Reload this Page >
TF Beechcraft Bonanza F33A Build
Old 08-21-2019, 04:53 AM
  #201
FlyerInOKC
FlyerInOKC's Avatar
I can relate to minimum building time. Life has a way of getting in the way of the stuff we really enjoy. I think it makes us appreciate our hobby all the more. Any new photos to share Vince?
Mike
Old 08-21-2019, 05:42 AM
  #202
VincentJ
VincentJ's Avatar
Mike
I'll have some pictures to post this evening Mike. Top sheeting of the Center Section to show.
Old 08-21-2019, 11:02 AM
  #203
mkjohnston
Hydro' I work the night shift and I just started 2 months ago! Sometimes I go in at 5:30 pm in the afternoon and then I won't get off until 7am the next day! I . I sleep almost all day and then get up and go right back to it!
But to work on my airplanes has been kind of hard lately. I did and a fast repair on my current flying airplane and found that it didn't work at all! so I need to rip the bottom out of the fuel compartment. I almost decided to take it to a swap meet next week and get rid of it! This airplane is a GP Easy sport ARF and the landing gear bends real easy in fact I bent the nose gear back into the bottom of the fuse and was just from landing! yikes ha
Your build looks amazon Vince and I need to work on my skills
thanks
Michael
Old 08-21-2019, 12:43 PM
  #204
VincentJ
VincentJ's Avatar
No narratives necessary for this evening...enjoy the pictures.
Old 08-21-2019, 02:11 PM
  #205
FlyerInOKC
FlyerInOKC's Avatar
A work of art as usual!
Old 08-22-2019, 03:02 PM
  #206
VincentJ
VincentJ's Avatar
The two slots that you see in the front portion of the Center Section ribs are for the two wing dowels. This is the reason these two ribs are sandwiched with plywood...
Measurements were taken to ensure that the 1/4" hole I'm about to drill will line up with those slots.
I used a 1/4" brad point bit to make the hole. After drilling, I test fit a 1/4" dowel to see if my measurements were correct (and they were).
This photos shows how the dowel is held in alignment with the slots. Don't be tempted at this point to epoxy the dowels in now as they will only get in your way later when you are covering your model.
Sometimes it's the little things that make your model "better". The things that most people wouldn't even know is there, they're unseen but they make your build a little better, a little stronger.
Since I will be epoxying these dowels after the wing is glassed, I want to be certain that the epoxy will surround the dowel securing it into position. That's why I cut two pieces of scrap lite plywood to box in the dowel slot.
A couple of spring clamps and you're good to go...
Old 08-23-2019, 05:31 AM
  #207
SA Flyer
SA Flyer's Avatar
This wing dowel step is interesting and precise. Gotta wait to see how the dowels will mate up to the former or plate that they insert into.
BTW. You do inspiring work that I will incorporate into future builds. Those will never be as complex as this F33A. Uh-uh.
Old 08-23-2019, 05:40 AM
  #208
FlyerInOKC
FlyerInOKC's Avatar
I wish I had thought of boxing in the dowel holes and inserting them after finishing the covering. We need a head slap emote!
Old 08-23-2019, 10:17 AM
  #209
VincentJ
VincentJ's Avatar
Thank you Lupe, I'm glad that you find some of my work inspiring. I try to share what I know with others so they can be aware of the process and duplicate it into their own builds...
Old 08-24-2019, 02:17 AM
  #210
VincentJ
VincentJ's Avatar
Plan details showing how wing panels are joined.
These are the plywood dihedral braces shown in the plan. The outer dihedral brace is 1/16" thick while the inner brace is 1/8".
In order for the wing panels to be joined together, measure, mark and carefully cut slots into the outer wing rib allowing the braces to slide in. I want to be sure to take my time while this fitting process. A tighter fitting joint will be stronger than a loose fitting one thus relying on the epoxy for strength.
Outer wing panel is slotted along with the corresponding Center Section panel.
View from the opposite direction.
The 1/8" braces are slid into place. Note how they fit between the upper and lower spar. Make sure that you have the dihedral brace in the right direction!
The 1/16" dihedral braces are inserted. They flank each side of the upper and lower spar, sandwiching the whole assembly together once epoxied.
Time to slide the Center Section on as see how it fits...
Old 08-24-2019, 06:48 AM
  #211
TCampbell
TCampbell's Avatar
Vin, I assume this is designed as a one piece wing? At first I was thinking it was a good set up to remove the outer wing panels for transport, but that brace design might not be best for repeated assembly. 81" is a lot of wing to move around...
Old 08-24-2019, 07:49 AM
  #212
VincentJ
VincentJ's Avatar
Tim unfortunately this is a one piece wing. Large enough to be a surf board...
Old 08-24-2019, 04:00 PM
  #213
VincentJ
VincentJ's Avatar
Received my wheels today. I had to send the others back because of the wrong axle size. (I was sent wheels that had a 3/16" axle)
These are high quality 3-1/2" wheels by Robart. The hubs split by removing the three cap head screws visible so the tire can be mounted.
When I mounted the tires for the first time, I wasn't happy with how soft the tires were. I needed to make them stiffer, especially with a potentially 20 pound plane. The solution was pretty easy.
