Reload this Page >
Kadet seniorita into a twin
Old 12-23-2004, 11:14 PM
FOD MAN
FOD MAN's Avatar
Default Kadet seniorita into a twin
from what i have heard in many posts a .15 in a seniorita will make it under powered. since i have two new .15 engines of different brands how about mounting one in a pod over the wing. this way i do not have to worry about the power differential between engines as they will be in-line. with the lite wing loading of the seniorita i dont think the extra weight will be much of a problem.the one in the pod will be a pusher. anyone care to comment or have any ideas. i know i should just install a .25FX or a small 4 stroke but i like to do things a little different
Old 01-24-2005, 05:02 PM
pfine
pfine's Avatar
Default RE: Kadet seniorita into a twin
Here are two Sig Kadet Seniors I bashed into twins. Both flew great with old OS FP 40's and about 3 degrees right thrust in port side engine in case one quits. Maybe this will give you some ideas.
Paul Fine
ID:	220092   Click image for larger version
ID:	220093   Click image for larger version
Old 01-25-2005, 12:39 PM
BedfordBob
Wow Paul,
That is really cool. From a Kadet even.
Bob
