SIG RYAN STA (FINISHED)
MI
RE: SIG RYAN STA (FINISHED)
WOW! Very Nice Job, Lets us know how it fly's,...PLEASE!!!!!
I have sig ryan at about 90% of the wood part of the plane, then really started lookin at that plastic,.....and put it up about 3 years back,....... also what did you put in it for the power plant?,.........Good Job,...Good Luck,.......Paul
Thank You everyone!! I put an OS 61 sf in it and am wondering how it will fly. The plans call for an Enya 60. The plane weighs 9 pounds even. Ill let you know how it flies. If anyone out there has run a two stroke in one of these Sig Ryan's. Let's hear from you.
Thanks, Barzini
Thanks, Barzini
Hey, that is one great job! No one else knows what it takes to accomplish it, one has to build it. I didn't put the wheel strut covers on mine- the old plastic did not hold up- maybe I'll fabricate some from balsa like you did.. Yours look so good. I'm nervous flying mine, now. But the first flight was a THRILL. My O.S. 61 SF, w/12x5 prop, does a good job of powering the plane-it's not supposed to "hang".
good job - it was worth the effort!!!!!!!!!
Nitehawk, retired Lockheed - Martin, NASA instrumentation and communications engineer since 1961.
BARZINI
The .60 should fly it just fine if the weight is within reason.
A friend of mine has the Sig Ryan with a .60 in it and it's a real
sweetheart.
Nice job, congratulations
Regards
Roby
sweetheart.
Regards
Roby
