Reload this Page >
PICA Cessna 182 build
Old 11-17-2009, 03:07 AM
Hughes500E
My Feedback: (16)
Hughes500E's Avatar
Default PICA Cessna 182 build
I just purchased a beautiful old kit of the Pica 1/6 scale 182 Cessna. I don't suppose someone would have the construction manual for it ?
Old 11-18-2009, 03:31 AM
Hughes500E
My Feedback: (16)
Hughes500E's Avatar
Default RE: PICA Cessna 182 build
Someone has to have the construction manual [:-]
I'm sure I can fight my way through it but I'm going to have my hands full just lightening it up. Sure is built I mean over built well
Old 01-10-2010, 02:12 PM
duradad
My Feedback: (40)
Hi,
Have you found any help with your Pica 182?
I just acquired a partially completed model that , I suspect, is a Cessna 182 by Pica. It may be a scratch build because some parts have numbers that look to be hand written and the holes through the fuse formers look like they were not die cut. (does this sound like your kit?). However, it came witha fiberglass and a plastic cowl, plus a molded front window, and it is about 72 inches in Wingspan. So, it may be a Pica kit.
The wing, flaps, ailerons and fuse are built, but not fully planked. The tail surfaces are missing
I'm hoping to find drawings so that I can build the tail feathers and finish. My biggest problem will likely be finding a plastic rear window for it.
I'd appreciate knowing what you have learned.
Bob
Old 03-11-2010, 12:57 AM
terryp-51
I need a copy of the Pica 1/6 Cessna 182 plans. Not instruction manual. Can you help. Thanks
