Where have all the builders gone
#552
My Feedback: (-1)
A bit of a heads up when gang cutting parts. My wood workers club also stocks a two sided tape, it's used to lay carpet and very strong stuff. It looks like a roll of duct tape and is a bit thick. I used it a few times when I made a big rocking horse and the first part I used it on was the saddle. This was with 1 inch red oak. The big problem came when the part was cut and shaped and it was time to take the parts apart. Did I mention it sticks well?? Like the parts had to be pried apart with thin tools. From then on I knew better and only used a few small pieces on the inside of the cuts for the rest of the horse.
This tape is very good for things like 1/4 inch ply but by no means ever use it with balsa wood.
I use a craft spray glue and on some of the wood when it is more then two sheets, on this new kit I'm cutting four at a time, I sprayed both sides of the wood being cut. It took a lot of time with my heat gun to separate all the ribs for the wing and stab. When I get the parts apart I can't stack them for a while until the glue cools down and sets up.
I have run into the little problem Acdii had with the shop rag leaving a bit of fuzz behind but a bit more acetone after a day or so to allow the glue to set that comes off too.
Just one of the little problems a builder or kit cutter will run into.
Back in the day saw cut kits were available in small numbers but die cutting is a bunch easier. Of course you would have to cut thousands of kits to ever pay for a Bop or Tompson press and the dies. I used to operate those but never cut a kit with one, dies aren't that cheap.
#554
We are still here. To find the builders get away from giant scale. I am 79 years old . Been building since I can remember. I have one ready to fly and seldom fly it. To tell the truth I had rather build than fly.I never got hung up on rc. I love it all .Old time free flight and c/l are my favorite.I always have more than 1 projecdt going I am lucket in that I have 16 acers just out my back door.
#558
jim
#559
I have Loctite spray adhesive, I think its the same as the 77 spray adhesive. Worked really good too. When I cut the parts for my Cub lower wing I traced the parts onto heavy card stock that I got from the packages my floor mats came in, then spray glued them to the wood, and glued the wood to each other. Worked great.
#560
#561
This is one of my tables in my shop. It is a seven foot long, ten inch wide by ten inch deep, a solid granite machine shop table. Perfectly flat from end to end, corner to corner.
It took seven people to move it into my shop.
It is fun to dream up ways to use it.
On another note, along the lines of this thread, building...the project shown here has been in the making for over two years.
Something which I find fascinating, people actually rate my photo contributions and it seems there is a bit of psychology going on. Once in a while I will notice that I get very high ratings only to find a few weeks later someone has then given me the lowest rating you could give to make the average score come way down. Honestly, I don't care other than to comment on human nature.
As as I said, along the lines of this thread, I guess there are people out there that just can't appreciate a person's creativity, hard work and commitment to detail. Boy, humans are a strange species!
Hey, where can I buy that?
#563
Thought I might add some updated photos of my Taylorcraft build. I have been working on this project since September and have worked through many challenges along the way but the entire process has been extremely enjoyable and satisfying. I have made some errors to be sure and have had to re-do several items but that's all a part of the learning. I will be 62 soon and this has been by far my most ambitious project.
#565
#569
This builder is currently building the Midwest Extra 300xs (27%). I have a few pics in the Midwest extra 300 thread. I have so many kits in my stock pile, it's hard to choose the next one to build. I have pretty much ever top flite kit with the exception of a few. I even have the old red box Zero. Think I'll build AK models F-16 next then either the giant scale P-51 or the AT6 Texan.
#571
Today I'm stuffing my nose with sawdust while sanding the LE & TE on my Stratus.
#574
Gerry
#575
My Feedback: (49)
As Much as I HATE building because a guy made me an OFFER I COULDN'T REFUSE, I have to either rebuild my 4' wide x 8' long x 2' high box on an Harbor Freight Trailed into a 4'x 4'x 8' box with a sliding shelf at 2' off the floor with side opening doors on the lower level or just sell it and buy a real trailer and get i5 MPG instead of 22 MPG back to Wisconsin. Decent cargo Trailers start at 2 grand Used. Oh heck I'm going on 72 and if I don't spend it My Daughter will. Any one in the Phoenix area got a good cargo trailer for sale?
Oh the offer was 3 - $600 to $900 New (but almost New, Batteries and receivers included) planes for $900 cash. Then he through in one of those 18" FA-18 with Receiver and Batteries. He said that $900 dollars would get him 6 Hours flight time in a Cessna 172. full scale ....
Man when I start full scale in June of 1970 It was $10/Hr wet and $5 for the Instructor. But I was on a Tool & Die apprenticeship and made $2/HR. Guess it took 10 hours work, minus taxes, for 1 hour of flight instruction. R/C aviation is just slightly cheaper ALMOST.
