Pics of 4-40 Aileron servo install
My Feedback: (24)
Hi,
I am looking for some pics on how the aileron servo(single mount) is installed on the 4-40 kit version. I bought this plane already built, but have no manual. I thought there would be a cut out or something on the wing were the servo mounts, or a mounting plate of some kind. Also, from what I can figure the servos for the elevator, rudder, and throttle get mounted on 1/4 balsa, or a aftermarket servos tray.
Matt
Matt
RE: Pics of 4-40 Aileron servo install
Hi Matt,
If it were me I would go with something a little stronger then 1/4" balsa for your servo support. You would be surprised at how much pressure can be applied to one of your control surfaces and in turn transfer that pressure to your servo's. I'd go with say 3/8" balsa or go ahead and use your 1/4" but glue some lite ply on top of it before mounting the servos.
With regards to your question about mounting your aileron servo you might do a search for the model that you have and see if a manual is available online. Some of the kit manufactures do offer that kind of support. Another idea is to go with a manual from another manufacture that may be similar to your and see what they did. I found this page that has several manuals online that might be helpful: http://www.greatplanes.com/parts/index.html
Do a search on this site for idea's that might be helpful. I'd start in the kit builders section.
Post what type/name of airplane that you have and this will help others who read your post to better help.
Hope this is helpful to you...
Cheers,
Cheers,
My Feedback: (24)
Thanks Tim,
It's actually a scratch built! So there is no hole cut out for the aileron. That kind of threw me off. I guess I am going to cut a square hole in the middle of the wing and then use two 1/4 balsa strips to mount the servos.
Matt
Matt
My Feedback: (24)
Thanks guys,
I actually used 1/4x3/8 Spruce for the mounts. It turned out pretty well. It took a while to curve the hole since there was a rib right in the center of the wing.
Matt
Matt
