Reload this Page >
Carl Goldberg Super Chipmunk build
Old 08-09-2006, 11:15 PM
  #76
RVM
Default RE: Carl Goldberg Super Chipmunk build
Your plane looks great! I really like the way you used the colors.
ORIGINAL: DVI
I built my Chipmunk about two years ago. I power it with a OS61FX engine. It flys very well, does great snaps and spins.
I have never posted a picture before, But will attempt to do so.[img][/img]
Old 08-10-2006, 07:08 PM
  #77
DVI
Thanks RVM
Stole that color scheme off a biplane pic I saw.
Good luck with your Chipmunk!
Old 08-15-2006, 02:49 PM
  #78
Campgems
I've got a Goldberg Super Chipmunk kit and I'm trying to decide if I should build it for my second plane or build a Sig Four Star 60. The Four Star was recommended by my instructor, but I 1. already have a Chipmunk and 2. I reall like the looks of the Chipmunk.
Is it going to be to much to handle for a second plane by a not very good pilot, or should I go with the four star??
Don
Old 08-15-2006, 03:35 PM
  #79
RVM
I think as long as you keep the throws per the instructions you should be fine. I would tell you that you will be increasing the throws rather quickly, as the Chipmunk is really very easy to fly.
Old 08-17-2006, 09:27 PM
  #80
ptmac3
ptmac3's Avatar
ORIGINAL: Campgems
Don
The Four Star 60 will give you more building and flying experience before tackling the Chipmunk. I had a Chipmunk that weighed about 8lbs. That's a little on the heavy side and it definitely came in a little hot when landing, even with the flaps. It is also more difficult to build than the Four Star. Don't rush it. The Chipmunk will still be there.
Old 08-22-2006, 07:19 PM
  #81
jamsam
Hi all-
Maiden flight of my CG chipmunk was this past weekend. It was a relatively windy day and I noticed there was some slight shimmy in the yaw direction on high speed passes. Anyone else experience this? The rudder linkage is not as stiff as I would prefer (used the nylon push rods). I'm wondering if I should retrofit to a pull-pull system. Any thoughts?
I also need to diagnose a fuel issue. Seems the engine (OS61FX) would die during the last 90-degrees of an outside loop. (First 270-degrees of the outside loop = no problem). Hmmm.
Other than that, it flew great. Hardy any trim adjustments necessary.
. . . .(can't seem to get the images to upload). . . .
ID:	511547   Click image for larger version
Old 08-22-2006, 07:21 PM
  #82
jamsam
Guess the images did get uploaded. . . . .
Old 08-22-2006, 07:23 PM
  #83
RVM
Great job!
I would replace the pushrod with a pull-pull system. I bet if you do this you will not have that yaw problem anymore.
ORIGINAL: jamsam
Hi all-
Old 08-22-2006, 08:25 PM
  #84
parrthd
also i notice that i have a bit of "rudder shim" while flying in windy conditions. could have been the wind if it was blowing hard enough.
Old 08-23-2006, 12:58 PM
  #85
donkey doctor
Hello; Someone asked that I post a picture of my RCAF chipmunk. I'm not sure it was here or in another thread that was about cowls for the chippy. Anyway, this is the only picture I could find.
Old 09-01-2006, 05:07 PM
  #86
RVM
Ok, I finally got some time to post up the latest pictures.
I don't know if I mentioned this before, but if I did, I'm saying it again anyway!
I wasn't happy with the way the ribs fit on the first wing panel I built. So, I called Carl Goldberg and had them send me the parts for another wing panel. I got that in a couple of weeks ago, and just got to work on it the other night. I went ahead and set up my table so I could work on both wing panels at the same time. I've gotten most of the work done. Today I'm getting the sheeting on top done as well as mounting the landing gear supports and blocks. I also hope to get the hingepoint supports in as well.
If you notice, I left the landing gear supports out this time. I think it will be easier to get them a perfect fit after the sheeting is attached. Once it all dries, I will be easily able to make the cutout from the inner side of the sheeting, and I can then easily trim it to fit around the LG supports. The way the manual has you do it is to make some measurements of where the support will be, then cut a hole, then put the sheeting on. A bit less accurate than I would prefer, and much more of a hassle.
You can see on the LE sheeting that I use a lot of clamps and a lot of tape. Once I get the front and back of a particular piece of sheeting attached (this only refers to a curved surface), usually with tape and/or clamps, and oftentimes medium CA, I'll put the parts under weight. I get a piece of MDF that runs the entire length of the wing panel, and set it at the midpoint between the front and back edges of the sheeting. The reason for doing this is sometimes, when bending the balsa and taping/clamping it into place, the middle will bulge up a bit. Putting the weight right in the middle solves this and makes for a nice, even curve along the top of the ribs. If you notice the clamps are not on the back edge of the sheeting. The tape is enough to hold that part of the sheeting on, and since the ribs won't fit undernear the piece of MDF, I took them off.
