Precedent Stampe SV4B Muffler
I noticed several build logs for this kit, I happen to own one too.
Earlier I had to modify the Evolution muffler to get it through our strict club noise limit. One exit pipe had to be blocked off and this was enough to get it to pass.
I was thinking on how to do a scale exhaust with an Evolution 33gx that is installed in mine. Then it hit me......
If I permanently block off the exit pipe then I can make an extension for the other pipe...
the pipe with the tape will be cut off and blocked up and welded.
this pipe will be cut to length (the faint mark is at the bottom) and brazed to this...
it will be all brazed together, sometime
