Reload this Page >
G&L 1/5 DHC chipmunk - diary of a build.
Old 09-06-2014, 12:45 PM
  #676
Zor
Banned
Originally Posted by TonyBuilder View Post
Blue text inserted by Zor.
I know that the antennas are to be at 90 degrees of each other.
For readers . . . Antennas can be at 90 deg in the same plane.
The best is to be at 90 deg in two planes that are also at 90 deg.
I have always ignored that and just install the receiver in the fuselage. I have never had a problem and with Futaba I feel confident.
When flying aerobatics the model is usually well within a strong radiated field.
It has to be close enough to clearly see its attitude and response to controls.
I will do a series of range testing and so on. I did not have the room to have both antennas come all the way out and at 90 digress.
The two antennas are already all the way out. We can see the ends of the coaxial lines outside the fuselage. All that is needed is their relative orientation. Where they are coming out is fine.
Futaba for carbon fiber recommends just the tips of the antennas to be out side of the fuselage so we will see. The second receiver will have the antennas in the second pilots cockpit.
Not only the tips of the antennas have to be out; the whole antennas ( 1/4 wave length; a bit more than 1 ( one ) inch ) has to be out. They are all out in the pictures. The coaxial lines ( transmission lines ) can be inside since their shields are grounded.
TB
Tony,
I will gladly remove this post if you feel inappropriate.
I am just thinking about all the readers out there.
The antennas do not originate at the receiver case; they are at the ends of the coaxial transmission lines.
Zor
Old 09-06-2014, 01:09 PM
  #677
TonyBuilder
TonyBuilder's Avatar
Rivets
I am getting a start on the right bottom half of the wing.
I needed more rivets so I asked Chad to print up some white ones.
This should cover better then the gray or silver. I am not doing weathering so I don't need silver.
With this Klass Kote primer the rivets apply much better. I haven't had one pull up yet. It was a struggle at times on the fuselage.
The stitching should do better to. On the elevator and ruder some of the ends of the stitching lifted when I was painting.
Should go pretty quick and far as the rivets go, the stitching and glue drops will take a bit more time.
TB
ID:	2029548   Click image for larger version
Old 09-06-2014, 01:11 PM
  #678
TonyBuilder
Originally Posted by Zor View Post
Tony,
Zor
Zor, your good. I don't know much about this stuff myself, so print on.
TB
Old 09-06-2014, 06:41 PM
  #679
Zor
Banned
Default Last post about antennas
Zor,
TB
Tony and all the multitude of readers,
I do not intend to get this wonderful thread out of topic but I thought that after all this wonderful work you are doing ( including rivets and stitches ) that you would wish the best and most reliable radio link with your airplane.
From where the antennas are coming out of the fuselage _ _ _ imagine two flat vertical cardboard making a 45 degrees angle with the longitudinal axis of the fuselage so the two form a 90 deg angle to each other.
You can bend the antennas in the imaginary flat face of these cardboard at about 45 deg toward the tail.
That will make the two antennas 90 deg from each other and in two directions to take advantage of the polarity of the radiated field from your transmitter.
Trying to qualify my competence in this subject _ _ _
Graduated in electronics at Montreal technical School ( a four year course ).
Two years as chief instructor for Radio College of Canada in Montreal, QC.
Twenty years with Radio Corporation of America as application engineer.
Introduced 'General Radio Service in Canada' ( so called 'Citizen's band) while with RCA.
Amateur radio operator ( so called Ham ) since 1946 and still active.
Attached pics of some of my reference on hand.
I will not post more on antennas unless you have some specific questions.
I am just hoping that your most beautiful and detailed model will have the best radio link possible.
Best 2 U,
Zor
Name:	R 100_7357.jpg
ID:	2029720   Click image for larger version
Name:	R 100_7358.jpg
Old 09-06-2014, 07:06 PM
  #680
Leroy Gardner
Tony Chad's rivets look real good and you make them look better the way your laying them out, nice work.
