 LT-40 Pics? >
LT-40 Pics?
LT-40 Pics?
Old 08-03-2005 | 12:16 AM
somegeek's Avatar
Default LT-40 Pics?
Building my first plane here pretty soon and trying to figure out what colors of covering I wanna get and what pattern to do on the plane and curious what others have done?
Got a pic of your LT-40? Post it hear please!
somegeek
Old 08-03-2005 | 12:41 AM
Default RE: LT-40 Pics?
Here's mine. Its my first plane, recently completed. I wanted something different than white so I went with piper cub yellow. The regular yellow looked too bright. The trim on the sides are the stock decals. I didn't like the way the tail decal looked so I didn't use it. I made the stripes using coveritte graphic stripping tape. The thick lines on the wings are actually 3 stripes right next to each other. Also, its only on the top part of the plane, so at distances, you can tell what the attitude of the plane is from the stripes.
Good luck with yours,
Rob
ID:	305006   Click image for larger version
Old 08-05-2005 | 10:42 PM
Banned
I don't have any good pics at the moment, but should have some withing a week. I did a !QUOT!fan!QUOT! pattern in red on the top of the wing. It makes it really easy to see the orientation of the plane in flight. Used standard white and the decals for the rest.
ID:	306092   Click image for larger version
ID:	306093   Click image for larger version
Old 08-05-2005 | 10:50 PM
MajorTomski's Avatar
The only critical thing on a trainer is to get the top wing and the bottom of the wing in contrasting markings. If you use a span wise stripe on the top then use a series of chordwise stripes on the bottom, or completely different colors. Helps in figguring if its turning towards or away from you.
Old 08-05-2005 | 11:17 PM
somegeek's Avatar
I have a couple rolls of Corsiar Blue and a couple rolls of Aluminum to cover my LT-40. Just have to figure out a color scheme. Only thing I know I'd like to do at this point is to have the top and bottom contrast each other.
Old 08-07-2005 | 12:39 PM
WacoNut's Avatar
ORIGINAL: somegeek
Be very careful with these colors, they are both very hard to see in the air especially in the late evenings. I am assuming you are just learning to fly and you need bright colors that will stand out and show you the attitude and direction of the plane.
Good Luck!!
Anthony
