TF P 47
Hi, I am building a Top Flite P-47 thunderbolt .61 size and I am on the stabalizer section. It says that you have to add the hinge blocks in the stabalizer and the dimensions are something like 1/4 inch, by 1/2 inch, by 1 inch, but I cant find any. There is supposed to be a total of 4 of them. I found 4 blocks almost the same size, except they were a bit thicker and shorter, and there is only 4 of them, I was thinking if they are te hinge blocks. If anyone has built this kit please let me know, this is the part that is holding me back from contuning on building it. Thanks
MO
They should be in the package, keep looking! I I would read ahead to check to see if the ones you have found are for the wing. If you dont have them, i bet you could make some. Good luck!