Leroy
Old 09-07-2014, 02:23 AM
  #681
TonyBuilder
Leroy
Thanks Leroy, Chad's rivets are really great. They pick up really good and lay just as well especially on this KK primer, I haven't had one rivet lift even when I lay tape over existing rivets.
The nice thing about Chad's rivets is the flexibility. Any color, any size, any spacing. I chose white so the yellow would cover.
I am learning a lot about finishing. These rivets will simulate raised rivets if you paint them heavy. I think making them look like flush rivets is harder and requires a lighter coat of paint.
I love your aluminum rivets, just cant see me doing 30k of those The vinyl rivets are so easy it not even funny.
TB
Old 09-07-2014, 02:33 AM
  #682
TonyBuilder
So while we are talking about rivets. I have heard from past Top Gun competitors that you cant compete (with the big boys) in Top Gun using vinyl rivets. And that your panel lines need to be bigger then scale. It has to do with how they see them, I have been told.
I disagree with this and feel that a plane should look as scale as it can even up close and that if you cant see the detail from far away then you are doing your job. I don't know how they judge these competition or who is judging them. Vinyl rivets and panel lines done right in my opinion look more scale then some of the other old school techniques.
Anyways viva sports scale
TB
Old 09-07-2014, 02:35 AM
  #683
TonyBuilder
On the bench for today, more rivets on the wing, rivets and more rivets, glue drops and rivets. Might go fly if the weather turns.
TB
Old 09-07-2014, 06:54 AM
  #684
TonyBuilder
So Zor what you are saying the best configuration is to have one antenna pointing to the noes at a 45• and the other pointing to the tail at a 45• with 1" of the antenna outside the fuselage! Is that correct?
TB
Old 09-07-2014, 07:54 AM
  #685
Leroy Gardner
Not to take away from your build Tony but what Zor said about antenna leads is not the norm for 2.4 reception every since it's inception. Also with the satelite antennas on the 2.4 systems sometimes as many as 3 or 4 located throught the plane it's almost impossible not to get the signals. Air waves will pass through almost anything including our own bodies, ezcluding lead and our planes can hardly create a shield to prevent radio waves from entering their bodies. I guess what I'm saying is that directional antennas do pick up signals better and that is one of the reasons for the satelite antennas on the 2.4 systems because the plane is never in direct alignment to the transmitter. In all, whats the point of a given portion of antennas sticking out of the plane at any point when a good majority of the time it's not going to be facing the transmitter anyway.
Probably not the place to discuss this, it's very debatable to say the least.
Leroy
Old 09-07-2014, 08:18 AM
  #686
acerc
acerc's Avatar
Tony, install your recievers and don't worry about it. I have numerous wrapped in aluminum, which is deadly by some, but things are fine. There are to many openings in our airframes for concern, and the directionality, by installation, always puts the antennas at different angles. Then add in the fact most Rx's have far more strength in signal than we can see to fly. Install them and keep on trucking I say.
Old 09-07-2014, 10:45 AM
  #687
TonyBuilder
Today I brought the chippie out to the field and my mentor gave her a look over. We did series of range tests. With the receiver and antennas as is I could run out as fare as I could with the 90 seconds I get to perform a range test, maybe 200' and everything worked.
The only time I would loos signal is if I put the transmitter behind my body. At 200' I am good. We did tests with the model in all different positions and I even turned the radio off and back on again under the range test mode and still had solid control.
We deemed it good and I will do a range test with the engine running before the test flights.
TB
Old 09-07-2014, 10:51 AM
  #688
Zor
Banned
Default Only to reply to Tony's question.
So Zor
TB
Tony,
The attached sketch shows what I have in mind and what I would do.
I always show or talk about what I would do and I do not tell peoople what they should do.
I also provide reasons for my outlook.
We have read postings from fellows with obviously much more knowledge and experience than I have.
I suggest you do your own evaluation of the postings which should always be done anyway.
