Sig Kadet MkII build >
Old 05-04-2016, 03:39 AM
  #176
TomCrump's Avatar
Originally Posted by Hydro Junkie
2) Tom, that shop is too clean. Can you show us something that actually shows you work in there? As any builder knows, a clean shop is a sign of a sick mind
That's the first time that I have been accused of having a clean shop. LOL That pic was taken just after I cleaned up the pile of scrap Solartex, the day I covered the Luscombe.
My shop usually looks like this.
ID:	2160805   Click image for larger version
ID:	2160806   Click image for larger version
Old 05-04-2016, 06:33 AM
  #177
FlyerInOKC's Avatar
See, Tom is normal after all! Its just his build quality that is off the scale.
Old 05-04-2016, 10:43 AM
  #178
Getting started on copying the trim scheme from the plans (thank you Sig for including that!) to the covering/airframe.
ID:	2160926   Click image for larger version
ID:	2160927   Click image for larger version
ID:	2160928   Click image for larger version
Old 05-04-2016, 07:01 PM
  #179
FlyerInOKC's Avatar
This is going to look great!
Old 05-05-2016, 02:40 AM
  #180
Hi Mike (FlyerinOKC-hope I remembered your name correctly), thanks for the vote of confidence. I'm trying my best, but a lot of this is new to me, so hopefully! :-)
Old 05-05-2016, 06:33 AM
  #181
FlyerInOKC's Avatar
You remembered correctly Ken. I saw a set of plans that reminded me of a Kadet, are you up to trying your had at plans building? Here is an interesting design from Phil Kraft from back in 1963.
http://aerofred.com/details.php?image_id=92261
Old 05-05-2016, 12:23 PM
  #182
Hi Mike,
Yeah I saw that Kraft bipe plan you posted on another thread too. It's a really lovely bipe actually, and it really does remind you of a Kadet! I'd love to try that one day...I don't mind trying my hand at plans building sometime in the future. (As long as I can get my hand on the necessary hardware like landing gear).
Cheers,
Ken
Old 05-05-2016, 12:44 PM
  #183
FlyerInOKC's Avatar
That stuff is usually easy to find and you could also check with a laser cutting service to make the shaped parts if you are so inclined.
Old 05-09-2016, 07:45 AM
  #184
Hi guys,
Marking of the paint scheme on the airframe done! (I have a hard time believing it myself). I just need to mark out the gray-trim (would it be wrong to call it pin-striping?) and I can start painting. I'm going to start by covering some scrap wood with Solartex and see how the paint goes on.
ID:	2161742   Click image for larger version
ID:	2161743   Click image for larger version
ID:	2161744   Click image for larger version
ID:	2161745   Click image for larger version
Old 05-09-2016, 02:26 PM
  #185
TomCrump's Avatar
Originally Posted by KenChoo
Hi guys,
An alternative method would be to paint the base color, and then mask the trim. Automotive tape is often used for pin striping.
ID:	2161785   Click image for larger version
ID:	2161786   Click image for larger version
ID:	2161787   Click image for larger version
ID:	2161788   Click image for larger version
Old 05-10-2016, 03:30 AM
  #186
Wow, that's beautiful!
Jim
Old 05-10-2016, 09:54 AM
  #187
Thanks for the tip, Tom!
Old 05-11-2016, 04:26 AM
  #188
TomCrump's Avatar
I
Unless I misunderstood what you were showing in the pics, I think you mayl find my method easier, and therefore faster. Either way will work, though. Go with what you are comfortable with.
Old 05-12-2016, 03:14 AM
  #189
Hinge knuckle gap may promote flutter - may want to consider relief for knuckle to eliminate gap on all control surfaces as stated in post #56 - had an aileron failure due to hinge gap from personal experience. Another alternative is to tape hinge lines.
Old 05-12-2016, 05:20 PM
  #190
Whew! Still masking patterns out in preparation for painting....I did not expect masking to be such time consuming and tiring work! Couple of pics of the masking progress, and one of a test piece for how the masking tape and paint handled. Interestingly, it looks like the gray just needs 3 coats, and the black will be fine with 2 coats, but the red needs 4-5 coats to look its best.
ID:	2162170   Click image for larger version
ID:	2162171   Click image for larger version
Old 05-13-2016, 07:00 PM
  #191
Are you painting the red over white? If no white underneath you will be very frustrated with the red and it will probably never look its best.
Old 05-14-2016, 03:10 AM
  #192
pd1
Ken, I'm a bit slow so bear with me. Are you going to paint the plane and leave under the masking tape plain covering color?
Or are you planning on re masking the pinstripes later?
I did this plane all white first, then the black nose, covered the nose and then the green.
When the tape and paper was removed the white accent stripes were revealed.
Is this what you are planning?
Paul
Name:	3m rtfrt.jpg
Old 05-19-2016, 08:58 AM
  #193
Hi all,
My apologies for the late reply. It's been a busy time. I'm going with a route that I feel is best for weight savings (being mindful it is a smallish plane). I think rather than explain further what I'm doing I'll let the photos do the talking...
Cheers!
ID:	2163193   Click image for larger version
ID:	2163194   Click image for larger version
Old 05-21-2016, 10:41 AM
  #194
My Feedback: (13)
: ) Okay guys, here they are then...
Beautiful work, Ken. I've about decided to build myself one; lose all the dihedral, make the wing bolt-on, convert to tail dragger, and use an OS 52 Surpass. I was considering the SolarTex, but I think I'll stay with my old standby UltraCote.
Old 05-22-2016, 06:32 AM
  #195
skylark-flier's Avatar
If I might - you really don't want to lose ALL the dihedral, it makes the wings look like they're drooping.
Dropping to about .5" works just fine though.
Just a thought.
Old 05-23-2016, 06:35 AM
  #196
Hi All,
As usual, progress is slow, but thankfully there's still progress. :-) This is where I'm at with the painting...
ID:	2163888   Click image for larger version
Old 05-31-2016, 05:45 AM
  #197
Progress picture...Black portion on wing done.
Old 05-31-2016, 06:37 AM
  #198
MFIGHT43's Avatar
Looks great! Nicely done.
Old 05-31-2016, 04:57 PM
  #199
My Feedback: (13)
Just a thought.
Makes sense; thanks.
Old 06-12-2016, 07:39 AM
  #200
DBD1's Avatar
Ken, your build is really turning out nice!
I am watching with great interest, the covering stage is where I stalled out on mine. I need to get back on it and get it finished and really like the Solartex and Nelsons paint approach. A couple questions if you don't mind.
Did you apply balsarite to the entire air frame before covering?
Does the masking tape come up without lifting the covering from the air frame?
Are you applying the paint with a foam brush?
Are you using the cross-linker in each Coat?
Don
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
