Sig Kougar "CG"
Sig Kougar "CG"
Hi all..I can't understand where the Cg is in the Kougar.. The instructions are as follows: Test fly with the balance point located anywhere between the leading edge and 1/2" back from the leading edge at the wing tip.. Is the Cg 1/2 ' from the leading edge, if so it doesn't sound correct..I've only built 2 other kits and the Cg was 3-31/2" from the leading edge..So people put your thinking caps on and figure this out..
Thanks in Advance Dan
My Feedback: (61)
CG
This plane has a tapered leading edge,if you draw a straight line from wingtip to wing tip @ the 1/2" point at the wing tip,you wil be at the 1/3 back from the leading edge at the fuse.I have one of these planes and I used the rule of 1/3 back at the fuse and it flew fine.
Hope this helps
Hope this helps
My Feedback: (25)
Kougar C.G.
As I remember on mine, I did it about a thumbs width fromm the LE out at the tip. It flew great, would snap roll very fast and still be gentle on landings with no worry about it stalling. Gotta love the Sig Kougar!!!
