Reload this Page >
sig kadet senior kit
Old 07-22-2016, 02:01 AM
MARK JR
Default sig kadet senior kit
Hi, what tools and how much glue do you need to build a sig kadet senior kit? Thank you
Old 07-22-2016, 10:44 PM
3136's Avatar
Have a look through these mate.
http://www.rcuniverse.com/forum/kit-...ky-needed.html
http://www.rcuniverse.com/forum/kit-...n-newbies.html
http://www.rcuniverse.com/forum/kit-...-building.html
http://www.rcuniverse.com/forum/kit-...-question.html
Old 07-23-2016, 06:37 AM
TomCrump
TomCrump's Avatar
An x-acto knife, razor saw, pins and 2 bottles of medium CA should be all that you need to build a Kadet Senior kit. This assumes that you already have a flat building surface that accepts pins.
If you decide that you need more tools, I suggest that you purchase than as they are needed.
I built my trainer, using only an x-acto and the two bottles of CA.
In my opinion, it's impossible to cover all the bases before you build. Buying tools as they are required, gets you exactly what you need, and you are not buying stuff "just in case".
As your building experience grows, you will find gadgets that can make your life easier. What suites some, may not suit others. I've read threads that state such and such is absolutely required, and I've never used them in 50 years of building.
You'll love the Kadet Senior. I have two at the moment.
Old 07-23-2016, 01:54 PM
foodstick
foodstick's Avatar
Built light the Senior is almost gravity defying, they really are that nice. Especially in low to no winds... and its a KILLER electric, slow and almost no sound but the air on the wings...
Old 07-24-2016, 12:08 AM
MARK JR
Thank you guys
Old 07-24-2016, 03:09 AM
3136's Avatar
I have one of those kits put aside for my son, (he's only three) when we build it, I'll probably include ailerons, but you don't need them.
One other glue you need for high stress areas is 2 part epoxy (30 min) you will normally use it for the firewall (where the engine mounts)
Generally just read through the forums and you'll find answers to questions you never even thought of asking.
I know I have learned a hell of a lot from reading others build threads, and others questions, and the answers they got.
I haven't looked at the kit instructions yet, but most sig kits are pretty good at telling you what you need, have a FULL read through that before starting.
Old 07-29-2016, 03:14 PM
ratshooter
This is my favorite glue to build with. I use some CA and of course epoxy but I am not in a hurry so don't mind a little extra drying time.
http://www.homedepot.com/p/Weldbond-...-545/203874337
Old 07-29-2016, 05:51 PM
foodstick
foodstick's Avatar
Ratshooter,
Does that glue dry more rubbery...or hard and brittle?..sanding properties? Also does it dry clear or opaque? Just curious.
I have been using the Gorilla glue for wood a lot lately dries clear and rubbbery, doesn't really sand down as smooth as some other things. But I like it..I think Woodbond 2 ? is the other harder yellowish glue I use. Some odorless CA and epoxy of course get used as well.
Old 07-29-2016, 07:01 PM
ratshooter
OK Weldbond is the same stuff as RC56 so I have been told. A little rubbery. If I need to sand an area I use Titebond original. I just don't like to use a lot of CA if I can get around it. The Weldbond dries really fast compared to Titebond. You can buy small bottles to try at Michaels Craft store. I bet you will like it. I have a syringe from the vet supply with the needle ground off and thats what I use to dispense the glue. Much neater than straight from the bottle. If it gets a little thick you can add water to thin it. Do a google search and read the spec sheet. It is impressive.
I have been using this glue since the early 1990s and hope it never goes away. I love the stuff. No fumes and its fuel proof. I use it in the engine area to fuel proof the wood. Best darn glue you will ever use.
I have even used it to glue the center section on a wing when I was out of epoxy. And I didn't even use fiberglass cloth. I used .010 pillow ticking I had on hand for patching round balls in my muzzleloader rifle. Here is a picture of that plane. I flew the snot out of it and the wing never failed. This is a Bridi Loadstar. And I have a new kit in my attic just waiting its turn on the building board.
