Reload this Page >
Genltemen...I messed up
Old 12-07-2005, 06:42 PM
Pocho
Pocho's Avatar
Default Genltemen...I messed up
I am installing mechanical retracts and the task did not come out as neat as I had anticipated it would. Would it be okay to place the plywood that the retract screw into at an angle inbetween the wing ribs so that the retracts sit on there nice and flush with the wing?
ID:	366478   Click image for larger version
Old 12-07-2005, 07:35 PM
MinnFlyer
MinnFlyer's Avatar
Default RE: Genltemen...I messed up
No problem, just break the mount loose and re-glue it in the correct position.
If it's epoxied in place, a good heat gun may soften it enough to make removing it easier
Old 12-07-2005, 07:43 PM
Countryboy
My Feedback: (25)
Countryboy's Avatar
Pocho,
Maybe a study of these pics will help a bit.
In answer too your question, yes....the more you can get the gear angled forward, the better.
ID:	366533   Click image for larger version
ID:	366534   Click image for larger version
ID:	366535   Click image for larger version
Old 12-07-2005, 08:34 PM
Pocho
Pocho's Avatar
Thank you, both of you thank you you've been alot of help. I did not expect this to be so trublesome, these retracts SEEM amazingly easy to install.
