 Retract Install >
Retract Install
Retract Install
Old 02-15-2005 | 07:00 AM
My Feedback: (31)
Default Retract Install
Hello,
Am installing air retracts into a Sig King Kobra. The wheel wells are cut out and lined with balsa.
Can the air line lay across the inside of the wheel well? Or does it need to be routed under the balsa wheel well?
Cassat
Old 02-15-2005 | 10:41 AM
MinnFlyer's Avatar
Default RE: Retract Install
It can be anywhere as long as it doesn't interfere with the gear or mechanism.
Old 02-15-2005 | 07:15 PM
DavidAgar's Avatar
My Feedback: (108)
What Mike said is indeed true. If you run it across the open wheel well, you really need to secure it so that it cannot get tangled up with the wheel or the struts. Good Luck, Dave