Old 07-30-2016, 08:33 AM
foodstick
foodstick's Avatar
I have never even consider using white glue from a syringe, that would be handier than laying the bottle on the side half the time so the glue was close to the tip....
Old 08-04-2016, 01:24 PM
ratshooter
The syringe trick works really well. I think I have a #18 needle on my syringe with the tip ground off flat. You can clean the syringe with water when you are through. Just don't use dish soap (Dawn) in the syringe. It makes the rubber plunger swell up and ruins the needle.
When I was doing mobile home factory service work sometimes there would be a bubble in the lino flooring. So I would use a syringe with floor glue and the sharp point to shoot a little glue in the bubble then set a weight on it to glue it down. Thats where I got the idea from. You can leave the glue in the syringe and just insert a close fitting wire in the needle till you need it again.
Old 08-04-2016, 03:37 PM
foodstick
foodstick's Avatar
I will be looking into this one way or another
Old 09-04-2016, 07:44 PM
MARK JR
Hi,John how do you set up a kadet senior to carry one fallon of fuel? Thank you
Old 09-05-2016, 12:01 AM
born2build
born2build's Avatar
I have one of these kits in my inventory. As soon as I clear the bench, I'll be starting on it very soon as my winter project. in order to create a light, straight, and strong structure, good fitting joints are a must, particularly on a stick-built model such as this. To that end, I picked up a Fourmost miter sander from Tower Hobbies for around $20 I think. Although not absolutely necessary, I think it will make getting the correct angles of those uprights and diagonals a lot easier. You might want to check it out.
Old 09-05-2016, 12:06 AM
born2build
born2build's Avatar
I assume you meant "gallon" and not "Fallon". At any rate, you're kidding, right?
Old 09-05-2016, 04:24 PM
MARK JR
Gallon
Old 09-05-2016, 04:25 PM
flyboy2610
flyboy2610's Avatar
Nope.
http://www.rcuniverse.com/forum/begi...ry-planes.html
Old 09-06-2016, 09:25 AM
born2build
born2build's Avatar
Okay, then. Well, I wish you luck with that.
Old 09-06-2016, 11:14 AM
foodstick
foodstick's Avatar
I think in weight carrying competitions in the past the Sig Senior has been able to carry 10 pounds with success, Now I think it probably affects the flying aspect a bit
Old 09-06-2016, 02:16 PM
born2build
born2build's Avatar
Yeah maybe just a tad. There used to be an A.M.A. cargo competition class. Do they still that? As I recall, the Senior Telemaster was used a lot in that category. F.A.I. keeps records on such things.
Old 09-06-2016, 02:37 PM
J330
1 gallon of fuel = 6.6 lbs. One Telemaster Senior out there, and it's an Engel too. http://www.ebay.com/itm/191961795803...84.m1555.l2649 The extra 20" wingspan and larger fuselage would facilitate a gallon a lot easier and not be a problem with flight. Build it with dihedral taken out.
Old 09-06-2016, 02:59 PM
born2build
born2build's Avatar
Okay, good to know. come to think about it, it may have been the12 foot Telemaster, which makes more sense. That thing could lift a small house! No matter, it's not really my thing. "Bashin' balsa since 1979"
Old 09-07-2016, 06:25 AM
J330
Forgot about that mammoth! http://www.hobbyexpress.com/12_ft._t...39257_prd1.htm
Only $900 on sale.
Imagine how much glue that takes? Monokote? When you crash it, you can make two or three .40 size planes from the busted up pieces.
Old 09-07-2016, 10:24 AM
MARK JR
How do you connect 2 gas tanks inside the plane?
Old 09-07-2016, 11:28 AM
born2build
born2build's Avatar
Feed (clunk) line from # one to the vent line of # two. Vent line of # one to the muffler, feed line of # two to the carb.
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service - Do Not Sell My Personal Information
Copyright 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
