Tower Hobbies Uproar 40 build
#501
My Feedback: (15)
CA
RE: Tower Hobbies Uproar 40 build
Never tried a fillet like that but it is looking good! is that 1/2" Triangle stock? hard to hold I am thinking... might have to try that it looks sleek! I got the Rudder assy built and one aileron. Some of the wood is a bit softer than I would like but I try to use it for the smaller parts and save the stronger stuff for the long pieces. No flying this weekend as it was very windy here[:@]
#502
ORIGINAL: Daddyo57
Never tried a fillet like that but it is looking good! is that 1/2'' Triangle stock? hard to hold I am thinking..........
Indeed it was a pain to hold but I managed. I did not do it in this case. But, one could tack (glue, pins, small nails) some small scrap balsa blocks to the 2X4 to help hold the triangle stock.
later
#503
My Feedback: (-1)
Rick, that really does look good. Seeing it reminded me that my wood shop/club has a shaper that would allow me to make up some nice sticks to keep on hand in that shape. The only machine in the shop that scares the peewaddle out of me. I have operated it a few times but never had to set it up. Or I could save my body parts and use the PVC/sand paper. Windy here too with a nasty looking storm blowing in, no flying at all sense last Wednesday and this week isn't looking very good.
Gene
Gene
#504
My Feedback: (15)
CA
Gray Beards shaper made me think of the router tables, they arent near as cool as a shaper but I wonder how they work on Balsa? might grab the part and fling it. I am with you Gray Beard, the shaper is a mean looking machine! we had a giant planer at my high school and that thing would chuck the piece back at you at high velocity! fun with wood tools!
#505
My Feedback: (-1)
ORIGINAL: Daddyo57
Gray Beards shaper made me think of the router tables, they aren't near as cool as a shaper but I wonder how they work on Balsa? might grab the part and fling it. I am with you Gray Beard, the shaper is a mean looking machine! we had a giant planer at my high school and that thing would chuck the piece back at you at high velocity! fun with wood tools!
#506
My Feedback: (15)
CA
I think wood working is one reason I like RC so much... yeah I know it isnt the same but the tools are smaller! I LOVE woodworking and want to do much more of it. I would really enjoy a co op like that! good for you! it is like RC too I think, you cant really make alot of money building stuff unless you are a cabinet maker but it is fun. I am continuing my Uproar 60 build and am ready to start the wings, the wings themselves seem like thay are as light as the Uproar 40 but the center section seems like it will be heavy and add to that the heavy spar tube and aluminum spar, there is room for improvement. I am going to build this one fairly stock and wont make many mods except to make the rudder and elevator a bit larger, I also made the ailerons come all the way to the fuselage (well except the distance of the center section)I needed a bit more 3/8" square stock for this over the amount supplied with the kit. I might split the difference on the landing gear position between rough field (way forward) and smooth field (more rearward) this expalins the pictures of the Uproar 60s I have seen where the gear seems different. The gear appears a bit small in all the pics I have seen, I have never seen an Uproar 60 here where I live or ever, and am the only one I know who flies the 40 sized, their loss! I have a very different covering scheme planned for this bird, my son is making a .pdf overlay for the plans I had scanned of a bird skeleton, the backbone is all the way down the fuselage and the wings are of course spread across the tops of the wings, should be interesting to look at and hopefully accomplish he is very good at graphic design so it helps the old man out. A couple of pics of my not so fast building so far, I have a few days off so I hope to glue some sticks!!!!
#507
My Feedback: (-1)
Go Daddy Go!!!!! I can see a big mistake already, your next trip to sin city I will have to teach you how to stand back 6 feet and squirt the glue onto the wood, that's just way too clean to ever fly correctly. Next photo could you show us the wing and center section. I have a thought running around from side to side in my head but want to see how the stock wing is built before I say anything. I have never built the 60 before. Flown them though.
#508
My Feedback: (15)
CA
LOL I am not that good with the joints trust me!! working on it though! I plan to use transparent monokote red and or? so I want the inner structure to look good as well as work of course. Might get to the center section today, it is a busy little piece of work to be sure! as I said before, I think there is room for imrovement in the lightness of this part, in the future there be tha opportunity for just that! I will post pics of it when I get there for your scrutiny, I am totally open to any and all input from you guys 100 plus years or so of combined experience is a good thing!
#510
ORIGINAL: Bonified Wingnut
Here's another video of my Uproar 60.-BW
[link]http://www.youtube.com/watch?v=vO8B7RTZgTk[/link]
Well, that ole TH75 is a screamer with that prop on it. But those thick wings just don't go fast. I'll be running 13X4 props on 40 sized uproars powered by ST51's.
Landing was smooth[sm=thumbs_up.gif]. I was hoping you were going to show us some stunts.
#511
ORIGINAL: Daddyo57
............................I am totally open to any and all input from you guys 100 plus years or so of combined experience is a good thing!