Apparently others before me had the same concern, so Robart came up with this solution. Simply insert inside of the tire with this foam rod.
The foam filler rod was very easy to install.
Once mounted, I was pleased with how much firmer these tires were.
Ready to install on the retracts.
The axle for these wheels are pretty robust at 1/4". I had to install a collar on the inside to give clearance for the knee shock.
I'm trying this new type of split collar. I think it will hold better and it's lighter than the steel collars since they are machined from aluminum.
With the wheels mounted, I can see how much material I need to remove from the rib for wheel clearance. I'm using a blade that I removed from a retired Zona saw. Works great!
With the material removed, I boxed in the cut out area using 3/32" stock.
Old 08-24-2019, 07:22 PM
  #214
FlyerInOKC
FlyerInOKC's Avatar
Looking good! Nice wheels too.
Old 08-25-2019, 12:25 PM
  #215
VincentJ
VincentJ's Avatar
I decided to box in the wheel well for a couple of reasons...
Reason #1- better support for the overlaying sheeting. #2-Wheel wells tend to collect dirt and debris with use. Easier clean-up down the road.
Old 08-26-2019, 12:01 AM
  #216
Hydro Junkie
Just out of curiosity, did you consider using wing tubes and splitting the center section to make the wings easier to handle while traveling and for storage? I see why it wouldn't work to do so where the dihedral braces are installed, so I was curious.
Old 08-26-2019, 12:49 AM
  #217
VincentJ
VincentJ's Avatar
No I never considered that as an option Hydro, but I like it, I think your idea has merit. Maybe if I ever build a second one!
Old 08-26-2019, 02:09 AM
  #218
Hydro Junkie
You could always scratch build a second wing center and integrate that into it before you epoxy the outer panels to the center section. If I were to do that, I'd extend wing tubes out to at least the wing joint, if not through it, for strength. The only real change, other than the wing tubes, would be to double up the center rib, one for each half. I know that's like taking the proverbial two steps back but..........................
Old 08-26-2019, 02:32 AM
  #219
VincentJ
VincentJ's Avatar
Too late Hydro as I have already epoxied the wing braces in place...
Old 08-26-2019, 02:46 AM
  #220
Hydro Junkie
Oh well, it was a thought. Time to start a second wing, if not a full plane. The way I see it, a spare is always good to have
Old 08-26-2019, 06:38 AM
  #221
GameEngineer
GameEngineer's Avatar
Perfect work as usual Vince. Okay time for another builders question. I see others fillet all joints with wood glue. I don't see you do that. Is it overkill if the joint was glued properly? Ribs to spars mainly.
Old 08-26-2019, 07:43 AM
  #222
VincentJ
VincentJ's Avatar
Excellent question Steve. Of course this is my opinion and others may disagree but...
If you have good contact between two pieces of wood, in other words no gaps, then fillets are NOT necessary. All they will do is add unnecessary weight to your model. The bond between the two surfaces will be strong enough. Don't believe me, then edge glue two 1/16" balsa sheets together and let dry. Now bend the sheets trying to break the glue bond. Yes, the wood will break, but not on the glue joint.
If when gluing up let's say a rib to a spar that is loose fitting, then it may be beneficial to have a fillet of glue to regain the strength lost from the lack of contact.
Whenever possible, after I glue two parts together I always scrape off any remaining glue that squeezes out. Glue that you see that isn't scraped off in any of my photographs means that I didn't have the access to do so. It not only saves weight, but it looks better too!
Hope this answers your question Steve.
Old 08-26-2019, 11:02 AM
  #223
GameEngineer
Yes it answers it perfectly. I like the added step of removing excess glue. Makes sense and not sure why I wasn't doing it. Wood glue dries outside in so if I add too much then I can imagine trapped air that takes a long time to dry. I found another forum where they had a mix of opinions but many favored the glue joint. For the kit I'm working on the rib to shear webbing was loose fitting and some secondary spars (lack of better name) had very loose fitting in the rib slots. Those were 1/4x1/4 spars just back from the leading edge.
I'm going to try the edge glue experiment. I believe you but I am a visual learner so I want to see it in action!
Old 08-26-2019, 12:03 PM
  #224
Hydro Junkie
And, while I agree with Vincent, there is another reason to leave a fillet of glue. If you have a structure that will be taking serious shock loads, such as landing gear blocks or, for that matter, floats on a float plane or flying boat hull, fillets may be a good idea. IF you can land smoothly every time and have a known smooth runway, fillets would be needless overkill. On the other hand, I wouldn't build anything that is going to be in the water without fillets and a sealing coat of something, at least on the lower half. Those joints, even when covered with film or FG, have to be water tight and able to take more of an impact than the plane that always lands smoothly on a smooth runway. Cracking a seam or a skin piece could result in a lost or water soaked plane if the joints aren't water tight, just like the Titanic
Old 08-30-2019, 05:44 AM
  #225
VincentJ
VincentJ's Avatar
Work or should I say progress on this project has slowed down because summer for me is over. That means back to work!
Big turning point in this build...I'm using 30 minute epoxy to join the three sections of the wing together. I prefer to join the wing prior to sheeting the bottom. I can clamp the halves together and see the epoxy squeeze out being assured that I have a strong joint that won't fail.
Copyright 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
