ELEVON ISSUE...
IL
Hi,
I have a RICCS RTF Mirage 2000. While putting it together I noticed upward Elevon travel differs on each wing (left up elevon travel is greater than right up elevon travel). Can you please tell me how to correct this issue and balance out the travel. Note: elevons are in balance at neutral stick and both horn/clevis adjustments are identical. Radio is 4ch DYNAM, servos preinstalled by RICCS.
Ken
Ken
Sounds like the control snake is flexing.
Happens most on push, up, control.
Check the snake on the wing with less up, and if all others things are equal, I think you will detect some movement.
Tack it in place with some glue and all should be well.
