4mm Coro
WV
Hello im building my first airplane from a set of plans and it is calling for 4mm Coro can anyone tell me what it is and where to get some?
Also have some other words i need defined for me,,,SPAR,,,,Thanks alot.
You can buy Coroplast at most sign shops. I just bought a 4x8 sheet today for $12.50.
As for "Spar", the spar is a component of the wing. The spars are the part of the wing that run the length of the wing and connect the 'ribs' (the airfoil shaped pieces) together. In most R/C planes there is one set of spars that run down the middle of the wing.
Clay
Clay
