RCM CESSNA 0-1E/L-19 BIRD DOG Build
#76
TX
RE: RCM CESSNA 0-1E/L-19 BIRD DOG Build
Thanks very much for your reply. I have looked at the Vailly kit and understand your suggestion. As much as I would, I have to stay away from larger engines. I ordered the cowl but had a question about the windows? Do you have to mold the plastic into shape or is there a place it can be ordered? If not, can someone explain how to accomplish this task? Sorry to bother you with questions, I guess I'm a leach when it comes to the L-19. I will be building a jig, thanks for the suggestion!
Best regards,
Fred
Best regards,
Fred
#77
I bought flat plastic from Balsa USA and just held my covering iron close for a couple seconds where it needed to make particularly sharp bends.
And, yeah, I built this one to avoid the large plane cost and transportation hassle myself. But, I kinda regret not taking the plunge anyway.
#78
ORIGINAL: Nergall
Well, I wasn't planning on posting this build until I saw someone here complaining about most of the build threads being the same small set of kits. (Guilty! I have a 4*, an Ugly Stick, and a Kadet Senior!)
Plus, this built looks considerably more complicated than I've done before, so I might need a little help!
Anyway, here's a link to the plans:
http://www.rcmplans.com/index.php?ma...oducts_id=2003
One of my first planes was an L19 that another club member built and sold to me. Ithink it was made from a Sig kit. It might have been a J3 that he converted but do remember it as from a Sig kit in the late 70's.
Thank you for the build thread.
#80
TX
I have the Bob Rich 72" Bird Dog short kit coming. What I need to know is where can I find DECALS or tranfers with the correct font,style, color & size for the MARINES version? Or is there any particular person that actually cuts out special orders?
Fred
#81
I built the Army version, but I still laid out the decals myself and then had a fellow club member cut the vinyl for me.
There are a ton of online services that do this - some of which may have the designs already on file. Check the advertisers in Model Aviation?
Good luck on your build!
#82
TX
Does anyone know where I can find an RCM back issue April 1995 featuring Bob Rich on the front cover with his Cessna L-19? I would be willing to pay a reasonable cost for this back issue.
Fred
Fred
#83
RCM should have sent you a xerox of it with your plans. If not, send them an e-mail. Many of the plans services forget.