I think your Chipmunk will be a fast flier that could get pretty far very quickly and should have the best range regardless of its attitude ( not altitude ) to the incoming radio propagation.
Receivers can be fully shielded ( in grounded metal envelopes ) as long as the antenna(s) are out of the shield to pick up the induced signal. Considerations have to be given to the cooling of the receivers that I think should have free air circulation.
The sketch is in accordance with the work you already have done.
Ideally one antenna should be horizontal and the other vertical when the model is sitting on the ground.
Any more questions ?
Zor
Name:	R 100_7359.jpg
Old 09-08-2014, 02:08 AM
  #689
TonyBuilder
On the bench for today, finish the rivets on the wing, make ready to paint.
TB
Old 09-08-2014, 04:13 AM
  #690
stevegauth30
stevegauth30's Avatar
Even with all your CF,you have no worries my friend. Finish her up and fly her. If you were going to be flying out to 10 or 15 miles fpv, that's a different story.
Old 09-08-2014, 05:54 AM
  #691
FlyerInOKC
FlyerInOKC's Avatar
Looking good TB! Thanks for the antenna information Zor! It's always nice to read stuff like that and have it explained!
Old 09-08-2014, 06:02 AM
  #692
TonyBuilder
The Mornings progress.
Plugging away on the rivets, I got most of the rivets short of some details.
I will be doing the stitching next.
I hope to have the wing done today so I can start on the stencils tomorrow.
TB
ID:	2030145   Click image for larger version
ID:	2030146   Click image for larger version
ID:	2030147   Click image for larger version
ID:	2030148   Click image for larger version
ID:	2030149   Click image for larger version
Old 09-08-2014, 11:55 AM
  #693
TonyBuilder
Wing rivets and stitching.
Got the top of the wing done with all rivets and stitching, short of the glue drops.
It is going to look nice with all that yellow paint on it
I will do the ailerons and flaps before I go to the bottom.
Break time!
TB
Name:	wing top 001.JPG
ID:	2030269   Click image for larger version
Name:	wing top 002.JPG
ID:	2030270   Click image for larger version
Name:	wing top 003.JPG
ID:	2030271   Click image for larger version
Name:	wing top 004.JPG
ID:	2030272   Click image for larger version
Name:	wing top 005.JPG
ID:	2030273   Click image for larger version
Name:	wing top 006.JPG
ID:	2030274   Click image for larger version
Name:	wing top 007.JPG
ID:	2030275   Click image for larger version
Name:	wing top 008.JPG
Name:	wing top 009.JPG
Old 09-08-2014, 12:52 PM
  #694
FlyerInOKC
FlyerInOKC's Avatar
Nice!
Old 09-08-2014, 01:10 PM
  #695
Zor
Banned
Fantastic Tony.
Fabulous.
FANTABULOUS.
Looking for the wires to the navlights _ _ _ ! ! !
Zor
Old 09-08-2014, 04:25 PM
  #696
TonyBuilder
Fantastic Tony.
Fabulous.
FANTABULOUS.
Zor
Not yet, still need to paint the wing first, then servos and nav lights go in!
Soon
TB
Old 09-08-2014, 06:10 PM
  #697
rt3232
Hi guys What is with RCU as I am not getting notefide of post's
cheers Bob T
Old 09-09-2014, 03:32 AM
  #698
TonyBuilder
cheers Bob T
Broken!
TB
Old 09-09-2014, 03:35 AM
  #699
TonyBuilder
Morning progress.
Got the flaps all done and detailed.
The stepping area will get painted black during color overlay detailing.
Ailerons and the bottom of the wing stitching is left to do, then glue drops, should take me all day to do that.
TB
ID:	2030427   Click image for larger version
ID:	2030428   Click image for larger version
ID:	2030429   Click image for larger version
Old 09-09-2014, 05:43 AM
  #700
Zor
Banned
Soon
TB
I was not expecting the navlights; I was looking for the wires which I assumed are already in the wings.
Zor
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service - Do Not Sell My Personal Information
Copyright 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