I finished the vertical stab and rudder, and only have to shape, sand and hinge the horizontal stab and elevator. None of the hinges are glued in yet. I'm very pleased with the way the tail section is coming together. Probably because I cut all the pieces to fit myself. I am a bit less happy about the wing panel, though if you think about what you are doing you can easily work around the ill-fitting parts.
ID:	517196   Click image for larger version
ID:	517197   Click image for larger version
ID:	517198   Click image for larger version
ID:	517199   Click image for larger version
ID:	517200   Click image for larger version
ID:	517201   Click image for larger version
ID:	517202   Click image for larger version
ID:	517204   Click image for larger version
Old 09-01-2006, 05:20 PM
  #87
RVM
oops
Old 09-02-2006, 08:46 AM
  #88
parrthd
hey robert, have you got thost two "oil spots" off the fin sheeting yet?
Old 09-02-2006, 10:17 AM
  #89
RVM
Yeah I think so. There seems to be a little stain left, but the smell of oil is gone and it feels just fine.
How is the Skybolt coming? It will be ready for Sunday, yes? [8D]
ORIGINAL: parrthd
Old 09-03-2006, 12:09 AM
  #90
parrthd
maybe the 5th or 6th sunday........if you DON'T count september 3,............LOL
i've been refitting a Staudacher i traded for and trying to get it ready. it's had my attention most of the week.....well what little bit i've got to do this week.
Old 09-03-2006, 01:18 AM
  #91
RVM
Maybe about the time I can get back out to Wren you'll have it ready to go. I might even be have this Chipmunk ready by then. I didn't get as much done on it today as I would have liked, but I hope to make up for it over the next couple of weeks.
ORIGINAL: parrthd
Old 09-12-2006, 12:16 AM
  #92
parrthd
made any headway on the chipmunk? noticed that you haven't posted anything in several days now.
oh yea, that 300S i was telling you about, i told you wrong. it's a great planes KIT .90 size, motor from .91 to 1.20
i'm planning on going over there tuesday afternoon for a few snapshots and then i'll send them to you.
Old 09-12-2006, 01:38 AM
  #93
RVM
I've gotten a little bit done. I'll post a bit once I get a few more pictures. I've just been really busy lately.
ORIGINAL: parrthd
Old 09-12-2006, 02:12 PM
  #94
DBono99
Hi All
I have a friend who's just started building the Chipmunk..He's going with dual aileron servo's, any information regarding the dual servo's on this plane will be helpfull..
Old 09-12-2006, 03:41 PM
  #95
NCIS
When I built mine I just used the stock hardware and the bellcrank for the ailerons. I did put the flaps on it and I just used the Hitec 6 channel radio with 5 heavy duty servos that came with the Radio. Why are you changing everthing and beefing it up? Mine does great the way I built it right from the instructions.
Gibbs
Old 09-12-2006, 03:51 PM
  #96
NCIS
I haven't visited this thread since I wrote my first post on it. I just wrote one about why the builder is beefing it up. Just above! I will post some pictures of my wild looking chippy soon.
Gibbs
Old 09-12-2006, 03:56 PM
  #97
RVM
At this point, due to some time constraints and the fact I just destroyed another plane (and I want to get started on my Extra ), I will probably be cutting back a bit on the mods. I will be using two aileron servos, and I'm still using carbon fiber pushrods etc., but I'm not sure if I'll be using the ABS wingtips and fairings. I'm going to be ****ing my Saito .91 into it instead of the 1.00, and probably staying with the stock muffler.
The main reason for doing these things is to make the plane fly more precisely. I am not really pleased with a lot of the stock hardware provided.
Pictures are definitely a must!
ORIGINAL: NCIS
Gibbs
Old 09-12-2006, 05:08 PM
  #98
NCIS
Here are the pictures if I did it right!
Gibbs
[img][/img]
ID:	523022   Click image for larger version
ID:	523023   Click image for larger version
ID:	523024   Click image for larger version
ID:	523025   Click image for larger version
ID:	523026   Click image for larger version
Old 09-12-2006, 05:16 PM
  #99
NCIS
One more try
Gibbs
Old 09-12-2006, 05:21 PM
  #100
NCIS
One more try
Gibbs
ID:	523033   Click image for larger version
ID:	523034   Click image for larger version
ID:	523035   Click image for larger version
ID:	523036   Click image for larger version
ID:	523037   Click image for larger version
ID:	523038   Click image for larger version
ID:	523039   Click image for larger version
ID:	523041   Click image for larger version
