Greenbelt, MD, USA
Rich
Old 09-15-2015, 06:50 PM
  #1099
JKEpps
JKEpps's Avatar
Awesome! Thanks!
Old 09-16-2015, 06:50 AM
  #1100
FlyerInOKC
FlyerInOKC's Avatar
Rich can I talk you out of a number?
