Reload this Page >
TF Beechcraft Bonanza F33A Build
Old 01-20-2020, 06:25 AM
  #701
jetmech43
My Feedback: (9)
I went all the way through then filled it a shaped with light weight spackle
Old 01-20-2020, 07:23 AM
  #702
VincentJ
VincentJ's Avatar
You filled the entire gap?
Old 01-20-2020, 08:00 AM
  #703
jetmech43
My Feedback: (9)
I used a separate 1/16 balsa sheet I glued on top of the sheeting after I made the corrugations, then fill it with spackle
Old 01-20-2020, 10:01 AM
  #704
VincentJ
VincentJ's Avatar
Sometimes you work all day to accomplish the small details that you hope others notice. Beside adjusting the gap surrounding each wheel, I added basswood strips flanking the strut opening on each strut.
In addition to giving it a more finished look, adding the basswood will: a) adjust the gap between strut and wing sheeting, and b) add strength to the sides of the sheeting hopefully preventing any damage from occurring .
Now it's time to make-up the wheel covers!
Old 01-25-2020, 10:07 AM
  #705
VincentJ
VincentJ's Avatar
While I may be fiberglassing, what I'm really doing is prepping the parts to make those corrugations that all Bonanza's have. After a lot of forethought, I decided on how best to make the corrugations. Using my Dremel rotary tool, I will route out 1/4" wide shallow flutes into the 3/32" balsa sheeting. Practicing on 1/32" sheeting, I was able to make shallow flutes without penetrating through. I also concluded that glassing the parts before routing will yield me a better/sharper edge once the balsa has been hardened by the resin rather than having to deal with glassing afterwards. Anyway, that's the plan, now it's time to fully commit to my plan and execute!!! Wish me luck...
1/2 ounce fiberglass cloth was cut and laid over the flap making sure it has about one inch of overhang all around. I know many modelers don't like using such light weight cloth, they have a hard time with the cloth staying in place along with having the weave separating while spreading the thick resin using a credit card. This is the problem why! First, the resin they're using is way too thick for such a light weight cloth and secondly, don't use a card to spread the resin, use a brush!!! I promise you if you try this method, you will fall in love with how the light weight cloth will easily follow the most complex curves. In the end you will end up with a better and lighter project.
Earlier on in this thread I had shared the ratio that I use, but I will quickly refresh your memories. In the small mixing cup, I pulled 5 cc's of resin and another 5 cc's of hardener and gave it a quick mix. To that, I added 10 cc's of denatured alcohol and gave it a final mix.
These are the chip brushes that I use to spread out the resin. I purchased them from my local hardware store. They are cheap and not worth the effort to clean. For today's job, I used the brush in the middle.
Liberally spread the mixture allowing it to wick into the balsa.
In total, I used 10 cc's.
Old 01-25-2020, 11:30 AM
  #706
FlyerInOKC
FlyerInOKC's Avatar
I am watching this with great interest!
VincentJ (01-25-2020)
Old 01-25-2020, 12:05 PM
  #707
VincentJ
VincentJ's Avatar
Me too!!!
Old 01-25-2020, 05:10 PM
  #708
speedracerntrixie
My Feedback: (29)
speedracerntrixie's Avatar
Looks like we are at the same stage with our projects.
Old 01-26-2020, 01:38 AM
  #709
VincentJ
VincentJ's Avatar
Nice work there Speed. Is that 1/2 or 3/4 oz. ? I enjoy glassing!
Old 01-26-2020, 07:23 AM
  #710
speedracerntrixie
My Feedback: (29)
It's 3/4oz. While sanding primer I cut into the cloth a bit, with 3/4oz cloth it reduces the odds of cutting through the cloth.
VincentJ (01-27-2020)
Old 01-26-2020, 01:32 PM
  #711
VincentJ
VincentJ's Avatar
The right flap has been glassed. Two coats of resin was applied at this point.
Pencil lines show where the corrugations will go. If you're wondering why there aren't any on the left hand part of the flap, the reason is that this area will have the black textured material for entering into the plane.
Now that I have the logistics figured out, I will glass the remaining flap and two ailerons before I start routing the corrugations.
Old 01-26-2020, 03:05 PM
  #712
Tequesta
Tequesta's Avatar
Smile
subscribed! This is a great build and I am so envious of your skills!
Earlier you gave this tip.