Cliff????[] I've only been at it a couple years[sm=71_71.gif] Yeah Right
#512
RICKSTUBBZ - I had the 13x6 on it for one flight and it had much better vertical. But it was mowing the grass and chipped it. It really needs a 14" prop but it just doesn't have clearance. I still take it easy with it until I can come up with a back up. I give you a quick roll and a small loop, next time I will try to get more on video.-BW
#514
Bonified Wingnut,
If you are interested, on Post # 314, I posted, with some pictures, how I modified the stock landing gear to get more prop clearance. I found the stock wire very easy to work with. Only bummer to that is, easy to work with means eventually it will pancake out. I am sure the sixty size wire is very simualr if not the same stuff. At any rate with a small amount of bending I am sure you can run the 13" and it might even be possible to get the needed clearance for a 14".
Good Luck
Good Luck
#515
ORIGINAL: RICKSTUBBZ
Bonified Wingnut,
If you are interested, on Post # 314, I posted, with some pictures, how I modified the stock landing gear to get more prop clearance. I found the stock wire very easy to work with. Only bummer to that is, easy to work with means eventually it will pancake out. I am sure the sixty size wire is very simualr if not the same stuff. At any rate with a small amount of bending I am sure you can run the 13'' and it might even be possible to get the needed clearance for a 14''.
Good Luck
Bonified Wingnut,
Good Luck
#516
hey gang,i'v been lurking about following the builds.....just thought i'd share a few pictures of my roar today flew it twice and the slick 3 times. on the second roar flight i was doing and speed touch down and go when the lg snaped off and went thru the wing...ouch!! not really bad at all ,took me 2 1/2 hrs to repair it to what you see,but the design of ghost flames/smoke can't be replaced as i'm not spending $16 for another set .....or maybe i will,but thats the only part of todays mishape that bugs me.
beautiful weather to fly here in nj,so take it slow when doin the touch an go...lol...stu
#517
ORIGINAL: tobydogs
....................... on the second roar flight i was doing and speed touch down and go when the lg snaped off and went thru the wing...ouch!!
Stu,
That kind of deal usually makes me want to curse![:@], Glad to see the damage was not too severe and she looks ready to fly again.
Myself, a little at a time I am getting the covering finished up on Uproar #1. The sides of the fuse is all that is left. Man, did I ever mention how much I hate trying to cover a completely assembled plane. Even a 40 size is a PITA. Anyway, this thing just might be a reasonbly durable plane because I have not crushed, broke, or knocked anything off of it while beating it against the table, chair, floor, and anything else that could get in the way.
#519
My Feedback: (15)
CA
LOL I was just marveling at the fact that I havent broken a rib or had to repair something yet! I always break parts with my clutzy hands... I did cut a couple of spar caps short [:@].Sorry you dinged your bird Stu!!! man you get your moneys worth out them!!! I have to say the quility of the wood is pretty good on this Uproar, my last 40 sized one had a couple of terrible pieces and like a dummy I used them. I have the left wing looking like a wing now, I like this construction method but putting the sheer webs on the front means the bottom sheeting will be 100% no access when I install it. I dont like that but nothing I can do about it but do a good job the first time. I took a couple of pics, the last shows the bottom ready to put the leading edge sheeting and spar caps on, then glue on the leading edge slab. If the wind blows tomorrow I will build the right wing and hopefully start the fuselage and wing center section. Going fairly quick really, cant complain and I used some of Ricks "Tooling' methods to keep the wing root rib perfectly square. I used a different camera and the images arent the best quality.[sm=49_49.gif]
#520
My Feedback: (15)
CA
I am pretty sure that is just flat aluminum stock BW, I am betting you can get some at Lowes or a good hardware store. Should have no problem bending it in a vice with a tap or two from a rubber or rawhide hammer to persuade it into shape. Wire would work great too and might be lighter... might have to use 3/16" though for an 8 pound bird. Depending on the poer plant I use I may have to do the same. i wouldnt mind a Saito 100 or at least a 90 2 stroke, I want this baby to have vertical.
#521
The gear isn't as soft as stock aluminum from the hardware store. The Tower 75 is plenty but some of you power hungry people might like a 90 or bigger 2 stroke. I also thought about a 20 - 30 cc gasoline engine with taller gear, but there isn't much room for the ignition.-BW
#522
TX
I used an aluminum door kick plate and cut it to my specs. The only thing that I have been thinking of adding would be a cross wire to make them a little more rigid. But if you land nice they don't bend and if you do have a hard landing, they give and can be rebent into position very easily. I'll post some picts in a few... cant upload right now.
#523
My Feedback: (15)
CA
Not sure what the temper of hardware aluminum is but stock is 6061 (printed on gear), I am sure store stuff is 6061 (weldable) but probably not T-6 more like T-3 softer. I have used the hardware stuff with great success in the past, I would just say dont bend it too flat, meaning make the top flat mounting part a bit wider so you can have a more vertical downward leg and will be fine.
#524
SLAP it - FLIP it - and RUB it down. Thw #1 uproar is freaking covered...............................
Not the best covering job I've ever done. But I won't be worried about it coming loose and/or blowing off either.
Just got to put all the nuts and bolts on now along with a little radio set-up.
#525
My Feedback: (15)
CA
Rick it looks great man!!! really sharp, I bet it will look really good sitting on it's tail in a hover too!!!!! Great timing too for Memorial Day!!!!! God Bless America!!!!!!!! [sm=shades_smile.gif]
