balsa usa phaeton 90
#127
To spare some unneeded details, I finished the lower fuse to where I needed to do other stuff. Brought the tail together and fit the cross pieces and landing gear mounts. Now I need to work the tail group. Before that starts I must tell the story. I originally intended to modernize this planes looks by imitating an Ultimate. My son talked me into doing it old school and well, of course I went that way. This plane lends itself well to imitating a "fun scale" Curtiss F6C Hawk with the flat sides and radial cowl, so I went that way. (I love radial engines and now have an excuse!) This is where I take off from original plans.
#128
Bear with me. I said "Fun Scale". Kinda sorta resembles it in the end. I hope. One issue with the Phaeton was the vertical stab needed more area. The F6C lends itself well to the need as you notice the large V stab. Great! So first order was changing the shape of the Horizontal Stab. This pic shows me drawing in the plans for it. On the bottom side is original plan and top is my drawn plan with the dashed lines showing the original outline.
#129
So I have the horizontal stab finished. (mostly) In the pics below you'll see I opted to reduce weight more by a built up elevator instead of the 5/16 slab directed by the kit. I'm really leaving the original design behind here now. BUT, I had to order in some more wood. You think you have every size wood needed but nooooo........
#132
Phaeton Wing struts
Hey there,
Just picked up an old Phaeton 90 and it didn't come with the metal wing struts.
I'm having a bit of trouble making the ones I ordered form Balsa USA fit. Did they change the design of these things.
Any close up photos of the mounting areas would be greatly appreciated. Or if you have that page in the manual that would be great as well.
John
John
#133
WA
Phaeton 90 Wing N Struts
Hey there,
John
John
Wing N Struts, the wire slides into the wing, then it is held to the wing with a bolt.
View of the two plywood mounts in the wing for the N struts.
The two holes in the covered wing for the N struts. One hole is for the wire and the other for the bolt to hold it in place.