Builders Tip: Now that the edges of the sheeting are jointed, you still have one more thing to do before you start spreading the glue. On the inside edge that will be butted up to the next sheet, sand a small bevel. The reason for doing this is to give clearance to the very small bead of glue that squeezed out and dried on the other sheet. This bevel will allow the two sheets to more closely butt up to one another.
Early in the build you bevel pieces to give a greater surface area for the glue. Wouldn't this tip reduce the area and make the bond weaker?
I have 3 kits that have been waiting for my kid to move out so I can have a hobby room. I have my room now. 22 years later.
thanks
John
Old 01-26-2020, 04:34 PM
  #713
VincentJ
VincentJ's Avatar
thanks
John
Thank you John. That tip that I gave was in reference to mating a second sheet to a previously glued balsa sheet. The first (already glued) sheet will have a very small amount of dried glue squeeze-out that will prevent the second sheet from making contact. By making a small chamfer on the inside bottom of the second sheet, will allow the two sheets to better mate. I hope I didn't confuse you!!!
Good luck with building those kits in your new digs...
Old 01-26-2020, 05:34 PM
  #714
Tequesta
Tequesta's Avatar
Thanks for clearing that up. It makes perfect sense now.
Old 01-26-2020, 08:48 PM
  #715
FlyerInOKC
FlyerInOKC's Avatar
Welcome John to the Vince J University of R/C Modelling. The wealth of knowledge in every build Vince does is invaluable! I get giddy evey time he starts a new one. I steal some of my best ideas from his builds and I'm not too proud to admit it!
Mike
Old 01-27-2020, 03:36 AM
  #716
VincentJ
VincentJ's Avatar
Thanks Mike! Don't look at it that your stealing anything, we modelers like to share the information that we learned either from our own work or through the help of others.
Old 01-27-2020, 05:54 AM
  #717
FlyerInOKC
FlyerInOKC's Avatar
I think its this freeflow of building secrets that makes this hobby so fun. I learn from you and then I pass the trick of the trade along to someone else down the road.
Old 01-27-2020, 02:04 PM
  #718
VincentJ
VincentJ's Avatar
I'll start this evenings post with a builder's tip. You can never have too much scale documentation on hand. Even before I started to unroll the plans for this build, my partner Bob and I went to the Manchester, NH airport and photographed a Beechcraft Bonanza that Bob had tracked down. We took over 150 photos. Surely that would be enough...Nope! Here's where my tip will help: Needing even more scale documentation left me scratching my head, then it dawned on me where I might be able to find what I was looking for...ebay!!! I logged in and searched for the parts that I needed specific photos of. As an example, I wanted to see if I could find the RH flap, sure enough there were RH flaps for sale with detailed pictures providing me with the information that I was looking for...GOLD MINE!!!!
I bound all the detailed photographs in sections organized by each part.
The remaining flap as well as the two ailerons are readied for glassing.
First coat of resin applied, tomorrow I'll trim them and glass the opposite sides...
Old 01-28-2020, 04:42 PM
  #719
Tequesta
Tequesta's Avatar
Thanks Mike I am eager to learn. Not sure if I'm going to switch to F\G though.
Old 01-29-2020, 01:36 PM
  #720
VincentJ
VincentJ's Avatar
This photograph shows resin and hardener in their correct ratio and mixed.
Now I add the denatured alcohol, as soon as you start to stir it, notice how cloudy the mixture becomes. This is normal, as the moisture in the resin is combining with the alcohol.
Keep mixing until your mixture becomes clear...
Second coat of resin applied to the control surfaces.
This weekend I will be anxious to route out my corrugations!
Old 01-30-2020, 05:41 AM
  #721
Tony Hallo
Looking forward as well.
Old 01-30-2020, 05:50 AM
  #722
FlyerInOKC
FlyerInOKC's Avatar
Me too! And probably every other builder wanting to build a Bonanza!
Old 01-30-2020, 06:50 AM
  #723
VincentJ
VincentJ's Avatar
Great camera work following a 1986 F33C Beechcraft Bonanza. Worth a look.
Old 01-30-2020, 06:55 AM
  #724
FlyerInOKC
FlyerInOKC's Avatar
That is some flying. I wonder if he made any modifications to the airplane to do stunts like that?
Old 01-30-2020, 07:32 AM
  #725
VincentJ
VincentJ's Avatar
Don't know Mike, but my partner Bob tells me that the F33C is the aerobatic version of the Bonanza that they made from the factory... and yes the pilot is superb!
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service - Do Not Sell My Personal Information
Copyright 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
