 Kit building question >
Old 04-14-2007 | 07:07 AM
Default Kit building question
I'm just getting into building kits (2nd one) and my ins.say to build the tail feathers first which I did and the wings next. The plans have the fuse. and tail on the sheet thats on my board and I was thinking about going ahead and build it and then build the wings do you guys ever skip around on the instructions and then come back?
Old 04-14-2007 | 07:16 AM
meaden's Avatar
Default RE: Kit building question
Yup, I build what I feel like building when the mood strikes. I'm building a biplane now and I'm putting the second wing off till the end...
Just make sure it's not necessary to have one assembly done to start another.
Old 04-14-2007 | 07:24 AM
Thanks, I don't see any reason I can't build the fuse before the wing.
Old 04-14-2007 | 07:26 AM
heli_Rod's Avatar
You can build any section you want first. Just read ahead in the instructions so that you don't miss a step or box yourself into a corner by missing a step that HAS to be done in sequence. I build the tail feathers first because that's my least favorite part and just want to get it over with...LOL.
Rod
Old 04-14-2007 | 07:32 AM
meaden's Avatar
Tail feathers, wings...everyone has their least favorite part of any kit
Old 04-14-2007 | 09:47 AM
bipeguy03's Avatar
I't does'nt useally matter but make sure that your design does'nt need the wings to help set up the fuse. this is mainly bipes though.
Old 04-14-2007 | 01:55 PM
My Feedback: (-1)
I like to read the instructions first A couple of times to see if I need any parts before I can go on with something else then just build what I'm in the mood for. If you don't read through A couple of times though it can jump up and bite you, been there.
Old 04-14-2007 | 08:22 PM
Just be sure something doesn't need to be fitted to something else during the construction.
I like to start with the tail surfaces. They're usually pretty easy and get you started quickly. I build the wing next, because the fuselage usually need to be fitteds to the airfoil and the attachment points. Then I build the fuselage. If there are any little sub assemblies, like drop tanks, wheel pants, etc., I'll build them whenever I have a spare moment or two.
Dr.1
Old 06-08-2007 | 04:50 AM
i got a question i am building a hots and it calls for cutting 1/4 balsa sticks for the tail feathers and i cant seem to get the angle right and never get them to line up properly how can i easily cut it to match up perfectly thanks
Old 06-08-2007 | 06:14 AM
cut it oversized and sand for a perfect fit .
Old 06-08-2007 | 01:35 PM
AllTheGoodNamesAreTaken's Avatar
My Feedback: (180)
ORIGINAL: niceguy1817
You NEED this. I find it to be quite useful for what you are talking about.
[link=http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXG876&P=0]Miter Sander[/link]
