Heat Sealing Iron Temperature
How do you measure the temperature of your sealing iron??? I like to work with ultracote and I need to know when the iron is at 220 degrees F so the glue can get maximum bonding without shrinking the material. Then I like to take the heat up toward 300 degrees for shrinking. I had a Top Flight bimetal thermometer, you know the one that is in the shape of a coil and sits on the bottom of your iron while you are holding it upside down. It takes forever to get an accurate reading. I have used trial and error for the most part over the last 30 years and have done pretty good with it, but I have found that having the correct temperature is the best way to go. Especially on a new iron that you are not familiar with and need a way to check its temp.
I have just started using an infrared thermometer built by Raytek. All you do is point it at your iron and you will get an instant reading. No need to use the bimetal thermometer anymore, this baby is the way to go. It will also be good for checking engine temperature. Is anyone else using an infrared thermometer with your sealing iron?
My Feedback: (12)
Re: Heat Sealing Iron Temperature
One other tip I have read is to actually have 2 irons. Set one at the lower temperature and the other at the higher. This way you don't have to change temperatures on the iron and wait for it to heat/cool.
The infra-red thermometer may be a little expensive though.
Maverick
The Raytek infrared thermometer that I have cost $145. Tower has one in the $70 dollar range. It would work fine , but it doesn’t have a laser sight, and at close range you don’t need a sight anyway. These are amazing little devices and well worth that price.
Iron Temperature
I got fed-up always wondering whether my covering iron was the right temperature, so I made this handy temperature chart http://www.rcuniverse.com/showthread...54&forumid=107]
My Feedback: (13)
James,
By gum, you're a genius! Those laser temp guns are all the rage among some heli pilots, to check engine temp with. Unfortunately, they are mainly deluding theselves, as by the time they get the ship on the ground and spooled down to where they can check the temperature, it has changed quite a bit already. But it is a neat toy...
I too have one of those coil thermometers, and it is indeed a PITA to use. But I can see where one of these temp guns would be just the ticket. And you're right; proper temperature on the iron is one of the keys to a good covering job.
Several guys have been after me to try their temp guns. Now, when I'm ready to cover the Contender, I will! Boy, are there gonna be some rolling eyes. I can't wait...<G>
Steve
Steve
