badly built wing >
badly built wing
badly built wing
Old 09-05-2002 | 12:14 PM
Default badly built wing
hey guys,
what happens in a trainer if you build a wing with way too much wing dihiteral??
That is besides looking ugly lol
Thanks for the help
Regards:
Brendan Williams
Old 09-05-2002 | 12:24 PM
PaulSwany's Avatar
My Feedback: (45)
How much is too much?? If it's not excessive... you'll be fine... Inverted flying won't be as good... but how much inverted flying do you do with a trainer anyway??
Old 09-05-2002 | 12:39 PM
Dont think i would be.Lucky my first kit was a trainer, many people get ARF's as first planes.
I once heard people talking about using a heat gun on monokote to bend mistakes back into shape.Would that work??
Old 09-05-2002 | 12:48 PM
My Feedback: (12)
Heating the mono coat will not reduce the dihedral but it can be used to take warps out, to much wash in or wash out. Do you have ailerons on the trainer?
Old 09-05-2002 | 12:58 PM
Probably a good thing otherwise people would be accidently changing there dihiterals.
I looked around www.sigmfg.com and cant see and wing kits.do they make wing kits??
Would a PT 40 wing fit on a Kadet MII fuse??
Old 09-05-2002 | 03:41 PM
JNorton's Avatar
Sig's Web page is not the easiest to navigate. Replacement parts are found under Accessories.
http://www.sigmfg.com/cgi-bin/dpsmar...FV2.html?E+Sig
SIGRPBK249 BALSA WING KIT- KADET MARK II EACH $41.99
Enjoy,
John
Old 09-05-2002 | 03:42 PM
TRP
Just curious - How off is it?
Old 09-05-2002 | 08:55 PM
Call Sig and they will sell you a wing kit. It will be approximately 2/3 the cost of a complete kit.
Old 09-05-2002 | 11:59 PM
its off 2 inches on each side of the wing.
Im ok with it looking ugly, see how it flys first.Wing kit may be 2/3 the price but it beats buying a new kit!
...im building with the ailerons.
Old 09-06-2002 | 03:25 AM
Put it on your power saw and CAREFULLY cut it right down the center of the middle ribs. Re shape it and reglue it. You shouldn't have to put out the bucks for a new wing for a mistake like that.
I cut my senior wing after building it with diehdral and took most all of it out and added ailerons on the rebuild. Good luck what do you have to lose. I used my scroll saw with a very fine blade.
Al
Old 09-06-2002 | 03:28 AM
ill give that a try if i do lean towards getting a new wing.
Thanks for the help
Old 09-06-2002 | 05:21 PM
Getting a new wing from SIG + shipping may cost as much a new KIT.
