Reload this Page >
Great Planes 60 size EXTRA.....TOTALLY 3D
Old 07-11-2004, 07:09 PM
  #201
Wildstyle
Default RE: Great Planes 60 size EXTRA.....TOTALLY 3D
Hello
I have started to build this kit, have increased the rudder and plan on cutting holes in the fuselage and other areas to reduce the weight,I am aiming for about 7 - 7.5 lbs. I used to have the smaller 40 size version which was built as per the book with a 70 surpass that ran perfectly but the all up weight was to high, I switched to a os 46FX and the planes weight reduced to 6.25 lb but it was still a brick.
My question is; is any one running a YS 1.10 on the GP extra 300 60, or a OS 91 surpass. could you comment on the preformance and state the weight of your plane. I dont know weather I should use the YS that I all ready have or get a OS 91 as I think the YS might be an over kill at 7- 7.5 lbs.
Old 07-12-2004, 07:06 PM
  #202
AdrianM
Without serious attention to weight savings this planes will be in the 7.5-8lb range. A Saito 100 with a 15x6 on 30% Heli fuel is a good setup with unlimited vertical. Vertical is not unlimited in 15% nitro. The plane would be better with a YS 1.10.
Old 07-29-2004, 11:09 PM
  #203
DrFun
DrFun's Avatar
Captain,
I am finishing up mine, I can start covering soon, I need to do some minor things, like fuel pump and needle valve installation cutting the canopy. I had finished the cowl ring, I used 1/16" ply, tried clamping but I bought a cheap 12" scroll saw which cuts like crap so it did not work. I finally got a nice scroll saw today. I am screwing the cowl ring to the firewall sides with 4 servo screws.
I installed the elevator and aileron servos and will adjust the location of the rudder servo and battery about 7oz to get correct CG. Got titanium pushords and they are nice and light.
I did not hear anything from fiber-lite altough sent couple of emails, so I am going to mold my own. This will be my first try molding, I got the info from https://www.cstsales.com/How_to_Arti...ovely_legs.htm will be keeping the same dimensions as the stock gear except the thickness and widest part instead of 1 1/4 I will have 1" to save some weight, the thickness I am planning is about 1/8" 6-7 layers of Carbon Fiber. I have an experinced club member helping me. How thick is your landong gear? Does 1/8" sound right to you.
Also I did not buy the wheel pants as they were about $40 and will be molding them from the stock, lets see what I will do. Altough I am going to spend about $120 to mold the gear and pants, I think it will pay back by the next project.
I also cut male and female molds for the tail gear, yep, I am going to mold it too, like the ones TNT Sells, but those will be my experiments before making a mistake on the main gear.
Old 07-29-2004, 11:38 PM
  #204
DrFun
DrFun's Avatar
Now just checked the fiber-lite web site and they have one for Funatna 90, which is 1/2" wider at the fuse and 1: longer at fuse side and seems like a good fit
Old 07-30-2004, 07:33 AM
  #205
DrFun
DrFun's Avatar
Captain,
I bought the fiber-lite gear for Funtana 90, it will be cheaper than making my own and pretty close fit to GP Exra 60
Old 07-30-2004, 04:21 PM
  #206
torp
torp's Avatar
Hi lord lucan, like your easy fueller set up, will do this on mine.
cheers for pics .
torp
Old 07-31-2004, 12:33 PM
  #207
Josey Wales
My Feedback: (61)
Josey Wales's Avatar
Hey Captain!! Check your Pm's when you get a chance!
Old 08-09-2004, 08:21 PM
  #208
DrFun
DrFun's Avatar
Captain and for those who are interested in replacing the stock landing gear in GP Extra, I received the carbon fiber gear from Fiber-lite for Funtana S 90 and here are some pictures compared to stock gear.
What is not noticable in these pictures is the weight difference. This is probabaly the best investment in terms of GP Extra diet for <$37 shipped it is good deal. the specifications from fiberlite says it is just 90grams about 3.2 oz.
It is about 1" wider than the stock gear and the width of the gear fits perfect to the stock location and a little wider at the ground and higher.
I am pretty happy with the gear, and that was a fast shipment from Fiber-lite.
ID:	162209   Click image for larger version
ID:	162210   Click image for larger version
Old 08-18-2004, 08:35 PM
  #209
paragallo3D
i would use Robart's hinge points. they are very much stronger, and only add another, what 2 ounces?
Old 07-26-2007, 10:39 PM
  #210
Hughes500E
My Feedback: (16)
Hughes500E's Avatar
Almost 3 years later; I can't believe you guys left us hanging like this [:-]
Well, did anyone actually finish this model?
Old 07-29-2007, 12:56 PM
  #211
vadik999
Hello dear friends! Anybody made this plane?
Please say – the GP EXTRA 300S .60 real 3D plane?
Old 12-17-2009, 12:59 PM
  #212
LSteve
Hi everyone, if anyone is out there,
Almost 2.5 years since the last post. This was an excellent thread. I'm building this plane now. Wish I could find a source for the carbon fiber gear. Oh well. The modifications I've made are to hide the aileron servos in the wing and to beef up the landing gear attach structure.
Old 01-24-2011, 10:27 PM
  #213
Legot
Since it was apparently not posted on this thread, it was "revived" back in December of 2004.
http://www.rcuniverse.com/forum/m_24...tm.htm#2447736
I have no Idea of who ,made the petition to not post it anywhere...
Old 06-19-2013, 07:05 PM
  #214
el_xero
How can I get the modified plans? I dont see the email option and this is a super old thread at that I wonder if anyone still monitors it. I've only just started reading it!
