Reload this Page >
GP F4U Corsair .40
GP F4U Corsair .40
Old 10-05-2010, 01:56 PM
  #176
drube
drube's Avatar
Default RE: GP F4U Corsair .40
Thanks! I like neon orange..lol It helps when flying after work in the eve's. I still need to add something to the wings though...
Here some pics I took after the maiden flight.
ID:	1511437   Click image for larger version
ID:	1511438   Click image for larger version
ID:	1511439   Click image for larger version
Old 12-10-2010, 06:11 PM
  #177
redbee03
I'm doing the same kit right now.  So far I'm ready to monokote it, this has been a great build!  Can't wait to fly her!
Old 10-04-2011, 07:45 PM
  #178
linderman
has anyone added scale guns drop tanks or the air to air missles to this kit?
Old 10-04-2011, 08:16 PM
  #179
drube
drube's Avatar
I haven't seen them on this kit but i'd like to.
Old 10-04-2011, 09:07 PM
  #180
EscapeFlyer
EscapeFlyer's Avatar
Just wanting to say I have really enjoyed this thread. It has been a lot of fun. Thanks!
Subscribed.
Brian
Old 10-17-2011, 05:57 PM
  #181
drube
drube's Avatar
I haven't flown mine in a while due to it being way tail heavy.I'mplanning on adding foam to the outside of thefuseand then carve/sand to scalish shape. Then My friend and I will use it as a plug and make a fiberglass fuse. Should be alot lighter and fly better. May try to figure out how to do a foam core wing also, but I don't know.
Just need to finish up my other project then start this one.
Looks great redbee!
Old 03-19-2014, 09:10 AM
  #182
niceguy1817
hey guys can someone help me i am a newb at building and i am building the gp corsair .40 kit and not paying attention i built the thrust angle to the left instead of to the right what can i do
Old 03-19-2014, 09:49 AM
  #183
mustangman177
How far along are you in the build ? Can you take out the firewall and re-glue ? This is not something you want to leave in like this.
If cannot take out, put in another firewall in front of the original, with the "right thrust" (no pun intended) built in. If this is the case, will push your CG more forward, and throttle linkages will be longer.
Old 03-19-2014, 12:20 PM
  #184
niceguy1817
havnt put in the firewall yet but have to put in the 2 1b backwards to make it work
